1983 BONNEVILLE INDIAN
#597911 08/13/2019 1:26 PM
NEW TO BONNEVILLE AMERICA.COM
JUST THE OTHER DAY PURCHASED A 1983 BONNEVILLE AMERICA
FROM A FRIEND. THE BIKE STARTS AND IDLES,THEN DIES OUT AND WILL NOT RESTART UNTILL COOLS A BIT, BOGS DOWN BAD WHEN ATTEMPT TO THROTTLE UP. THE FUEL TANK IS PRETTY WELL VARNISHED (SAT 6 YEARS),OBVIOUSLY THE CARBS ARE BLOCKED. QUESTION IS WHAT IS THE BEST WAY TO GO ABOUT CLEANING OUT THE FUEL TANK, I CALLED A LOCAL BIKE SHOP AND SOUNDS EXPENSIVE. ALSO AM I BETTER OFF REBUILDING THE CARBS OR REPLACING ? IF I OVERHAULWHERE CAN I FIND REBUILD KITS AND SHOULD I REJET?
Re: 1983 BONNEVILLE INDIAN
duster440 #597912 08/13/2019 6:22 PM
Disassemble and put them in a dunk tank kit and let them soak. While apart inspect the slide rubbers for holes/cracks.
Can't speak to the jetting, don't have enough info.
The_Dog33 #597913 08/14/2019 8:02 PM
is there any easier way to remove carbs without taking off rear wheel and airbox?
duster440 #597914 08/15/2019 3:25 AM
Hose the front and rear rubbers that hold the carbs in place with WD-40 or any other penetrant oil, remove the metal clamp bands, work the carbs towards the airbox, then remove the front rubbers, I always pull the carbs to the left enough to detach the throttle cables. Mea Culpa, I'm slightly out of sequence, pull the fuel line while the carbs are still locked in place, first. It's not rocket science, you can manage it. There is also a small cone shaped screen in the fuel feed, remove and discard, it only causes grief at some point. There are schematics available on the internet, and if needed we do answer questions to the best of our combined recollections.
Ryk #597915 08/15/2019 8:38 AM
What exactly is a "1983 Bonneville Indian", or for that matter, a "1983 Bonneville America"?
B02S4 #597916 08/15/2019 12:31 PM
A Indian born near the Bonneville Dam in 1983, would be one. I've done rehab and repair three times on that particular structure since my career in the Millwrights began. And the area is historically tied to specific Indian Tribes
Ryk #597917 08/15/2019 2:07 PM
that is a beautiful area, I like the bridge of the Gods plus there is a impressive of statue of Sacajewewa near by.
not sure she actually looked like that, but the statue is pretty good.
