passenger seat bolt?
#603429 01/27/2025 2:07 PM
tikiman Offline OP
Hi guys, I am in need of a new passenger pillion bolt, but cannot find one for sale anywhere. I've tried numerous sizes from random hardware stores, but haven't been able to make one fit. do any of you know where I can get a replacement? Newbonneville used to sell them but not anymore.
Re: passenger seat bolt?
tikiman #603430 01/27/2025 2:28 PM
I turned them on my lather but you can use 2 washers, a spacer ,and a bolt all available at the hardware store. I am assuming you mean the one at the back of the drivers seat that holds the front of the passenger seat. The one at the back of the passenger seat is just a standard bolt. I would use stainless.
tikiman #603431 01/29/2025 5:46 AM
tikiman #603432 01/29/2025 1:21 PM
A regular bolt could be used to replace that one, I would imagine he means the slotted one hetween driver seat and passenger that holds the front of the passenger seat.
tikiman #603435 02/02/2025 7:02 AM
If you mean the one between the rider & the passenger, then an 8mm x 20 mm should fit, the lower one should be a 6mm x 16mm.
Good luck.
tikiman #603437 02/04/2025 2:33 AM
tikiman Offline OP
i believe the bolt housing is stripped. It cannot hold a bolt. The back seat comes loose after a few minutes. for a hole that's been drilled into the rear fender, what would the best idea be to fix this? I wonder if this is too shallow for a heliocoil? That said, I've not installed a heliocoil before so I can't say for sure.
tikiman #603438 02/04/2025 5:30 AM
tikiman #603439 02/04/2025 7:30 AM
Run a bolt up from underneath and put an acorn nut on it. It is possible to replace the nutcert but , to me, nut worth the hassle.
