Ignition systems
Posts: 4,056 Likes: 78
Posts: 4,056 Likes: 78 |
Plugs, wires, ignition coils and related info
Spark Plug Cross reference
SPARK PLUG Electrode Gap for the NGK DPR8EA-9 is 0.8 to 0.9 mm
Denso Iridium Racing IXU01-24 Denso Iridium plug IX24B NGK IX iridium DPR8EIX-9 Splitfire Triple Platinum TP416C (No longer available) Splitfire SF416C NGK DPR8EA-9 Autolite 4163 Champion RA6HC Denso X24EPR-U9
Info supplied by: Soren
Igniter or CDI module
Aftermarket supplier of CDI modules for pre fuel injection, Hinckley trumpets: Bonneville (Standard) Bonneville T100 Thruxton American Speedmaster Scrambler all, in one unit, made possible via a blue-dial selection. Current Maps
General info
Don't if this is listed anywhere, but this site has loads of info on plugs. I know it is a vtwin site, but what the heck. Wendell Spark Plug basics
NGK Cross Reference
Posts: 9,223 |
NGK Cross Reference spreadsheet
Click on the link 'NGK Cross-Reference Matrix (2.0meg)'
(lines 1415 & 1416)
Re: Ignition systems
Posts: 3,960 |
I`m going to put this here since it has something to do with the ignition system. Just in case you are looking for a replacement key for your bike I`ve found this site, Motorcycle keys.com. Be careful which key you order. The Triumph 2 key is the one they say will fit our bikes. They also carry two versions of a key for our steering lock, one is the Triumph 3P and the other is the all metal Triumph 3M.
John
Like a dog on a car ride with my tongue in the wind
Pick-up coil Air Gap change
Posts: 3,960 |
The gap for the Hall Effect pick-up coil, located behind the right engine cover, was changed during production due to warranty issues, the following was sent out as a statement;
Triumph manual, chapter 16, page 47 has the alignment procedure...
Thanks to members Sightglass for originally posting this and TonyG pointing out that it should be in the tech vault.
John
Re: retard the timing by 8.25 degrees
Posts: 11,120 Likes: 11
Posts: 11,120 Likes: 11 |
(via the pick up sensor) Micah's (mag10) details on making an an adapter plate which is mounted under the pickup head. Micah's photographs:
