Big bore kits question
#460850 08/21/2011 11:51 AM
ce7871 Offline OP
I while back someone posted pretty much every outfit that big engine mods, one was in FL and had a program where you could just ship them the engine. I can't seem to find the post. Does this ring a bell with anyone?
Re: Big bore kits question
ce7871 #460851 08/21/2011 2:24 PM
Two_Wheel_n #460852 08/21/2011 8:15 PM
ce7871 Offline OP
Neither of those two links are what I was talking about, thanks though
ce7871 #460853 08/22/2011 6:08 AM
oldroadie #460854 08/22/2011 8:17 AM
ce7871 Offline OP
oldroadie #460855 08/22/2011 8:19 AM
I worked with Bill Gately at bonnevilleperformance.com, he shipped the sleeved cylinder and piston kit to me and I shipped the stock cylinders back after I swapped them out. I can't say he won't have a core charge, but he didn't make me pay one.
roadworthy #460856 08/22/2011 8:21 AM
ce7871 Offline OP
my problem is, if i do this upgrade, who i can get locally to do the work...our local stealership is NOT an option.
roadworthy #460857 08/22/2011 8:33 AM
ce7871 Offline OP
Question, to those who have had these upgrades done. i know our engines to be pretty much bulletproof stock, can the same be said after these mods?
ce7871 #460858 08/22/2011 11:01 AM
You can pull the motor yourself and ship it to Gately and pay the $500 flat rate to have the big bore installed. That's at the very bottom of the page on that link.
oldroadie #460859 08/22/2011 11:41 AM
ce7871 Offline OP
actually, Bill's brother live right here in MD and i already scheduled everything for Nov. thanks !!!
ce7871 #460860 08/22/2011 4:20 PM
Hey, good luck with the BB build, & let us know how it turns out.
ce7871 #460861 08/30/2011 5:53 AM
30,000km with minenow and no problems what so ever, seems to be getting stronger
Nick
Nick #460862 08/30/2011 6:00 AM
12000 kms since mine was done in March.
Runs like a train and still get 250+ before reserve.
Zen would ride a Triumph
ozspeed #460863 08/30/2011 8:36 AM
I went with D&D Cycles (Pensacola, FL) kit. They swap your barrels for bored nickelsil ones that are essentially just like factory ones but larger. The kit has either the Wiseco pistons or ones that are slightly higher compression. I went with the Wiseco ones.
I feel the longevity of the engine is no different that stock although I ended up putting in slightly stiffer clutch springs. The additional torque might have been tougher on the clutch, but it had 22,000 miles on it when I replaced the plates and springs.
RamSound #460864 09/04/2011 1:17 PM
Here is a link to D&D Cycles (Pensacola, FL) performance kits:
D&D performance
RamSound #460865 09/08/2011 9:17 AM
The D&D kit seems to be the same as the TPUSA kit, only cheaper. The CR's available are different & the TP kit comes with clutch springs, but even when added to the D&D kit it still comes in cheaper.
Any reason why?
TPUSA cams are cheaper though...
S.
sharp21 #460866 09/08/2011 10:07 AM
Any reason why?
S.
I am pretty happy with the D&D kit and the people there are very helpful with any questions.
mag10 #460867 09/08/2011 10:26 AM
I see you've got 12:1 pistons! Pretty high CR isn't it? What gas do you use?
How is the power with those?
S.
sharp21 #460868 09/08/2011 7:17 PM
S.
I use 93 octane. I had to retard the timing (via the pick up sensor) by 8.25 degrees. Backing up the timning was probably good for an extra 5 hp or so. The bike really is a lot of fun, once you crack that throttle, hang on!
mag10 #460869 09/09/2011 12:54 AM
Can you elaborate on retarding the timing? I've got a pieman module so would I still be able to do it?
S.
sharp21 #460870 09/10/2011 2:26 PM
it would still work with the pieman module. The pickup head itself is moved relative to the flywheel. Prior to retarding the timing I had some issues with knock on hot days or with lower octane gas. The idea was suggested by D&D as they had similar issues with their turbo charged bikes.
the picture shows the retarded pick up head.
mag10 #460871 09/11/2011 1:03 AM
Interesting. Is it just a case of loosening off the sensor & then moving it over? How do you tell when you are at 8 degrees?
S.
sharp21 #460872 09/12/2011 8:05 AM
S.
yes and no. it is as simple as moving the sensor over, and no because as it is layed out from the factory the sensor can only be moved about half a degree.
in the previously posted picture (look closely) you can see there is an adapter under the pickup head, that is what is setting the timing.
I can post a drawing of the timing adapter if you wanted to make one up for yourself. or, If you can view acad file I could PM one.
mag10 #460873 09/12/2011 12:06 PM
I've got Autocad. I'd love a copy if you dont mind
S.
sharp21 #460874 09/12/2011 2:11 PM
S.
(oops)it appears that I cannot attach a file to this forums PM. It you would PM me your actual email address I will gladly send you the drawing.
mag10 #460875 09/12/2011 6:54 PM
Micah,
I'd appreciate it if you could post a simple drawing of the adapter plate. Probably could go in the tech vault.
Gregger #460876 09/15/2011 6:16 AM
Micah,
drawing of adatper with parts list
drawing of flywheel timing diagram for 270 degree motor/ pick up head.
this adapter should work the same on a 360 motor but I have not tried it.
mag10 #460877 09/16/2011 4:26 PM
Thanks Micah,
Much appreciated.
Gregger #460878 12/31/2011 4:05 PM
ce7871 Offline OP
Ok, so I have bill gatelys brother Steve doing my big bore kit. I am very impressed so far, these guys are triumph alchemists. With the the addition of the air box removal, big bore kit, and bigger front sprocket, I also needed a preformance clutch kit, in that the the new torque output slips the standard clutch at around 4.5 rpm in 4th gear!! Oh yeah, daddy like!
ce7871 #460879 01/08/2012 2:05 AM
So jealous. I really want a 904 but i'm poor.
KaiserSoze #460880 01/08/2012 10:27 AM
What are you guys' opinions on the Plated all-aluminum cylinder vs
the Iron-sleeved one?
BrianT #460881 01/08/2012 6:39 PM
You can always have the plated upper, rebored and sleeved, when and or if you manage to wear it out. Heard nothing but positive things as to the longevity of Nikosil plated pistons and bores. There is a small advantage to not running a sleeve, and that is the upper cools a little more efficiently due to the better transfer of heat via the homogeneous construction. Quite a few properties of steel and aluminum alloy are different. Especially concerning temps. (disclaimer)IMHO
Ryk #460882 01/08/2012 7:07 PM
Mine is steel sleeved and runs about 190-215º consistently. I have flogged mine with the 904 for almost 20,000 miles and it's stronger now than when it was fresh.
roadworthy #460883 01/12/2012 8:46 PM
+1
ce7871 #460884 01/13/2012 3:09 PM
Say, I was wondering if you'd had any other mods..i.e.exhaust/air, and or carb rejetting. I've got the 904 and stage 1 cam, (D&D kit), with SS long cannons and Uni air filter w/bellmouth, have been playing with jets for best performance and can't quite get what I'm after. Torque is good, but can't find ponies. I also have a procom igniter that I'm thinking of setting up once I get the fuels delivery thing together. maybe airbox removal? Dyno shop? any input would be appreciated. thanks
snortonslim #460885 01/15/2012 2:25 PM
ce7871 Offline OP
just got my bike back from gately, mother of God!!!! the diff is significant. i will go into detail about it later, and what mods i have. right now i have to go thaw out, i had it up to 110 with plenty left over.
snortonslim #460886 01/16/2012 9:14 AM
ce7871 Offline OP
ok, the mods:
wiseco big bore kit (904) from bonnieville preformance
jet and pins came with the kit
air box
front spocket change out for the...18 tooth? 19 tooth? can't remember, one tooth up from stock
sceptre pipes
bonnie pro racing clutch and springs (mind you this is my only beef with the set up is that it is a total pita to hit nuteral right now, i have been told this will loosen up over time (which the original clutch did, so i assume it will)
to semi quote FJ, it runs like a raped ape, with a scalded cat on its back.
HOWEVER, if even after all that the bike does not have enough bang for you (don't see how because mine truely intimidated me a tad and i have been riding since i was 8) you can get HSR Mikuni Flat back Carburetors his (gately's) son has ONLY the carbs on his t100 race bike and thing is NUTZ.
ce7871 #460887 01/16/2012 12:59 PM
Are you running stock carbs?
I'm going to guess around $3-4000 for everything listed?
FriarJohn #460888 01/16/2012 2:40 PM
ce7871 Offline OP
yes, stock carbs. the 904 kit was roughly 1000.00 the air box kit was 250, clutch was 150 and labor for all was 450...i already had the pipes and the sprocket. but the pipes were 600...so rougly 2500 total i think the carbs are 1200 but they propbably would have changed me the same price for labor (really cheap)
ce7871 #460889 01/16/2012 3:14 PM
That's not bad at all. I wouldn't use them, of course, but I've considered the 904 upgrade.
