Pluging a tire
Posts: 211 Likes: 2
Posts: 211 Likes: 2 |
What is the consensus on repairing a flat? This would be for an America with alloy wheels. The shop originally said they would not plug it but when I was going to take it elsewhere they plugged it. A friend said the tire is not safe. The small nail was in the tread on the front tire
Re: Pluging a tire
Posts: 23,133 Likes: 52
Posts: 23,133 Likes: 52 |
If it is a rope style plug it will probably be OK. That being said I wouldn't do it for anyone else because it isn't safe. Best way is a patch or plug patch from the inside(my choice) Most shops I know will not plug a motorcycle tire due to liability.
Re: Pluging a tire
Posts: 2,668 Likes: 14
Posts: 2,668 Likes: 14 |
Agree with Ian, at least when it comes to motorcycles. Personally, I consider a plugged motorcycle tire to be an emergency repair, not a long-term fix. Harry Callahan's famous question regarding luck of course applies in this situation.
Re: Pluging a tire
Posts: 4,056 Likes: 78
Posts: 4,056 Likes: 78 |
Ill advised in my opinion. I was running around 50 when it blew out. I luckily managed to get it mostly stopped before the tire wadded up in the trailing arm and locked the wheel. It could have gotten real ugly.
Re: Pluging a tire
A buddy who rode old Triumphs told me he had a blowout on the front once.. Showed me his jacket.. Flipped him right over the handle bars.
Re: Pluging a tire
I have had both front and rear blow outs, lucky I was able to keep it upright every time. Back not so bad but front was hairy.
Re: Pluging a tire
Posts: 211 Likes: 2
Harry Callahan? Now where do I know that name? Oh yeah! https://www.youtube.com/watch?v=38mE6ba3qj8Enough said I will buy a new tire.
Re: Pluging a tire
Posts: 211 Likes: 2
We discussed this a long time ago I think but I do not remember the result. The OEM front tire for a 2009 America is a Metzeler Lasertec 110/90-18 61H. This does not seem to be offered anymore the closest being 110/80. The replacement appears to be the Metzeler ME888 Marathon 110/90-18. Does this sound correct?
Re: Pluging a tire
Just need to stay close in size, actual tire is a personal choice for the most part the big name tires you are paying for the name not better quality. There are some exceptions, Metzlers are over priced in my opinion. You need to look at speed rating and load rating. Generally the higher the speed rating the softer the compound, the softer the compound the better they grip the road but the faster they wear. If you ride aggressive you need a softer tire if you are conservative riding you probably don't need as soft a tire. As far as size goes the first number 110 is the width of the tire at it's widest point in MM then the 2nd number is a percentage of the first giving you sidewall height in MM. The 61H is load and speed rating 61 being load and H speed. Also when buying a tire the dot number tells you week and year of manufacture, the first 2 numbers are the week and the 2nd two are the year.
Re: Pluging a tire
My 07SM currently has a 110/90-18 Michelin Commander II front tire. I like it.
