Motor install
#601381 03/16/2021 8:07 PM
Haddon1 Offline OP
Hello- has anyone installed a EFI motor in their carbed bike and run it on carbs instead of efi??? Thanks for your input
Re: Motor install
Haddon1 #601382 03/16/2021 8:34 PM
The 2007 America had this combination out of the factory. I have a friend that has one. It does not seem to have any advantage over my 2005.
Re: Motor install
Haddon1 #601383 03/16/2021 8:57 PM
Well, not exactly; 2007 had carbs & used a CDI igniter, not ECU controlled like EFI. The carb model igniter won't run with EFI, and an EFI bike won't run with the electronic igniter from a carb bike.
Re: Motor install
Haddon1 #601384 03/16/2021 9:29 PM
Haddon1 Offline OP
Hello- I mean put just the metal part motor —-remove wires ,,install carb wiring with CDI and run it off a carb to intake manifold- thanks
Re: Motor install
Haddon1 #601414 03/28/2021 5:43 PM
Seems like the cams were different, but to the good. I had a 2012 sm that had good low end power stock. Better than the 05
