I have a Sears non-contact infra-red thermometer as well. Probably $40 - $60 bucks, I forget.
I also have access to a $1200 version where I work. Guess what? Neither one is very accurate on chrome... The shiny stuff tends to scatter the beam.
Check the joint under the engine where the crossover pipes mate together. If you see a lot of soot, there is a leak, and if there is a leak, the right side is sucking air.
