Straight piped my BA
#590292 10/18/2017 7:45 PM
Mags Offline OP
Well, out of pure boredom I decided to completely remove my baffles. Obviously I know it's going to be loud.
I'll point out a few things from this experience
- It is almost as loud as Gravedigger
- I could not ride it more than 5 minutes
- Noticeable loss in bottom end torque
To remedy this I have ordered 8" steel baffles.
Re: Straight piped my BA
Mags #590293 10/18/2017 8:03 PM
Duly noted
mikemm03 #590294 10/18/2017 8:35 PM
I lost a baffle out of my Scepter pipe before, and pulled the other side to balance it out. It's obnoxious and yes, loses power...
roadworthy #590295 10/18/2017 8:41 PM
Mags Offline OP
I wonder how EMGO cocktail shakers sound compared to these. I can imagine they are comparable.
Mags #590296 10/18/2017 11:39 PM
I removed all three baffles from my BA and don't think it's too loud. Most of the guys I ride with have HDs that are louder than my bike.
And once I fattened up the carbs it runs better than it did stock.
jamesbrown #590297 10/20/2017 6:30 PM
I gutted my pipes too and have a measurable gain on the dyno. That being said I do not have straight pipes, there is still back pressure but only a reducer cone no baffles. I have also done other mods though to go with the pipes. You need back pressure or you lose power and you will not gain by simply allowing the exhaust to flow better. You need to make intake and fuel changes to go along with the open pipes.
The_Dog33 #590298 10/20/2017 9:20 PM
Mags Offline OP
Right now I still have my stock air box so I haven't rejetted yet. It runs pretty good without any backfiring.
Mags #590299 10/21/2017 12:46 PM
You are way lean then but not as bad as if you had opened trhe intake too without a rejet.
The_Dog33 #590300 10/24/2017 4:16 PM
Mags Offline OP
I've also done the SAI removal so I'm sure I'm about as lean as the factory which is still lean anyway. It seems to run just as good but I'm looking into rejetting for pods.
Here's a sound clip of the new baffles with steel wool wrapped around them. They're cheap 8.5" steel baffles from eBay with Ace hardware wool.
https://youtu.be/6S1eYsOYEqQ
Mags #590301 11/06/2017 10:58 PM
Mags Offline OP
I've ordered 128 main jets from Bellacorse. Love that website. Hopefully this will get me right on point to where I need to be. I might be a tad rich but if I am I will modify the airbox.
Mags #590302 11/06/2017 11:20 PM
You will most likely not be rich, more likely still a little lean at 128 main with open pipes even with the stock air box but who knows until you try it. Don't forget the pilot circuit.
The_Dog33 #590303 11/07/2017 1:39 AM
Mags Offline OP
Thanks for the wisdom. I was going off of dinquas calculator which lead me to 126 mains, however bellacorse only offered 128.
Moderated by  bennybmn, chy
