Dimensions, etc.
#42353 03/07/2006 11:50 AM
slide hole
2.500mm is 0.098"
2.778mm is 0.109" (7/64") is the maximum this can be drilled out
exhaust valve tolerance - .25-.30mm
intake valve - .15-.20mm
Engine Covers and Sprocket Cover (all to 9NM):
M6 x 75 quantity = 5
M6 x 50 quantity = 15
M6 x 45 quantity = 2
M6 x 40 quantity = 8
M6 x 30 quantity = 7
M6 Washer quantity = 37
Carbs:
M4 x 14 quantity = 8
M4 x 8 quantity = 8
M4 Washer quantity = 16
Fraction - inch- mm conversion
bonnyusa #42354 03/26/2006 11:21 PM
Here's a handy link to convert fractions to inches to millimeters:
http://mdmetric.com/tech/cvtcht.htm
Re: Conversion program
bonnyusa #42355 03/27/2006 1:49 AM
Here's a link to a free program that will convert just about anything to anything.
Convert
Triumph Handlebar Dimensions
Deon #42356 03/30/2006 12:55 PM
Thanks Derek!
(Scroll down to the bottom of the page)
Shim Calculator
bonnyusa #42357 04/05/2006 11:45 AM
Valve Adjustment shim calculator courtesy of member dinqua.
Pat's Dinkulator.
Download and execute!
Jetting Calculator
bonnyusa #42358 07/11/2006 9:14 AM
For determining what size jets to use with what pipes and airbox setups. Good for the 790/904cc 270º motors. May be close enough for the 865cc motors as well.
Jetting Calculator
Fork size
bonnyusa #42359 04/15/2009 1:55 PM
From Fischercat.
Without shrouds 41mm , With Shrouds I believe 55mm.
