Pretech 6-Pot Caliper for America & Speedmaster
#542759 03/26/2014 12:27 PM
PieMan Offline OP
TTP have worked with Pretech to enable our 6-Pot front caliper to fit the America (all years) and the Speedmaster (2011 on). Click HERE for information.
Re: Pretech 6-Pot Caliper for America & Speedmaster
PieMan #542760 03/26/2014 12:39 PM
Will it lock the front wheel and if so at what speed?
satxron #542761 03/26/2014 12:57 PM
PieMan Offline OP
Unusual question. It will lock the front wheel at any speed you like depending on the pressure applied.
PieMan #542762 03/26/2014 1:03 PM
Its a safety question. If in a panic you can lock the front wheel you will wash it out and go down.
satxron #542763 03/26/2014 1:14 PM
PieMan Offline OP
I've not experienced that in the dry, but once in the wet, very painful! The Pretech used with the OEM master cylinder gives a very progressive feel not an on/off wooden feel. In my experience any properly sized caliper will lock the wheel if a panic situation arises.
PieMan #542764 03/26/2014 4:00 PM
Well, that was my question, at what speed will this caliper lock the wheel? The America caliper has a big problem locking the front wheel at speed which is a very good thing.
With the trail of the Speedmaster and America if you lock the wheel at speed it will kill you.
I was just wondering if anybody did any engineering or outrigger panic stopping on this caliper mounted on these particular bikes.
satxron #542765 03/26/2014 4:34 PM
Is it the same as Harrison 6-pot mini? Using the same pads?
piper1 #542766 03/26/2014 4:45 PM
I guess I have another question. Is there testing on the America that shows stopping distance is reduced? Like at 40MPH oem stops here and the minipot stops here.
So here is a link showing an example. Did Pretech do something like this to show stopping distances. As all these test are done with outrigger wheels, did Pretech find a significant washout issue with our bikes.
