Hi Folks. I thought I'd share my joy here. My 2010 Speedmaster was getting bit rough while negotiating steep inclines, and on my V-Star 650 that indicated unbalanced carbs. So, I figured I might do an adjustment on the throttle bodies and see what the difference would be.
I have 4600 km (2900 miles) on the bike now. My V-Star was happy when I balanced the carbs every 3500 km or so, and this would give me an opportunity to try out TuneECU. I have a Vag-Com cable that I purchased on eBay, and am running this on an Asus Netbook computer. I used TuneECU 1.67. A big THANK YOU to the developer(s) for making this software available!
Here's some screen shots:
Fast Idle while warming up
Engine Warm
Throttle Bodies BEFORE adjustment
Throttle Bodies AFTER adjustment
The tachometer readout doesn't update while in this mode on TuneECU so ignore that reading. It was barely a tweak on the adjustment screw to bring the throttle bodies into line. Both thottle bodies are now at 330 hPa as indicated on the two left dials on the dashboard.
Test ride. Did a 50 km loop which has various speeds, hills, and curves, but no LONG (8 km) hills at highway speeds. That'll be next week The engine does feel a bit smoother, even loafing along at 2800-3000 rpm. Of course, the real test is when I'm loaded up for those big hills.
Screwdriver. I used one of those right angle phillips screwdriver thingies. Not very good. I think I will be investing in a proper tool for this. You only adjust the balance screw every so sllightly, and I'd prefer a tool that will give small increments. The right angle tool was either too much to the right or the left in position.
So, it was worth doing, and I do recommend doing this very easy adjustment every so often.
H.
