Chopped Pic's Posted
#98771 09/22/2006 3:00 PM
Well, the pictures are in the members gallery for hill8586
I posted two (2) post chop and one (1) pre-chop to the gallery...............................................
by the way, the Speedmaster front fender looks great on the bike, I just needed to add 1.8 inch to the supports and have just not put it on yet.....works better than a bandana
Re: Chopped Pic's Posted
hill8586 #98772 09/22/2006 4:32 PM
I like theose black fork legs.
SalMaglie #98773 09/22/2006 6:20 PM
i like it!! how did you accomplish this?
jethro666 #98774 09/22/2006 6:58 PM
Very nice, job well done. Couple of questions for you, what sort of rake is that? What's the front end off? And how's it affect the handling?
hill8586 #98775 09/22/2006 7:42 PM
did you powdercoat or paint those legs??? what was involved in that project?? i like the look of the bike.
ENJOY!!!!! NEWT!!!!!
newt #98776 09/23/2006 1:22 PM
well, All shiny parts i.e. lower forks, rear tail light assembly, rear fender supports, clutch & brake lever, chrome battery retainer were powdercoated black, the rear pegs were lowered and the billit aluminum hanger was powdercoated as well. TBA sprocked cover was replaced with a chrome T-100. Fork gaitors replaced the metal shrouds and the origional hub to the stock front wheel was sent off to be re-laced and trued to a 21" rim to fit a 120 tire.
Now, once you go from a 19" stock to a 21" you change the rake and trail to a negative trail. to compensate for this the "math" dictated a 3.75 degree rake. Hence new triple trees. the new rake compensated for the new 21" tire and brought the trail back into the green range .
as far as performance. it rides as crisp as it did with the 19" but in person, just looks like it has that special attitude.....and is noticibly longer. ... Tail light is a 1958 Lucus tail light. Turn signals are off a Thunderbird and have had the stems removed and are "butted up close" on the bike. The rear fender was just cut to please ( yea, that looks good, cut it there !) Rear shocks are stock.
hill8586 #98777 09/23/2006 1:39 PM
Where did you get the triple trees?
tdmccoy #98778 09/23/2006 1:42 PM
I had a friend of mine that owns River City Cycle in Fort Smith ,Arkansas help with all the heavy lifting like the triple trees, 21" & powdercoating.
hill8586 #98779 09/24/2006 1:31 PM
we have a stock 18" on the front
BIKER
biker #98780 09/25/2006 8:09 AM
Biker - yep 18" - had a brain freeze
hill8586 #98781 09/25/2006 8:45 AM
hey but i do have some ???for you is that rake in your tree's a derake or did you add 3.75 of rake making the total 37.05
thanks BIKER
biker #98782 09/25/2006 2:41 PM
well, not sure on the term de-rake but, the stock rake was 29 degrees and we added 3.75 for a sum total of 32.75 (33) to compensate the trail by going to the 21" with the 120 tire..all in all it moved the front axel about 1.4 inches forward with the new trees.
hill8586 #98783 09/25/2006 4:05 PM
hi hill8586 but our stock rake is 33.3 i think some one is giveing the wrong info....
BIKER
biker #98784 09/25/2006 4:44 PM
hmmmmm. The Triumph factory numbers are, 29 degree rake with a 114mm trail. Neck height of 37.5"..................
With the 3.75 deg rake in the new triple tree the new rake is 32.75 with a new trail of 3.79" and a front stretch of 1.4 inches due to the new rake. with the new 21" tire the overall length is increased by 3.4".........................
hill8586 #98785 09/29/2006 7:50 PM
nope hill the factory number are 33.3 degree/153mm trail and they have been like this from the first one of 2002
web page now this is right from the triumph uk site for the 2006 tba and here is one on the 2002 tba web page
so i don't know where your getting you number from
BIKER
hill8586 #98786 10/01/2006 1:33 PM
Hey Dan,
Outstanding bike you have there. Front end looks great!!
On the numbers, I'd listen to biker (Ed). I got to see his handmade girder front end in NY recently and there is NO question, he knows his sh!te!
Brilliant work Ed.
Check this out:
bonnyusa #98787 10/01/2006 9:25 PM
I have an observation here....
Both this bike and Ed's have short pipes, and they both look like the front of the bike got raised in the process of the girder. Optical illusion?
biker #98788 10/02/2006 8:42 AM
Biker.... I do not know... the information I got on my '02 from the folks in Noonan, GA was the 29 degrees... that is also the measurement at the shop before we started our modifications (not saying your numbers are incorrect) but the numbers I had and worked with and the results, i.e. handeling, stretch figure , etc,,, are spot-on... all I can testify to is what I have and proven on mine,, no offense ,
bonnyusa #98789 10/02/2006 8:46 AM
Bonny USA... that bike looks sharp....these bikes are just great looking pallets waiting for customization...I thought they looked great stock, and the custom options are only limited by imagination.....just makes ya proud to be a TBA owner.
hill8586 #98790 10/06/2006 1:21 PM
Just back from a ten hour trip on the "new" TBA ....to pick up some equipment in Kentucky ( hauled bike back) and with the new rake, what a dream on the Highway...smoother than my Trophy.... I think I have my new road bike and its good for show too !!!!!!!!!!!
