 Re: Floor boards??
Posts: 10,729 Likes: 5
Posts: 10,729 Likes: 5 |
 Re: Floor boards??
Posts: 1,847 |
Still lovin' me some Floor boards...
Warren
04 Caspian Blue and Silver America
 Re: Floor boards??
Posts: 490 |
Does anyone want to get rid of their left-over original equipment "driver's" footpegs? I could sure use a set. Shoot me an e-mail offlist to discuss terms. kthunter01@sbcglobal.net
Kevin Hunter Friendswood, TX
Email sent.
Ride like you mean it.
 Re: Floor boards??
Jerry, that post was from 5 years ago, but you never know!
 Re: Floor boards??
Posts: 75 |
I have floor boards on a 2011 America. My hips cramp on long rides and the heel shifter is virtually worthless for me because I cannot lift my heel enough to utilize it. I also have difficulty getting the toe of my boot under the toe shifter, although I can manage to do so. Has anyone made adaptations that might solve this problem? If I could just mount a toe shifter (only) it would help a lot and allow me to rest my left foot on the rear edge of the left floor board like I do on the right. Is there a toe shifter available that is compatible with the OEM left floorboard? Has any one just cut off the heel shifter?
 Re: Floor boards??
Posts: 1,493 Likes: 6
Posts: 1,493 Likes: 6 |
You can adjust the shifter lever by loosening the lock nuts on the shifter rod and turn it to shorten the shifter rod. On the heel toe shifter, your toe steps on the front (toe) part, and then you step on the rear (heel) part, Your toe isn't designed to "up" shift with the heel toe shifter. It all depends on how much room you have between your shifter and floor board and if you keep the heel toe shifter (can you bend the heel side up a little?,remove it from the bike first before trying to bend it!)
 Re: Floor boards??
Posts: 23,219 Likes: 61
Posts: 23,219 Likes: 61 |
When I did the changes to Wendys bike because she was so short I took the arm off the shift shaft coming out of the primary case and moved it to gain enough adjustment to get the position desired.
 Re: Floor boards??
Posts: 75 |
Dang! I've been eating the wrong peoples' brains. I'll try both remedies given so far. Thanks
Homer
