From members Tony_From_Boston and chip,
I talked to Steve at National Cycle today and here is the skinny. The Shield is the one that fits; the Honda Shadow Spirit 750, or the Shadow Ace 97-2000, or the Shadow 1100 87-97.
Mine is the Two Up model and the part # is N21101. It is tall and I look through mine, but I ride all year round. It blocks a lot of air and there is no buffeting.
There are 4 different windshields that will attach to the same mounts.
The mounting kit part # is, Q102. You'll need to add 2each of the following.
Mounting straps,
The top strap is a number 73, and that number is located on the inside of the strap. The Part # is 37-370173-000.
The bottom strap is a 74, and the part # is 37-370174-000.
Be sure to order [2] two of each or you’ll only be able to put one mount on.
These are all the part numbers you'll need to have all the parts to mount the “Switch Blade†shields to you bike, if you have the tapered bezels over your fork legs. Follow the directions they send except one thing. Turn the bottom spool around so that the thick part is on the outside. That takes up the difference in the taper of the bezel.
Steve said all the parts are available and could be ordered by the numbers I've given here by any of the sales reps. He also didn’t mean to imply that they wouldn’t sell these parts to anyone who wanted to mount their windshield. They weren’t sure if there was enough interest to develop a kit for our bikes.
If there are any questions I’d be glad to help, so just PM me and I’ll try to answer all. If you get the parts and have any trouble mounting them you can also give me a shout. I had some trouble ,but I did the R&D because they didn’t know what I needed to make it work. Once I got all the right pieces it was pretty straight forward. Estimated time to mount the mounting brackets is ½ hour. Time to install windshield, 5 seconds.
