 Parking your bike
Posts: 713 |
My husband and I have an ongoing debate and I need your help.  Do you leave your bike in neutral or in gear when you park it? I always leave mine in gear and his is usually in neutral unless on a hill.
 Re: Parking your bike
Posts: 169 |
I leave mine in neutral only because I turn it off in neutral.
06 Speedmaster
Posts: 5,616 |
Depends on if I was in N when I shut her down.
NEW: 19 Goldwing Tour DCT
Posts: 8,393 Likes: 1
Posts: 8,393 Likes: 1 |
Its easier to push away when in neutral. So If you want to be pranked by your friends park in neutral. If not leave 'er in gear.
Edgar Allan Poe
Posts: 125 |
I second that one! hehehe... don't know if it's right or wrong but that's what I do.
I do lock the handlebars everywhere I go though.
2003 Caspian Blue America: Rush Exhaust, FREAK Kit, Almost Chrome Everything, 150/80/15 and 120/90/18 WWW, 18T and 42T Gears, Speedy Tach.
Logic dictates I park 'er in gear, but I'm not always logical. Neutral in the driveway usually 'cause I can just grab it and move it around.
Posts: 125 |
That parts the truth! I think my logic kicks me in the noggin' if I'm on anything other than flat. Any kind of a grade and it's in gear.
Posts: 2,580 |
Every bike I've had I've nearly always parked in neutral. I don't know why. Strangely, every car or van I've had, I've nearly always parked in gear. Probably because it used to annoy the hell out of the wife.  Do you think that might be why she's an ex-wife now
Posts: 1,738 |
I always park all vehicles in gear unless inside my garage.
Posts: 728 Likes: 1
Posts: 728 Likes: 1 |
I'm in mind to think like your Hubby, neutral unless its on a hill. That way I can start it up, before putting my gloves on if its been parked for awhile.
Posts: 713 |
You ALL were supposed to agree with me, jeez, now what do I tell him???? At least a couple of you are on my side.
Seriously though it's interesting. Thanks
Posts: 1,680 |
Always in gear, and usually with petcock OFF
Thom
Posts: 2,419 |
Does anyone else struggle to shift into neutral while the engine is not running?
This is the main reason I park in neutral - except if on a hill. If I have parked in gear, I usually need to start the bike in gear and then slip the clutch slightly before she will allow me to shift into neutral. All a bit of a hassle. Anyone know any tricks/knacks to overcome this issue?
Posts: 6,821 |
Neutral in my garage. Outside, I park in gear because it can get windy without notice around here and wind can push a bike, rolling it and making it fall over, seen it happen.
Posts: 6,821 |
Just roll it forward til it stops, back til it stops and split the difference so the pressure is off the gears. Should slip right into neutral without using the clutch. That's what I do if I want to start it before I get on.
Posts: 2,419 |
Hmmmm. Mine doesn't roll forward or back while in gear - no play at all.
Pull the clutch and it should.
Posts: 1,459 Likes: 1
Posts: 1,459 Likes: 1 |
Leave mine in neutrel unless on a hill or a boat. Would also put it in gear if it was on a trailer, thats never happened.
Posts: 2,419 |
Keith - I think you're missing the point.
Pulling the clutch while in gear with the engine off does not enable changing gear or moving to neutral on my bike - at least most of the time. It usually is very reluctant to move out of gear without the engine running (clutch in. So it requires starting the engine and applying slight load on the gearbox by slipping the clutch a tad.
Posts: 537 |
Nope
Edgar Allan Poe
Posts: 23,248 Likes: 64
Posts: 23,248 Likes: 64 |
Neutral, comes from when I rode my chopper all the time. Can't start an old Triumph twin in gear with the kickstart, the clutch disengages that. So when running up to start in a hurry there is no time to mess around finding neutral. Now I just do it out of habit.
+1 (plus, my garage might be the only truly level spot in the county )
Posts: 2,839 Likes: 3
Posts: 2,839 Likes: 3 |
old habits are hard to break. fuel off, neutral, and pointed out(always backed to the curb) in case i'm in a hurry when leaving. i suppose this all stems from when bikes were built a little less reliable
ENJOY!!!!! NEWT!!!!!
Posts: 7,706 Likes: 24
Posts: 7,706 Likes: 24 |
I didn't know there was any other way. Neutral then turn off the key. Ya see they put the key on the left side for a reason. So you would be in neutral first before turning it off. Can't let go of the clutch otherwise. Kick it down into gear if on a steep hill. It also makes sure you don't forget your key.
Just teasing but it does kinda make sense.
Posts: 20,096 Likes: 2
Posts: 20,096 Likes: 2 |
What ever you do watch this. http://www.youtube.com/watch?v=ti6_N19wc_A
Yep. However, every H-D I've ever ridden has had a kickstand which when extended feels somewhat "nebulous" down there and has given be the feeling that the bike will fall over once I get off of it.
And re the Kathy's question: I too almost always leave my bikes in neutral unless they're parked on a inclined surface.
Well I couldn't find a video of a Triumph rider who dropped his bike due to failure to engage the side stand. So I had to settle for a Harley rider.
Edgar Allan Poe
A good friend of mine ,Cousin Jimmy (RIP) has done that several times that I have seen. Always good for a laugh. Some old HD stands are designed to go up by themselves. The weight of the bike keeps them down.
Yep Ian, and like I was sayin', the sidestands on the newer H-Ds don't feel like they're fully deployed, even when they are.
And, Ducati for years had that whole "designed to go up by themselves when you'd swing the bike upright" thing goin' on, and of which I always thought was a left-side turn-signal smash(at a minimum) just waitin' to happen, too!
There is no definitive answer! Depends on where you park it. I do it all. Mostly just put her in neutral, side-stand down, fuel off, key off, lid on saddle, gloves wedged 'tween the speedo and handlebars.
Park at strange hotel or where you can't see it? In gear, steering locked, key out, fuel off etc...
...Mostly just put her in neutral, side-stand down, fuel off, key off, lid on saddle, gloves wedged 'tween the speedo and handlebars...
That reminds me...considering the ignition location on our bikes, I wonder how many of us around here have at least one time run down the battery 'cause we've used the kill switch to stop the engine but have forgotten to do that thing you mentioned that I've put in bold print there???
(...I have to admit I did that once!)
I have never shut my bike off with the kill switch. Never used to have one so never use it.
Well, I suppose that's ONE advantage to bein' sooooo "Old School", eh Ian?!
Posts: 231 |
Unless I am on a hill, I leave it in neutral, back in, use the kill switch, and leave the gas on. Only ran the battery down once this way, and I figure the fuel system is supposed to have fuel, so let it flow.
-W. Zevon
2020 Bud Ekins T100
Yep, I still want a point ignition and a kick start! No CDI to fail then or expense to replace it.
Posts: 2,626 |
If any of my "friends" pushed away my bike they would: A: No longer be friends B: Have broken legs BTW Missanies, I'm with your hubby, I always leave it in neutral unless it's on a hill. Then I leave it in gear.
The Hayabusa Killa
Procom CDI
This is how I park mine. http://www.youtube.com/watch?v=wx2J4o4qr00see how perfectly executed. No side stand required.
Edgar Allan Poe
Posts: 5,068 Likes: 1
Posts: 5,068 Likes: 1 |
Neutered or in gear , 'tis always better to crank it in neuter . If it be in gear and you pull in the clutch to turn it over , there's a drag on the starter . Next time it's cold , put 'er in first , pull the clutch and feel how much harder it be to push it .
Posts: 3,937 |
Mine's usually in park, with the e/brake on.
And you may see me tonight
With an illegal smile
J. Prine
Posts: 237 |
Allways leave the Bikes in neutral .. But I live in Florida.. Flat.. Flat... Flat... easier to move around etc...
07 SPEEDMASTER ..SLASHCUT BUBS..
NOLOGY COILS/WIRES ..PHANTOM BLACK ..CHROME COVERS...K&N PODS..
BEAUTIFULL WHEN SHE RUNS RIGHT..SHE WAS ..
.. I LIKE HER>> ALOT ~~
Posts: 10,736 Likes: 8
Posts: 10,736 Likes: 8 |
kickstand schmickstand
Posts: 2,152 |
I always park in neutral.
I always park in neutral unless on a hill.
My bike's been parked too long with all the rain we've been getting. It's clean though... and in neutral.
Posts: 96 |
Always park facing uphill, then neutral, gas, switch.. my left hand just goes to those automagically. Never used the kill switch. I have had to shove bikes backwards uphill, hence the up-facing parking.. lots easier to coast down. If it's steep enough to slide back against the kickstand I find a better place to park.
ride when I can, work when I have to
Posts: 282 |
Neutral. Easier to start and I like to pre-warm. I can get geared up while the bike is warming and don't have to be on it.
Pacific Blue/White 2009 America in the TX Hill Country
Not all that glitters is gold. Tolkien. Hmm Must've seen the chrome on my TA coming down the road.
They must be tired from doing that crotch rocket mating dance as seen in the video in the Lounge...
Posts: 12,164 Likes: 1
Posts: 12,164 Likes: 1 |
In gear.
Posts: 8,639 Likes: 3
Posts: 8,639 Likes: 3 |
I always park everything in low gear except cars that don't have a proper gearbox go in park. The only time I park in neutral is when I need to because I am going to work on it. It helps ensure that the bike is where it belongs next time you go to ride it. Even living here where it is so flat you can watch your dog run away for three days I always park in gear.
...Even living here where it is so flat you can watch your dog run away for three days...
Posts: 4,518 Likes: 32
Posts: 4,518 Likes: 32 |
Always in gear (as with a handbrake). In fact I use the stand as a kill switch (in gear). It's a routine I have followed (on the bikes that have the kill feature when in gear and sidestand is extended) over the years - it always ensures I put out the stand.
Bedouin.
Blessed are those eyes that have seen more roads than any man! (Homer).
This, I like!
Posts: 6,681 Likes: 1
Posts: 6,681 Likes: 1 |
The MSF beginner mc course teaches you to put the bike in gear when it is parked(so my son says). Mostly that's what I do.
Posts: 2,726 |
I usually leave the bike in neutral on level ground unless it's on a ferry.
Bob
Yall could over anal-izing this whole parking thing.
Edgar Allan Poe
Ok, you win something positive and constructive about parking a bike. My friend parked his bike and left the key on, he killed the motor with the switch. He was lucky he didn't get it stolen, but when we came back his battery was dead.
Edgar Allan Poe
Edgar Allan Poe
Posts: 1,502 Likes: 7
Posts: 1,502 Likes: 7 |
I didn't realize it started in the military but I'm not surprised. I've only ever heard bikers use it.
FNG is the official title of the newbs on a traditional hot rod forum I'm a member of. Until 50 posts or something like that. But yeah, it's a military term, and it sucks being the FNG there.
Posts: 3,937 |
Apparently, it's not much better here.
J. Prine
Dude have you seen other forums? This place is a cakewalk.
This one is very easy to use.
Don't know why I'm a FNG.
Edgar Allan Poe
Didn't say YOU were. It's not always about you.
keep watch the following videos.... thats one hell of a road.
Edgar Allan Poe
