Dimensions, etc.
Posts: 9,223 |
slide hole
2.500mm is 0.098"
2.778mm is 0.109" (7/64") is the maximum this can be drilled out
exhaust valve tolerance - .25-.30mm
intake valve - .15-.20mm
Engine Covers and Sprocket Cover (all to 9NM):
M6 x 75 quantity = 5
M6 x 50 quantity = 15
M6 x 45 quantity = 2
M6 x 40 quantity = 8
M6 x 30 quantity = 7
M6 Washer quantity = 37
Carbs:
M4 x 14 quantity = 8
M4 x 8 quantity = 8
M4 Washer quantity = 16
Fraction - inch- mm conversion
Posts: 9,223 |
Here's a handy link to convert fractions to inches to millimeters: http://mdmetric.com/tech/cvtcht.htm
Re: Conversion program
Posts: 5,172 |
Here's a link to a free program that will convert just about anything to anything.
Convert
Triumph Handlebar Dimensions
Posts: 9,223 |
Thanks Derek! Triumph Handlebar Dimensions(Scroll down to the bottom of the page)
Shim Calculator
Posts: 11,120 Likes: 11
Posts: 11,120 Likes: 11 |
Valve Adjustment shim calculator courtesy of member dinqua. Pat's Dinkulator. Download and execute!
Jetting Calculator
Posts: 6,307 Likes: 3
Posts: 6,307 Likes: 3 |
For determining what size jets to use with what pipes and airbox setups. Good for the 790/904cc 270º motors. May be close enough for the 865cc motors as well. Jetting Calculator
Pat
Fork size
Posts: 12,877 |
From Fischercat.
Without shrouds 41mm , With Shrouds I believe 55mm.
Black & Silver '02
Too many mods to list
Not enough miles ridden
