 Re: Lets see them....cutom builds
Posts: 103 |
 Sprocket & rocker cover yet to be done, and a few other bits. Goldie silencers etc
Posts: 99 |
.....I know the key to a well rounded education is, EXPERIMENTATION......
Posts: 103 |
Girders
Posts: 103 |
Does the top pic have America bars on, looks like speedie bars on the lower pics. You going to be using struts on it ?
Posts: 110 |
I like this one. Very nice!
That z-bar (or what ever it's called) is so cool. Does it fit with stock cables? Wonder where I could get one?
Posts: 99 |
To answer borgcymru's question about the middle bike on this page (red tank). Those are custom Harley drag bars w/4 1/2" rise--25" width....had to drill out top tree for these bars to fit, Harley bobber grips, so had to cut out control for the throttle grip to fit, plus readjust cables because the grip is thicker....add not using fender struts, cut of that part of frame and will be cutting of the upper shock mounts as well.
Posts: 103 |
Ahh right, no didn't mean 'fender' struts, mudguard supports over here  Meant a solid bar type thing instead of rear shocker, a sort of hard tail effect. I ask because I noticed the rear guard/fender is fixed to both the frame under the seat and the swinging arm
Posts: 99 |
Ahh..gotcha, yes right now it is bolted under the seat cross bar and to the swing arm...that was a quick add just for support so I could run it..I will change it when I put the mono shock in...actually, the bracket I welded for the swing arm has a mount bar welded infront that goes across the fender...I will add another support so I can make it strong enough for a passenger
Posts: 103 |
Your doing a mono shock soft tail mod, cool been looking into that for the next thing myself.
Posts: 99 |
Yeah, going to use air ride for adjustment..got rid of the fender struts because I like the clean open look...so everything has to be hand made...but we do it because we love it...I have a thread under custom--" time for change- project" that shows a lot more..lost pics on first couple pages, but put them back on plus updates
Posts: 2,420 |
Your bike is sweet, Paul. I was wondering if you remember where you got your axle spikes...
Posts: 311 |
With thanks to all the folks on here for being able to copy some of their ideas, finally got my battery relocation done. Pics are poor, sorry, sun in the UK in April wasn't expecting that one.     Hope someone likes it. I do.  Cheers Chris
All the best
Chris
Do it today - tommorrow it may be illegal.
Posts: 251 |
Hmmm...  Long Fender, or Short... Which looks better ??
Mike.
Veho Liberate
Iustus Paratus Prohibeo Penuriosus Effectus
Posts: 3,210 |
I like long smoothed out fenders myself but I'm kinda biased
Posts: 99 |
Goes in for paint and finish next week...can't wait..going to fit a 21" front wheel this week end see how it looks..
Posts: 103 |
Can you get some close up build shots of the mono conversion please ?
Well I sure like it Chris Fawcett. From what I can see you really got it right from the carbs on back. Nice going!!!
Wouldn't it be cool if you could get that part of the frame that sweeps back underneath the seat to meet with the part that comes up from below at a point? Ya know what I mean? Right in front of the spring on the seat... right there. Have that juncture come to a point. Watcha think?
Posts: 311 |
Very formal Kieth, not been called that since school or my boss when I've messed up. Thanks for the comments though, Cheers Chris
All the best
Chris
Posts: 1,498 Likes: 7
Posts: 1,498 Likes: 7 |
Yes to what Keith said, and add a back rest/sissy bar connecting to two ends !!
Posts: 99 |
There are more pics of the mono mount here...look under "general discussion>>custom ; and then "time for change, project" or my photobucket... my 07 America album
Posts: 3 |
Hello! Today I bobbed my rear fender but it looks bad in my opinion. There is to much space between the wheel and the fender. Now I want to buy a pair of Hagon shocks but I don´t know in which length. Has anybody a tip for me? Are 11,5" shocks low enough?
Posts: 144 |
If 11.5s are an inch under stock (which I think they are), I wouldn't go any lower than that. I have a set of Progressives that are an inch under and a new back tire rubs the fender just slightly over hard bumps. It's not enough to go back to stock but I'd hate to see what 10.5s would do. It also might be the Progressives and the amount of travel they have. I haven't heard of anyone else rubbing the fender, so it might be my shocks.
you should be able to do a little searching on here and find some more info on what people are running and how they look.
Don't forget the bike will handle differently.
Good luck and nice start.
Posts: 1,883 |
Hello!
Today I bobbed my rear fender but it looks bad in my opinion. There is to much space between the wheel and the fender. Now I want to buy a pair of Hagon shocks but I don´t know in which length. Has anybody a tip for me? Are 11.5" shocks low enough?
The BellaCorse E-Bobber used 11.5 hagons. I think it looks awesome.
~Brent
~Brent
Posts: 99 |
If you can choke the cost...go with air ride..the standard Harley is 11.5 and will allow You to go another 1 - 2 inches lower...most are just 1"(so 11.5" - 10.5")
Posts: 853 |
If you use the Harley shocks they have to be shimed. I got a 0.032" plate from Ace and made shims that go between the mounting stud on the bike and the shock.
Posts: 853 |
Oldgimmer:....Nice bike....could you take a picture with the seat off showing how you put all the wire under the seat....I am faced with that problem now...
Posts: 3,210 |
You dont necessarily need air ride, my stock shocks with cut springs are 10-3/8" with no rubbing.
Posts: 3,210 |
Heres my wiring when I first did it
Posts: 1,284 |
I have progressives, 10.5" as well as 2" lowering kit in front - no problems.
Strangler
Posts: 311 |
Sorry its been a while to reply mate, heres what I did.  As you can see from Brokenfixed and all the others on the other threads everyone has probably done thirs differently. IMHO I think the main problem is where to put the starter solenoid which is the chunkiest part. If you can put that somewhere else it gives you a lot more room under your seat. Goodluck Chris
All the best
Chris
Posts: 853 |
Thanks...what you have is something like I was thinking...mount the starter sol. elsewhere and mount the fuse box on the end of the frame tube.
I spent Sunday working on the front brakes...making a one line in to two lines for dual disks.
Posts: 251 |
Matchboxracer, When I bobbed mine I felt the same... A set of 11" shocks (26kg springs) were the way... Travel reduced to 40mm and a progressive stop/bump rubber put in. Never dragged the fender, haven't made any mods to chainguard etc..(rider and lots of luggage only)..
Mike.
Veho Liberate
Posts: 144 |
Well, I'm sorry to say that tomorrow she'll be in someone else's hands but I think it will be a good home. I was just getting it where I wanted too...  More pics here:http://www.flickr.com/photos/28732891@N03/?saved=1
Posts: 363 |
Battery relocation with KNs, signal relocation, corbin seat, mirrors, fork gaters. I am done for the summer, so I can ride other than gutting the TORS. Next winter I plan to lower it, wide wheel kit with a 200 tire on the back and a bigger front tire, bob the rear fender, different bars and grips, and some more chrome. I am lovin it so far!
Posts: 99 |
New color...only did the tank to see if I like it...Mercedes charcoal Will be adding a Honda blue design to match my tribal tattoo on both the tank and fender...
Posts: 2,150 |
Dennis, hat's off to ya. Surely you've put yours into a comp or two haven't you cos I haven't seen a bike that suits my eye like that for some time. thankyou stacka
Posts: 1,883 |
That is looking really good. I don't blame you for waiting for winter, I'm doing the same thing right now. Rather ride than wishing it were done 'cause that's when the weather will get nice.
~Brent
~Brent
Posts: 334 |
Pics of my 06 Speedy. [image]  [/image] [image]  [/image] [image]  [/image]
Posts: 325 |
