T100 Bonneville end cans fit?
#564844 04/14/2015 2:38 PM
I have the chance of some free T100 Bonneville TOR end cans. Will they fit on a BA?
I fear that they may not.....
Re: T100 Bonneville end cans fit?
DevonDel #564845 04/14/2015 10:14 PM
They likely have the same size diameter pipe for the header & muffler, but...
The peashooter mufflers I had on my Bonneville had a sweep in the pipe between the header joint and the muffler itself. Not sure if all years had the same kink. Think the Thruxton had a straighter header and muffler profile but could be wrong.
MattyMo #564846 04/14/2015 11:40 PM
I'm thinking Bonneville pipes are a smaller diameter than the America but don't know for sure.
Keith #564847 04/15/2015 2:10 PM
If they are free, get them and try them on. Then get back to us and let us know! :-)
JohnSpeedmaster #564848 04/15/2015 5:05 PM
Tried them they would need major fabrication to get them the fit. The bracket is far too far away......the bore is the same though.
DevonDel #564849 04/17/2015 1:37 PM
At least you tried, and now we know! :-)
DevonDel #564850 07/20/2015 4:35 PM
How far away were the beginning of the cans and the end of your factory head pipe? Was it a level distance, or were the cans setting up higher also? I've always wanted to mount a set of vintage looking "pea-shooters" on to my '12 America. Are these mufflers actually the "Triumph brand OFF-Road" slip-ons, or "TORs" for the T100, and not just a set of the stock T100pea-shooters? If they're the actual TORs, and you're considering selling them, I may be interested.
Mike
TBA1960 #564851 07/20/2015 9:38 PM
Bonnie pipes bend up at the front of the mufflerMaking it not practical to fit. There are pea shooters out there with 1 3/4" inlets that are straight that will work.
The_Dog33 #564852 08/17/2015 2:22 PM
Where would one look for such a set of pea shooters pray tell? So the inlets on the America cans are 1 and 3/4 then?
Thanks!
Mike
TBA1960 #564853 08/17/2015 2:36 PM
Unless you an find some that are specific for TBAs, I would stay away from the Bonnie ones, they are totally different in mounting. Inquire with Norman Hyde, that would be a good start for a search. If they exist, they might point you in the right direction.
Ryk #564854 08/18/2015 2:10 AM
Well these guys made them for a member of this form, can't find his three with pics:
http://www.feked.com/universal-burgess-type-british-classic-silencer-21-id-35-51mm.html
These are the ones he used.
Dan
Moderated by  bennybmn, chy
