Brakes
#52996 04/09/2006 8:31 PM
chy Online Content OP
OP Online Content
Brake stuff
A word of caution...
chy #52997 04/09/2006 8:37 PM
When removing the front rotor, you may consider heating the bolts both from the head and thru the spokes to the tip of the bolts. These are in VERY tight and with loctite!! And the bolts a $6 a pop, so don't screw them up! Ask me how I know...
Brake pad part # info
chy #52998 04/10/2006 11:37 AM
OP Online Content
I have found that the Tucker Rocky book, which is used at many parts counters, has the wrong information for EBC rear pads, listing them as the same as the front pads - FA196. The correct EBC part number for TBA rear pads is FA214. An FA196 pad will not fit on the rear of a TBA or Speedmaster.
EBC Brake pad/rotor part # info
chy #52999 04/10/2006 1:48 PM
Straight from EBC's Application PDF, page 36, here is their info:
02-06 Bonneville America
Front:
Organic Pads/Shoes - FA196
Sintered Double-H-Pads - FA196HH
OE Replacement Rotor - MD649LS
Rear:
Organic Pads/Shoes - FA214/2
Sintered Double-H-Pads - FA214/2HH
OE Replacement Rotor - MD643
03-04 Speedmaster 790cc
Front:
OE Replacement Rotor - MD649LS / MD649RS (Left and Right sides)
Rear:
05-06 Speedmaster 865cc
Front:
Rear:
Also, Brent can provide EBC floating rotors (#MD601LS) at NewSpeedmaster.com
*** As of February 2007, NewSpeedmaster.com is also selling the rear EBC rotors. ***
Re: A word of caution...
bennybmn #53000 01/27/2007 5:04 PM
As an addendum to Ben's post, I spoke with my dealer about the bolts holding the brake rotors on. He says definitely heat the bolts up to melt the loctite before removal. You will round the heads out of them otherwise.
Moe's Edit: Use heat? Alternatively, use a hand held impact driver to break the blue loctite holding the rotor bolts. These are only torqued to 22nm. It's that dern blue locktite! The repair manuals say to replace the bolts no matter how you get them out!
More flags More fun!
Calliper bolts and hose clips.
chy #53001 06/22/2007 1:21 PM
From Ray (Birchr) whi used these when converting to twin front discs:
the part numbers for the brake bolts to hold the callipers on M8 X 40 Chrome part number T3050085 and also the brake hose clips for the front fender/mudguard 2 of them part number T3700024.
Great thread about bleeding brakes
bennybmn #53002 09/02/2007 8:26 PM
Re: Great thread about bleeding brakes
bonnyusa #53003 09/10/2007 8:07 AM
From Ray (birchr) again.
His front brake pads from a 1996 Honda CB Seven Fifty are an exact match for ours.
Re: EBC Rotors other Triumph applications
wojo #53004 04/10/2008 1:19 PM
EBC Front Rotor Cross Referenced from the 2008 EBC Catalog
EBC Part number (non floating) MD649LS
Other bikes applications
America/865cc (Cast wheel) 06-08
Bonneville America (790cc) 02-06
Bonneville 800 (790cc) 01-06
Bonneville T100 (865cc) 02-08
Bonneville/Bonneville Black (865cc) 06-08
Scrambler (865cc) 06-08
Speedmaster 800 (790cc) 03-04
Speedmaster (865cc) 05-08
Thunderbird Sport 98-03
Tiger 955cc (Spoke wheel) (up to VIN 198874) 99-04
EBC Rear Rotor Cross Referenced from the 2008 EBC Catalog
EBC Part number MD643
Adventurer 96-01
Legend TT 98-01
Thunderbird 95-03
