procom cdi (ecu0
#379958 03/09/2010 8:49 AM
replaced my ecu with a new promcom cdi result = bike turns over but will not fire
2005 america
any thoughts or ideas??
Re: procom cdi (ecu0
paulypfr #379959 03/09/2010 9:51 AM
Different starting with the procom imho.
fuel on
choke in
Turn key on
engage starter
while starter is spinning motor, pull choke out 1/2 to 3/4 way.
No go?
Repeat from choke in point
paulypfr #379960 03/09/2010 12:39 PM
I have been really suprised at these hard starting reports.
I have never had this problem.
I start with full choke, fires right up, just like normal.
I will add, though, I never used the baseline Procom ignition map,
I used my alternate one from the beginning.
What map are you using?
BrianT #379961 03/10/2010 3:23 PM
This is mine and I get starting problems, I can get it started though.. and when it runs. man it runs.
Cant remember whos this map was, think I got it off here or the procom site.
TrOjAn
moe #379962 03/12/2010 10:18 AM
hi got trouble with bike cutting out when reaching rev limit would putting a procom cdi on my bike ba 02 allow me to alter rev limit? thanks kevin
lowered 2 in stretched front ,widened front forks, aubergine black pearl paint 40 ford rear light standard exhaust all baffels removed, pods, 155 main, 45 pilot, thruxton needle, 16 tooth sprocket procom ignitor set to no 5
3spirit #379963 03/12/2010 10:46 AM
yes it will.
roadworthy #379964 03/12/2010 2:10 PM
Getting back to the thread, I am thinking now that if I start the ramp up from 1000 rpm instead of from zero that may?? help the starting, I will reprogram Sunday and check out the starting.
My thinking is this: as the bike turns over at x rpm the CDI unit is advancing the ignition while its trying to start (needs retarding).
Anyway, Ill try and post back.. we need to nail this bad / non starting issue asap
This is the next one I will be trying.
TrOjAn
TrOjAn #379965 03/12/2010 6:25 PM
Terry,
Could you post the stock profile?
I'm confused with the chart. Is it showing a maximum advance of just over 3 degrees at 5000 rpm? Seems low?
Gregger #379966 03/12/2010 7:20 PM
Gregger-
The map he posted shows the change from the Procom
baseline map. Not the total advance.
BrianT #379967 03/12/2010 7:34 PM
Thanks Brian....makes sense now.
Gregger #379968 03/12/2010 8:39 PM
got the bike to run with a lil help from procom,,,thanks to all you guys for the good info...time to ride finaly!
Gregger #379969 03/13/2010 7:28 AM
Yes BrianT is correct.. HOWEVER!!!
The real pain in the butt is, whats stock?
According to Procom the Stock Map is the same as the default Triumph one.
Gregger, I have to admit timing is major bug bear of mine... wish everything started as ZERO then we could work from that, anyway, the NEW maps I have have a larger advance and are completly different to what we have been playing with..
It appears to em that these small 3 degree advances are our "lets tweak but be careful" approach.
I have sent the maps to about 10 people so between us we should be able to narrow down a decent map.
TrOjAn
TrOjAn #379970 03/14/2010 8:42 AM
Is there some way that the built in advance from Procom can be mapped?? On "older" cars you just point your timing light on a degreed balancer or have a "dial back" timing light. Is there some place to put a degree wheel on? or have/make an inspection hole in the side cover? Does Procom hold their timing advance as "TOP SECRET"? Can BA.Com ask them?(strength in numbers)
I know, more questions, no answers, so sorry.
paulypfr #379971 03/15/2010 8:22 PM
funny you should write that. Just today i recieved my new procom and installed it in my 2005 TBA. Same results. Cranks but no fire. I tried the choke thing while cranking. Nuttin! Pulling whats left of my hair out!
virtualinsanity #379972 03/16/2010 6:37 AM
With the new maps its a bit better to start.. however it is different to how it used to be...
I just pull the choke out and hold clutch in and press and hold that starter button untill it bursts into life, once running getoutta my way baby cause Im moving.. yeeeeehaaaaaa
TrOjAn
TrOjAn #379973 03/16/2010 9:34 AM
Which map do you have uploaded currently?
From a reply to Matt, here are some notes on the new maps--->
Procom released 9 new maps.
Beginning Rider Maps
Medium-level Riders Maps
Advanced Riders Maps
Each skill level has three maps. A map for a bone stock machine. A map for a machine with Minor modifications. Lastly a map for a machine with General modifications.
moe #379974 03/16/2010 6:19 PM
Well I contacted Procom. I was instructed to set the ecu to #4. The bike now starts but wont run right. I used the map downloads, and tried different ones.They dont seem to make much difference.Lots of backfiring. I had the bike in the shop last year for this problem and after almost $400.00 they told me the prob seems to be the ecu.I didnt have them put one in because Triumph gets more that $600.00!! I am beginning to think they misdiagnosed the prob in the first place
virtualinsanity #379975 03/16/2010 6:52 PM
Backfiring doesn't necessarily mean the CDI unit. It might but there are a lot of other items that should be checked first before putting out that kind of money. Have you done anything to the bike in terms of modifications? Have you checked the intake system rubbers and vacuum caps closely for cracks? Do you have your idle mixture adjustments screws set properly (turned too far in will give you backfiring)? When were the carbs balanced last? Have you checked your spark plug colour?
When does it backfire? While idling, steady running, accelerating, decelerating? Makes a difference in diagnosing.
Gregger #379976 03/16/2010 7:09 PM
The bike has aftermarket pipes and has been re-jetted. When it was in the shop they also eliminated the air injecton parts. After I bought the bike I put about 4500 miles on it, trouble free.I tried everyones suggestions on here before I finally gave up and took it to the dealer.I can only assume that they checked all the obvious things, but I dont know for sure.
virtualinsanity #379977 03/16/2010 7:14 PM
The bike backfires when I try to give it throttle. It wont rev up freely without popping and backfiring
virtualinsanity #379978 03/17/2010 3:03 AM
I bet somebody here can help straighten it out for you. It might take a week or three of trial and error & posting, but there are some very mechanically talented folk here.
virtualinsanity #379979 03/17/2010 7:30 AM
Don, I just re-read these two threads. Dang man. Troubleshooting April 06, 2009
pulling my hair out April 14, 2009
glaringly...
I wonder if anyone can help me with a troubleshooting question. I have an 05 America that started running crappy last fall before i put it away for the winter. It started out as a hesitation when you give it the throttle. It has gotten progressively worse and now backfires as well. I checked the plugs and air filter.Also ran carb cleaner through it. Cant figure it out. Any help is appreciated. thanks,Don
That really sounds like a bad coil. not coils. So, given all you have done since almost a YEAR ago, have you tried installing a new or at least a known good used ignition coil?
AND it wouldn't hurt to pull and clean the carbs, including the diaphram side of things.
Fuel or lectrics... The timing light trick tells ya lectric. a test for fuel problems: when the symtoms exhibit, pull the choke out. If they go away odds are ya got a fuel issue.
BadCoil. Again, have you tried installing a new or at least a known good used ignition coil? One should be all you need. If after install the symtoms are still present, install the coil on the other side. ALSO check your plug wire(s). Simple ohm check on those. There are checks using a meter on the coils. The primary side is explained in Haynes. Maybe some of the members here that are more versed in electron flow can chime in.
Hang in there. Lets see if we can get you hooked up with a member local to you so you can troubleshoot a possible coil issue.
virtualinsanity #379980 03/17/2010 11:52 AM
OK 2 things here... you say your on #4 on the cdi unit?? might want to double check that (post your original part no)
2nd, I would go with coil.. the reason I say that is I have had it happen twice now and I went through EVERYTHING!! even bought 2 replacement carbs, checked the shims, the air gap the lot.. you name it I did it.. bought 2 2nd hand coils and it ran like a dream.
2 weeks ago, got the same issue, this time swapped out the coil for a spare I had, running like a dream.
I have now in my possesion 3 PVL coils, they are slightly larger but as I now had had 2 right hand coils go on me I am trying anything.. when I locate a dealer that has the nology coils in stock Ill get them.
Good luck
TrOjAn
TrOjAn #379981 03/17/2010 2:30 PM
pvl are exact coils Nology is selling with nology stickers on them
Grzegorz #379982 03/17/2010 3:51 PM
The number on the Triumph ecu looks like 1291100. The label is worn and the numbers are hard to read. The tech support guy told me to use setting # 4 based on that number. I havent tried another coil myself but the shop said they tested it. I dont have much faith in the Triumph dealer here.
virtualinsanity #379983 03/17/2010 5:11 PM
You can test the coils with an ohmmeter also. Check positive to negative on the primary side. Should be relatively low values. Probably just a few ohms. Then test from the positive or negative to the main secondary output. Should be several thousand ohms. Compare the values between the coils.
Note, this is not a perfect test since the resistance value on the secondary side could break down with the high voltages. A megger would be the proper device to check the secondary side but this isn't something most fellows own.
Gregger #379984 03/18/2010 6:16 AM
imho the ohm check will not reveal an intermittent failure. for what ever reason the coils seems to fall in and out of grace, every so much further, over time, into hades.
from the haynes manual (PURCHASE ONE), Chapter 4,
"10. the coils can be tested in situ. Pull the cap off the spark plug for the coil being tested.
11. Measure the primary circuit resistance with an ohmmeter or multimeter as follows:
Disconnect the primary circuit wiring connectors, noting which fits where—the red wire goes to the positive (+) terminal on the coil. Set the meter to the ohms x 1 scale and measure the resistance between the terminals on the coil. If the reading obtained is not within the range shown in the Specification, it is possible that the coil is defective.
Primary winding resistance ………approx. 6 ohms @20degreesC
12. Measure the secondary circuit resistance with a multimeter as follows:
Set the meter to the K-ohm scale. Connect the positive (+) meter probe to the contact in the spark plug and the negative (-) probe to the primary circuit terminal for the red wire. If the reading obtained is not within the range shown in the Specification, it is possible that the coil is defective. .
Secondary winding resistance ………approx. 15 K- ohms @20degreesC
13. Before buying a new coil, pull the HT lead out of its socket on the coil and measure the resistance of the lead and cap by connecting the meter probes between the HT lead end and the spark plug socket in the cap. .If the reading is not as specified, replace the spark plug cap with a new one.
If the coil is still suspect, substitute it with one that is known to be good before condemning it. If the problem still exists, then the fault is probably in the primary wiring circuit see chapter 8.
Spark plug gap resistance……approx. 5 K- ohms @20degreesC
Notice the words used when coil meter readings are outside the specs: IT IS POSSIBLE THAT
Whereas for a spark plug wire outside the specs: REPLACE
virtualinsanity #379985 03/18/2010 6:24 AM
and Cerberus is snarling, thrice over, at one of your coils...
moe #379986 03/18/2010 8:55 PM
imho the ohm check...
If that isn't already in the vault then it ought to be.
B02S4 #379987 03/19/2010 3:09 AM
Yep, I have 2 Gil coils here that pass the dreaded Ohm check but they are fubar, run ok at over 3000 rpm but below it misfire like a nutter.
Get a 2nd hand coil and try it...
As for PVL are same as Nology?? are you sure? they may look the same but 2 different companies.. would be very surprised if they are identical.
TrOjAn
virtualinsanity #379988 03/19/2010 6:12 AM
... I havent tried another coil myself but the shop said they tested it. I dont have much faith in the Triumph dealer here.
http://cgi.ebay.com/ebaymotors/07-Triump...=item1e5afb46c9
moe #379989 03/19/2010 12:39 PM
Thats just too cheap :P, just paid 3 times that on a used pair... I need to move over there... anyone wanna put me up
TrOjAn
paulypfr #379990 03/19/2010 1:22 PM
So I just got my new Procom CDI, I have a big bore, freak, and septers. I was looking for some map suggestions or is it just trial and error?
TrOjAn #379991 03/19/2010 1:27 PM
Nology source their cols from PVL, just badge engineering.
PieMan #379992 03/19/2010 1:36 PM
Nology buys bulk of coils from PVL put their sticker on, makes nice looking packet ............ AND I'M SURE I know what mark is on my coils
Grzegorz #379993 03/19/2010 1:42 PM
Pieman, Grzegorz,
OK, I am convinced.. in that case Ive had a right result, I have 3 of the pvl coils..
I wasnt trying to say your wrong btw, it just seemed like the pvl coils are widely available and theres no nologies anywhere
Thanks,
TrOjAn
Mlessard #379994 03/19/2010 1:44 PM
Try map No: 9, its the most advanced / modified apparently.
I am running No: 6 atm but will try No: 9 later.. No: 3 was really nice, No: 6 is different, wont say better, so looking forward to trying 9.
Report back on your findings.. remember its harder to start usiung the procom
Here is the link to the maps download in case you dont have them: Procom Maps
TrOjAn
TrOjAn #379995 03/20/2010 5:40 AM
who do I order a procom cdi , for the best support?Rudyr
majorruddell #379996 03/20/2010 3:08 PM
Get it right from the manufacturer.
Procomeng.com
TrOjAn #379997 03/20/2010 3:51 PM
ok thanks a lot brother! So since I cant seem to get my instruction cd to work, I just wana double check, I turn the number on the bottom to match my SN, then program map number 9 in, plug and run? almost seems to simple..
