Ignition systems
#48244 03/24/2006 1:43 PM
chy Offline OP
Plugs, wires, ignition coils and related info
Spark Plug Cross reference
chy #48245 03/24/2006 1:46 PM
chy Offline OP
SPARK PLUG Electrode Gap for the NGK DPR8EA-9 is 0.8 to 0.9 mm
Denso Iridium Racing IXU01-24
Denso Iridium plug IX24B
NGK IX iridium DPR8EIX-9
Splitfire Triple Platinum TP416C (No longer available)
Splitfire SF416C
NGK DPR8EA-9
Autolite 4163
Champion RA6HC
Denso X24EPR-U9
Info supplied by: Soren
Igniter or CDI module
chy #48246 03/24/2006 1:50 PM
chy Offline OP
Aftermarket supplier of CDI modules for pre fuel injection, Hinckley trumpets:
Bonneville (Standard)
Bonneville T100
Thruxton
American
Speedmaster
Scrambler
all, in one unit, made possible via a blue-dial selection.
Current Maps
General info
chy #48247 03/28/2006 6:57 PM
chy Offline OP
Don't if this is listed anywhere, but this site has loads of info on plugs. I know it is a vtwin site, but what the heck.
Wendell
Spark Plug basics
NGK Cross Reference
chy #48248 04/12/2006 9:31 AM
NGK Cross Reference spreadsheet
Click on the link 'NGK Cross-Reference Matrix (2.0meg)'
(lines 1415 & 1416)
Re: Ignition systems
chy #48249 11/05/2007 10:47 AM
I`m going to put this here since it has something to do with the ignition system.
Just in case you are looking for a replacement key for your bike I`ve found this site, Motorcycle keys.com.
Be careful which key you order. The Triumph 2 key is the one they say will fit our bikes. They also carry two versions of a key for our steering lock, one is the Triumph 3P and the other is the all metal Triumph 3M.
Pick-up coil Air Gap change
wojo #48250 01/01/2008 7:34 PM
The gap for the Hall Effect pick-up coil, located behind the right engine cover, was changed during production due to warranty issues, the following was sent out as a statement;
Triumph manual, chapter 16, page 47 has the alignment procedure...
Thanks to members Sightglass for originally posting this and TonyG pointing out that it should be in the tech vault.
Re: retard the timing by 8.25 degrees
wojo #48251 01/08/2012 9:54 AM
(via the pick up sensor)
Micah's (mag10) details on making an an adapter plate which is mounted under the pickup head.
Micah's photographs:
