Re: Step by step baffle removal instructions
FriarJohn #287467 09/03/2009 6:43 PM
As contributions go, that's a pretty good one...
I have to agree, best way to let people know what's in there I have seen. It has been explained over and over but that leaves no doubt.
Dupre97 #287468 10/29/2009 10:17 PM
I'm having problems pulling up your pic's. Would you email them to me?
PersonalTriumph #287469 11/24/2009 5:35 PM
BLT Offline
Is there a trick to viewing the photos in here, all I can see is red X's.
Thanks
Ride more, worry less.
BLT #287470 11/24/2009 6:58 PM
the link is probably broken, or server issues on those pics
roadworthy #287471 11/24/2009 7:22 PM
BLT Offline
Okay thanks.
BLT #287472 01/13/2010 7:48 PM
http://members.optusnet.com.au/~matt_l/exhaust.htm
Web site from NZ that shows the baffles extracted and the sound you will get.
SMJoe #287473 01/14/2010 7:35 PM
Hate to contadict... but when I went to the house of the owner of that site, I was in Australia!
But that's how I learnt to remove baffles... from Matt's site.
GinaS #287474 05/07/2010 5:39 AM
I just removed all the baffles from my 2005 America stock pipes... Did loads of research on here and elesewhere, reading about hole saws, extenders, hooks etc...
I just took the cans off and beat the living sh*te out of them with a half inch across 5 ft pole
Very quick, precise and quite effortless. Regardless of what you hit first wether its the tube or the plate welded to the sides.. it all shifts after a few good taps... 10 mins each can.
They do sound really purdy now
gremmann #287475 05/24/2010 10:47 AM
My neighbor gave me his slash cut pipes off his '05' and I took 2 of the 4 baffles out. YES 4 are in there. Anyway, it sounds great. Not too loud, nice thump. Having said all that, I don't think taking just 2 baffles out should make a hairs difference in jetting. I know their pretty lean from the factory, but I can't believe that they are THAT fine tuned. OK, so I'm going to call my dealer tomorrow and make sure. Will keep you informed. BTW, runs great too!!!
How did you do it? Can you post instructions, or is it the same? Any sound or video?
PersonalTriumph #287476 05/24/2010 6:16 PM
My picture links don't work anymore, and I can't seem to edit the original post, so I'm reposting in its entirety with new links to the pictures. I no longer can locate the audio file, sorry 'bout that guys.
I took out my baffles today. It took two hours total, but it was hard work. Extremely frustrating, confusing at times, grueling hard work at times, painful at times (my bruised hands are testimony to that.)
Because this is a subject lots of folks are interested in, I’m posting step by step instructions with images to help a bit. I hope that the Bonneville America community finds this helpful.
I used a 1 3/8” hole saw to cut into the baffles from the rear of the pipes. This was the easiest step of the process, but required a trip to Lowe’s to get the hole saw. Make sure your hole saw cuts metal. The one I bought at Lowe’s cost $10 and worked like a charm:
The pipes looked like this when I started:
And like this when I was done with this step:
NOW the fun starts. If you read other posts on this message board, it sounds like you can just wiggle the baffles and whack the welds them with a screwdriver and they’d pop out. This was NOT THE CASE for me.
Wiggling them back and forth started the process. The hardest part for me was finding an appropriate tool to crack the welds. The biggest screwdriver I had was not long enough to reach the welds. I looked around my garage and found these huge nails. I mean huge. Here’s a picture of the nails next to the baffles and a ruler. You can see that whatever you use to crack the welds has to be at least 8” long:
I used a combination of wiggling the baffles back and forth with a pliers, banging the nails through the welds and the inner bracket, grabbing the baffles with a vice grips and pulling, banging the nails through again. Ultimately what worked on one of the baffles was putting the sharp side of a chisel inside the baffle and banging on the other end with a hammer. This pushed the baffle into the exhaust pipe and finally broke off the weld. The second one came out due to twisting with a vice grips.
At the end of the process I was exhausted, sweating, and my hands were hurting, but when I turned the key and pressed the ignition button, it was all worth it. WHAT A DIFFERENCE! The new and improved exhaust note exceeded my expectations a hundredfold. I was planning to have an aftermarket exhaust installed to give the bike a more masculine sound, but no reason to do this now. I would describe the new and improved exhaust note as warmer and richer. I also have a digital audio file of the new sound. If someone can tell me how to post it, I’m happy to put it on here.
These are all the tools I used:
Here is how my pipes look now:
Hope this helps! If you need any additional info, let me know.
Joe
PersonalTriumph #287477 07/28/2010 2:40 PM
Have taken out 3 baffles love the sound but a bit loud do i need to rejet and what size jets, sorry if this has already been posted
thrape #287478 07/30/2010 5:41 PM
First of all, welcome to the forum. To answer your question, you should rejet.
Here is Dinqua's jetting calculator which is a good place to start with jetting. This is not the absolute answer but as I said, it's a place to start with jetting. The BEST way is to jet and dynorun. Or the seat of your pants dyno can help.
DunnSpeed #287479 08/02/2010 2:58 PM
thanks for the reply will get round to changing the jets will it do any damage in the mean time running it as it is..
thrape #287480 08/03/2010 9:04 AM
No damage right away. You've got a some time but don't wait for months to go by, you know.
Do a search on this topic and you can learn more about the topic....quick ways to rejet by dropping just the bowls, how to read your plugs by looking at the color, etc...
DunnSpeed #287481 08/09/2010 2:41 PM
sorry still really confused ive had so many contradictive advice (not on here)dinqua's jetting guide says 130 main 42 pilot jenks bolts said 135 main 42 pilot 1 shim
free flow air box, some guy who sold jenks bolts the company said 120 and maybe 1 shim but get it on a rolling road, and then some chap who used to tune triumphs and worked for triumph said you can't chop out the stock pipes like that your going to do more damage with no back pressure
I am at my wits end please help
Dupre97 #287482 09/01/2010 9:46 PM
SUPER EASY BAFFLE REMOVAL un bolt silencer throw into trash can go to local muffler shop select some chrome tips the length diameter and style of choice pay go home and bolt on.
StandingBull #287483 09/01/2010 10:05 PM
look you dont need back pressure. my america will leave a black mark down the street how ever long you want. All i did was install the unifilter, remove the snorkel, install 130 mains, shim the needle .9 mm, turned out the jet screw to 2 1/2 turns out from closed, and remove the silencers.
I installed some 18" turn downs. I beat a 1200 sportster off the line and he could never make the distance back threw all 5. I stayed ahead of him 1/2 a bike length. I know you dont want to hurt your bike but trying to beat out the baffles or punch an over sized hole in them is way out there. I put 22" x 3 1/2" slash cuts on my friends bike $105 for both. at a muffle shop and my 18" turn downs $40. For the price of performance replacements you can go to a custom exhaust shop and have some thing completely unique built.
StandingBull #287484 09/24/2010 10:43 AM
Welcome to the "back art" of tuning...your location, elevation, will effect the jetting...so I am at sea level so my jetting would be different than when I lived in CO. Start with dinga jetting...then read up on tuning and change one thing at a time...say up/down one main jet size...see how it runs....or...take it to a dyno tuner who will tune it on the dyno....
SDKimo #287485 09/25/2010 7:50 AM
Yes this is true, you will have to tune the bike afterwards. However thats not to difficult either if your local triumph dealer is cool. The tech will tell you what he has been doing to get the best results. Your bike may differ to an extent, but its a good way to start. I also live at sea level here in texas, down on the gulf. you dont have to dyno one just ride it. If you have been riding long and understand mechanics of it all you'll befine.
StandingBull #287486 11/10/2010 11:10 AM
My exhaust does not look like the posted photos: 2006 Bonneville America
They are slash cut and the inner (smaller) pipe is about 3" inward.
Would the same baffle removal method apply?
Rev #287487 12/22/2010 7:29 AM
What if you gutted the pipes on an 09 version, would
you need to buy a fuel commander to alter the EFI?
I currently have a carbureted Yamaha, and one of the
biggest reasons I stopped at removing the first baffle
is because removing the cats and final baffle required
a rejet, which I neither wanted to bother with, or pay for.
Hi,
I'm rookie. Bought BA this summer (2010). It's got EFI. I didn't see anyone answering this question, so I thouhght of reposting it, cause I'd be intresting to take the end-plate
(and baffle attached to it) out and wonder if adjustments in EFI are required.
rgds,
Hude61 #287488 12/23/2010 8:51 AM
yes you would have to get the power commander and retune.
Dupre97 #287489 11/16/2011 5:36 PM
Many thanks dude great stuff! Now to get the inner one out lol
Quick! There's time 2B Wasted! :-P 2007 America Harley FatBoy Short Pipes
Fizzyhair #287490 01/04/2012 2:16 AM
I did this and yep its easy then i got the idea of more mods so slash cut my pipes now thinking of removing the next baffle will i need to re jet or would it still be ok
roosters #287491 01/05/2012 8:52 PM
You'll need to re-jet.
Two_Wheel_n #287492 01/05/2012 10:43 PM
No you don't need a Power Commander. There is a little program called Tune Ecu available now that allows you to change the maps on an EFI bike at home with a laptop using a $20.00 Vag-Com cable that you can order from several places.
If you only remove the end plate and the first baffle you won't need to mess with it.
EFI=TuneEcu
Carbs=Jets
firebird #287493 01/06/2012 2:34 AM
thanks for that i will
Zmilin #287494 01/16/2012 9:45 AM
Thanks for the info! I did mine 2008 America yesterday,sounds great!
streetdown #287495 03/05/2015 4:18 PM
I just Mangled the ****** out of my 05 America stock exhauste. I'll post pics as soon as I can but it looks like I'm going to have to buy new pipes for the sound I need. I didn't even get the first baffle out because it was so much bigger and deeper then I thought.
JDJohnson #287496 03/05/2015 4:54 PM
There is a set of TORs on Ebay right now for $99, if you want a quick fix?
Ryk #287497 03/05/2015 7:32 PM
Buy the TORs, you will like them better than taking the baffles out. Plus most can give you a decent tune.
edmspeedmaster #287498 09/23/2015 11:52 PM
Hi everyone this is my first time in this forum. after reading about baffles I did remove one baffle from each stock exhaust pipe, Bike runs and sound better but still quiet...I may go for the second one or drill holes in it.
my bike is 790cc 2006 AMERICA and is my first bike.
little bit apprehensive about re-jetting my self but willing to do. thank you all for great advice
Moderated by  bennybmn, chy
