Re: Maiden voyage
Keith #427757 02/26/2011 10:20 PM
Thanks Keith. It's been a real tail chaser. I ran seafoam today and it does run better. I'm going to get the fuel filter on and clean up the carbs again and am thinking I might have to invest in a carb tune.
Of course I can't actually ride because it's all snowy but running thru the throttle it doesn't pulse like it did. But that was a quick check. Like Ian was saying I was a little worried about over heating because ilet it run for about 20-30 mins to work the seafoam through.
Re: Maiden voyage
08America #427758 02/26/2011 11:02 PM
Well let's hope the seafoam did the trick! After all this is over might I suggest you go see a Chiropractor... yer bound to have a kink or two in your neck by now, lol!
Re: Maiden voyage
Keith #427759 02/26/2011 11:33 PM
Ha. You know what's funny is I just iced my neck because it hurts and I'm chasing that with a grey goose and cranberry. Just what the doctor ordered right buddy!!
Re: Maiden voyage
08America #427760 02/26/2011 11:39 PM
That IS funny... best to ya Brett!
Re: Maiden voyage
08America #427761 02/27/2011 8:26 AM
When you winterize it, did you let the stabilizer run thru your carbs a little bit, or did you, >"My usual winterization routine is Shell V power 93 octane with stabil, shut off the petcock and let her run until she drains the carbs."< My thinking is that you might of had some residual fuel that "varnished" in the bowl/fuel passages/jets, Let the Seafoam work its magic, gently shake the bike/carbs back and forth for a few days (not continually) and try starting it to let the gas run through the carbs while changing throttle position
Re: Maiden voyage
Two_Wheel_n #427762 02/27/2011 10:55 AM
Aha Steve. Now we may be onto something there. Because I don't let the stabil run thru. I just added it and drained the bowls. And it was better with the seafoam. I'll try the shaking trick and running it more. when I twisted it thru she would keep running at full throttle. Then as I let off it back fired a little. But definitely better. I'll let you know after a few days of seafoaming.
I have seen it before where guys have made manometers but I'm a bit skeptical about how accurate that's going to be. If I bought a carb tune realistically how much would I use it??
Re: Maiden voyage
08America #427763 02/27/2011 12:57 PM
...If I bought a carb tune realistically how much would I use it??
If you have a few bike buddies that live in your area, You can split the cost and pass it around when needed, as long as your buddies respect tools, all SHOULD be good! or buy it out right and get a few beers for its use!
Re: Maiden voyage
Two_Wheel_n #427764 03/01/2011 9:54 PM
Well dang it JR I is making me look bad he fixed his kickstand switch and is up and running. Here's my progress or lack there of I have run sea foam thru a few times and she runs good at idle and throttle blips. But if I hold it WOT it pulsates with a backfire. So it's kind of a vrooom....dying....pop...vroom repeat over and over. I'm sorry guys that's pretty bad. Could this be a float issue? Seems like a main jet issue. Should I get new? I've cleaned them. Would carb tuning help this? I'm totally lost!
Re: Maiden voyage
08America #427765 03/01/2011 11:12 PM
The way you describe it it does sound like a fuel issue. Like it runs out then the flow catches up then it runs out again. That is not to say that it isn't an ignition issue but the way you describe it it sure sounds like fuel. Dirty petcock maybe? Bad tip over valve? Clogged vent? Float issue?
When cleaning jets don't even push wire or paper clip through them.
Re: Maiden voyage
The_Dog33 #427766 03/01/2011 11:33 PM
I live in the sun downunder
+1. Excellent advice.
Re: Maiden voyage
FrankW #427767 03/01/2011 11:40 PM
OOPS! I meant don't ever.
Re: Maiden voyage
08America #427768 03/02/2011 12:23 AM
I didn't go back and read the whole thread but did you check the spade connectors on the coils? Reason I ask is they were very loose on my bike and prone to coming loose, causing all kinds of erratic running conditions.
Dang, I'm getting really frustrated (I'm sure a lot of us are) with your bike... I can't imagine what it must be like for you!!!! All you did was park it!
Re: Maiden voyage
Keith #427769 03/02/2011 7:40 AM
Oops I did do a paperclip thru the mains. Won't do that again!! What is the spade connector on the coils?
And how do I check ignition issues. Just kind of getting ideas on possible fixes.
Last question-for this post anyway-how fast do the bowls empty. I mean like 5 seconds or 1 min kind of ideas. Was a curiosity question there.
Re: Maiden voyage
08America #427770 03/02/2011 11:13 AM
Those connections on the left there. They were very sloppy on my bike and prone to coming loose.
Re: Maiden voyage
08America #427771 03/02/2011 5:56 PM
It depends on how far you turn the "stop" out. If you just crack it, it could take 5 min. but if you turn it out a couple turns,~20 seconds(just like a faucet)
Re: Maiden voyage
Two_Wheel_n #427772 03/02/2011 6:12 PM
Bret,
For my own peace of mind.....could you please drain some fuel from the bowls for at least a minute to see if you have good fuel flow. All you need to do is open the screw at the bottom of each bowl and let it flow. If it flows well, it means everything (petcock, inlet screen, hidden filter and fuel lines) is clear to the carbs.
4th request. If you have done so, let us know.
The bowls shouldn't stop flowing so long as the fuel is turned on.
Re: Maiden voyage
Gregger #427773 03/02/2011 10:24 PM
Gregger, I'm sorry I didn't answer you the first three times. I did open the bowl drain and the fuel flows constantly out with the petcock open.
Again I'm sorry for the lack of communication only part.
Re: Maiden voyage
08America #427774 03/02/2011 10:35 PM
Thanks Brett. Wanted to get that clear before we moved forward.
Next test is to determine your float height. An easy check is to fit a clear plastic tube over the bowl drain then hold the tube beside the carb body, open the drain. The tube should fill with gas and stop just below the top of the bowl. Both sides should be the same.
Re: Maiden voyage
Gregger #427775 03/03/2011 4:54 PM
Checked the float height and both sides look equal at the top of the bowls. Also checked out the ignition coil that would appear in good shape and well connected. I pushed all the wire junctions I could find together. also poured about a cup of gas on my garage floor because put petcock on reserve instead of off. So safe to say tipoff is not pinched!
Re: Maiden voyage
08America #427776 03/03/2011 6:44 PM
Plugged vent tube?
Re: Maiden voyage
Keith #427777 03/03/2011 6:52 PM
Is vent tube different than tip over tube. The tube that hooks on to the right of the tank-correct?
I revved it up and popped a filter off. If that helps. When it backfired it came off. I'm also having an old motocross buddy come look at her on saturday. He knows a good bit about carbs etc. Used to race for Honda.
Re: Maiden voyage
08America #427778 03/03/2011 7:13 PM
So it looks like your float adjustment is ok. Fuel to carbs is ok. Try pulling out your choke (enrichener) to see if the extra fuel makes things better or worse. Then your going to blow out the fuel circuits with compressed air.
BTW - you stated that the engine cuts in and out at full throttle. It that under load while riding or in neutral. The reason I ask, is it possible you are reving the bike above your rev limit in neutral and the limiter is kicking in? You stated you don't have a tach.
Re: Maiden voyage
Gregger #427779 03/03/2011 8:22 PM
Hey great call Gregger. That is in neutral. I haven't check her under load because we are still pretty icy here. But it does backfire and dye out. And I dint know what they rev limiter at neutral sounds like. Never tried it honestly. I'll try pulling the choke and see if that makes it better. I'll report back
Re: Maiden voyage
08America #427780 03/03/2011 9:35 PM
There's just one hose (vent or breather hose) which has a one way valve near the end. Sometimes the valve can stick and effectively block the breather line. However, a good way to check for that kind of problem is to run the bike with the cap loosened off... if it runs better then the hose could be blocked.
Re: Maiden voyage
Keith #427781 03/05/2011 10:07 PM
So not to drag this on forever and be a thorn in the side but feel like I'd be remiss if I didn't follow up. I tore the carbs apart again and looks like the vacuum diaphragm was seated poorly. I made the mistake of using carb cleaner on them and they got the rubbers all stretched out. So I have them is inside hoping they will shrink down a little so I can fit them back in that ridge to get a good seal. Also have a local guy looking for replacement parts and prices (to compare to bikebandit). If you live around here you have to see this guy he is the best. So hopefully in the next week I'll have more solid answers and we can move on to conversations like what kind of coffee is Keith brewing that is best this side of the Rockies. And what is Gregger doing with his grandkid.
Re: Maiden voyage
08America #427782 03/05/2011 10:11 PM
I look forward to that, but probably not NEAR as much as you!
Re: Maiden voyage
08America #427783 03/05/2011 10:20 PM
Brett, since you brought her up,
We went out to the mall today (The Saturday routine) where grandpa let her have several rides in the kiddie section, went into the pet store to look at the rabbits, guinea pigs and birds, then off to food court for her favourite......French fries and ketchup (along with a chocolate milk). The ketchup has to be in those small single containers so that she can dip each fry in.
She lets me eat only the fries she doles out to me...I love it.
Re: Maiden voyage
Keith #427784 03/05/2011 10:21 PM
Be fore warned that bike bandit is very slow to ship.
Re: Maiden voyage
The_Dog33 #427785 03/05/2011 10:27 PM
So Keith not devulging any secret hey?! Haha. And Gregger sounds like somebody gets a little spoilling from grandpa. Good for you buddy that's the joys of grandparenthood. Wow is that a word? And finally Ian (like the Wizard of Oz-and Scarecrow I'll miss you the most) I saw bikebandit was slow to ship. Hopefully my local guy will come through. I might have to buy the whole slide if I go thru bikebandit.
Re: Maiden voyage
08America #427786 03/06/2011 10:49 AM
bandit taint slow, it is Newnan, Ga that slows the bandit up. For OEM parts anyways. Tires get shipped next day. Don't forget about the bandit's 10% AMA discount.
Anyway, if you need new slides, the bandit list them at $68/VACUUM PISTON, 3mm HOLE, KEIHI "VACUUM PISTON, 2.5MM HOLE"
Whereas Pinwall has a set of carbs for $99.99. diaphragms for thought.
Re: Maiden voyage
moe #427787 03/06/2011 1:00 PM
Yeah Moe I saw that on eBay and was wondering what the opinion of that was. I think they were 2003 carbs. Think vacuum gaskets would still be ok etc etc. ?
Re: Maiden voyage
08America #427788 03/07/2011 12:25 PM
Yeah. Or wait for some fresher carbs to appear. However I bought a set a ways back and looked at the slides last year. They were fine.
Re: Maiden voyage
moe #427789 03/13/2011 8:30 PM
I'm big on closing the loop. Turns out I had a stuck left slide. And when I pulled it apart to unstick and clean I didn't get a good seal on the rubbers of the vacuum slide. I put it in the freezer for a day and it shrunk down and fit perfect., because I sprayed carb cleaner on it it swelled all up. Took her out in the 35 degrees and ripped around the neighborhood with no more hesitation.
Let me take a moment to thank everybody that helped me and I apologize if this was frustrating at times. I appreciate all the input and adivice on this forum. It is my first resource for any problems. Hey maybe I should make that a quote on the suggested forums quotes John
Thank you all for you're help. You make owning an America even cooler!!
Re: Maiden voyage
08America #427790 03/13/2011 8:57 PM
Thanks Brett for keeping us informed. We all learned from this one.
Re: Maiden voyage
08America #427791 03/13/2011 10:56 PM
Glad you got it sorted out, Brett and thanks for letting us know. As Greg said, we all learned from this one.
Agree with you that this place makes owning an America even cooler!!
Re: Maiden voyage
Keith #427792 03/14/2011 8:41 AM
This is the 2nd time I can remember on here that we had these similar symptoms and thinking float...vent...etc... and it turned out to be the slide.
