T100 Bonneville end cans fit?
Posts: 21 |
I have the chance of some free T100 Bonneville TOR end cans. Will they fit on a BA?
I fear that they may not.....
Re: T100 Bonneville end cans fit?
Posts: 407 Likes: 2
Posts: 407 Likes: 2 |
They likely have the same size diameter pipe for the header & muffler, but... The peashooter mufflers I had on my Bonneville had a sweep in the pipe between the header joint and the muffler itself. Not sure if all years had the same kink. Think the Thruxton had a straighter header and muffler profile but could be wrong.
I'm thinking Bonneville pipes are a smaller diameter than the America but don't know for sure.
Posts: 29 |
If they are free, get them and try them on. Then get back to us and let us know! :-)
Posts: 21 |
Tried them they would need major fabrication to get them the fit. The bracket is far too far away......the bore is the same though.
Posts: 29 |
At least you tried, and now we know! :-)
Posts: 95 |
How far away were the beginning of the cans and the end of your factory head pipe? Was it a level distance, or were the cans setting up higher also? I've always wanted to mount a set of vintage looking "pea-shooters" on to my '12 America. Are these mufflers actually the "Triumph brand OFF-Road" slip-ons, or "TORs" for the T100, and not just a set of the stock T100pea-shooters? If they're the actual TORs, and you're considering selling them, I may be interested.
Mike
Posts: 23,133 Likes: 52
Posts: 23,133 Likes: 52 |
Bonnie pipes bend up at the front of the mufflerMaking it not practical to fit. There are pea shooters out there with 1 3/4" inlets that are straight that will work.
Posts: 95 |
Where would one look for such a set of pea shooters pray tell? So the inlets on the America cans are 1 and 3/4 then? Thanks! Mike
Unless you an find some that are specific for TBAs, I would stay away from the Bonnie ones, they are totally different in mounting. Inquire with Norman Hyde, that would be a good start for a search. If they exist, they might point you in the right direction.
