lost my key
#598044 08/25/2019 11:33 AM
leonard Offline OP
how can I hotwire my bike. The dealer has tried to cut me a new key using the number I had with the original key.
So far, they have failed. I need to get it running to get the bike back home.
Re: lost my key
leonard #598045 08/25/2019 8:27 PM
My seat of the pants opinion is:
Follow the ignition harness Black and white or black and brown clip, may be under the harness sheath. Big wires. Pull it apart at the clip and jumper the two together in the clip on the starter side Like a U shape will make the connection. It should light it up and make you ready to go.
I could be very wrong.
Re: lost my key
satxron #598046 08/25/2019 9:15 PM
leonard Offline OP
Thanks, I'll give it a try tomorrow.
Re: lost my key
leonard #598047 08/26/2019 12:57 PM
This happened to me. The dealer took my VIN and sent it to Triumph. Triumph sent a brand new factory set of keys.
Re: lost my key
MACMC #598048 08/26/2019 2:43 PM
The old school way to hot wire a vehicle was to run a wire from the Pos on the battery to the Pos on the coil/coils and jump the solenoid. Vroom, Vroom.
Re: lost my key
Ryk #598049 08/26/2019 8:49 PM
Will that work on a modern ignition? Crank sensor has to be powered up to trigger the fire in the CDI that also has to be powered up. It used to work on points or HEI because that was all you needed to power everything, no computer or crank sensor involved.
Re: lost my key
The_Dog33 #598050 08/26/2019 10:43 PM
Call Hollywood, they do it all the time in the movies!
Re: lost my key
ladisney #598051 08/30/2019 4:40 PM
leonard Offline OP
I tried Hollywood, no luck!
Re: lost my key
leonard #598052 08/30/2019 4:43 PM
leonard Offline OP
I tried Hollywood, but no luck!
Re: lost my key
satxron #598053 08/30/2019 6:53 PM
leonard Offline OP
shorted the connector, all it did was turn on the headlight. Nothing else would work.
Re: lost my key
leonard #598054 08/30/2019 9:48 PM
Sorry, I thought it may work.
Re: lost my key
satxron #598055 08/30/2019 11:09 PM
leonard Offline OP
thank you for the suggestion. any help is appreciated. My dealer is trying to help, but they have tried cutting a key for me twice, but no luck yet. I will try to replace the switch, but I'm not able to get to the screws holding the switch. I will try drilling it out. Has anyone replaced their switch?
Re: lost my key
leonard #598056 08/31/2019 7:39 AM
You could try and pick it with 2 paperclips, a rake and lever. Also could try and unplug the switch and use jumper wires at the plug.
Re: lost my key
The_Dog33 #598057 08/31/2019 11:54 AM
leonard Offline OP
Thanks Dog33, I'm still trying.
Re: lost my key
leonard #598058 09/01/2019 12:36 AM
Schematic in the manual should make it fairly easy other wise identify the ground and hot first and go from there. A power probe would make that easier.
Re: lost my key
The_Dog33 #598059 09/01/2019 3:53 PM
There's a complete ignition switch on Ebay right now for 100 bucks with key
