Page 1 of 4 1 2 3 4
How To Post Pics In Messages
#79134 07/13/2006 11:47 AM
Soren Offline OP
I have noticed that some people are still having difficulties posting pics in posts. Hopefully this will help clear up some of the questions and confusion on how to do it.
There are a couple basic things that need to be understood first before continuing. On the internet, everything has an address, the technical term is URL. Every page has an address, every object on that page that is not text has its own URL as well. For example; this is the address (URL) of a page in my photo gallery http://www.bonnevilleamerica.com/photopo...=500&page=1. This is the URL (address) of the picture on that page http://www.bonnevilleamerica.com/photopost/data/500/202UKMCross3D400.jpg. In order to post a picture in a message, you need to have the address of the picture (graphic, image, whatever you want to call it). Your image does not have to be in the BonnevilleAmerica.com PhotoPost to be able to use it in a thread, you should be able to grab just about any picture from any web site, such as the screen shots below, they are stored on another web site..
So with that out of the way, here we go.
Getting the URL of an image
1- Go to the page that has the image you want to post
2- Right click on that image
3- Click on properties
4- Highlight the URL of the image
5- Right click on the highlighted address
6- Click on Copy
Congratulations, you now have the URL of your image
Adding the image to a message
1- Create a new message or post a reply to a message
2- Without any spaces type [ image ] (the spaces are ther only so you can see the tag otherwise it would look like I am actually going to add a graphic
3- After the tag, right click and click on Paste
4- Without any spaces type [ /image ]
If done correctly, after the message is posted the result would be:
Good Luck!!
Re: How To Post Pics In Messages
Soren #79135 07/13/2006 1:41 PM
[image] http://www.itv-f1.com/ImageLibrary/38208_2.jpg [/image]
Lets see if this worked
nope, must have done something wrong
Arsenalfan #79136 07/13/2006 1:44 PM
You have a space right before the 'h' in http and right after the 'g' in jpg. Cannot have any spaces....
bonnyusa #79137 07/13/2006 1:46 PM
OK...lets try this again.
OK here goes
Ureka...its works. Thank you Soren, thank you Phil
Arsenalfan #79138 07/13/2006 2:26 PM
I got to try that. [image]http://www.bonnevilleamerica.com/photopost/data/500/671Copy_of_Triumph_MC_Jan_2006-a-[/image]
tomv #79139 07/13/2006 3:20 PM
Soren Offline OP
Tom,
Looks like you didn't get the full URL.
Soren #79140 07/13/2006 3:28 PM
education at its best! well done.
image] [url=http://www.naughtyflordiaboys.com/bonnyusa.jpg] [imge]
wait...what did i do wrong?
Mlessard #79141 07/13/2006 3:36 PM
Great, any Mac people out there that can guide us PC challenged?
Mark
A Dyslexic Man Walks Into A Bra
Mlessard #79142 07/13/2006 3:50 PM
No beginning '[' before image
There's a space after image]
[url=http://www.n..... url is not used in an image post
spaces after jpg
[imge] you have to learn how to spell
finally, naughtyflordiaboys.com does not exist!
bonnyusa #79143 07/13/2006 5:08 PM
Anonymous
Unregistered
Anonymous
Unregistered
http://pic20.picturetrail.com/VOL1274/4353672/9185278/128358132.jpg
edit- that was supposed to pe a picture, not a link
#79144 07/13/2006 5:19 PM
Anonymous
Unregistered
Anonymous
Unregistered
When I'm working on bike, truck, or wife's car, I just undo all the fasteners I can see, fix it, and put it back together. This is different.
When I try to paste, "paste" is not brightend up, therefore unclickable.
bonnyusa #79145 07/13/2006 11:19 PM
Fill, I couldent take my chances all the spelling mistakes were just in case that was a real address.
Mlessard #79146 07/14/2006 8:29 PM
jj_ Offline
While you're submitting your post, if you use the 'Image' link in the 'Instant UBB Code box' it will ask for the image url. Just past it in the box, click 'OK' and it will add the code and place it at the end of the text you've put in the 'Post' box. No matter where the cursor is, it will put the code and photo url at the end of the text you type. Just remember, if the link you get doesn't end in .jpg or some picture file, you may have grabbed the location but not the photo.
jj_ #79147 07/17/2006 2:29 PM
i gotta have a go at this,, never done it before..
bear640 #79148 07/17/2006 2:36 PM
bear640 #79149 07/17/2006 2:37 PM
i guess i,m just too dumb... i,ll never understand computers
bear640 #79150 07/17/2006 3:08 PM
jj_ Offline
Find the image you want to post and right click on it, then in the short menu box select properties.
There are 2 web links in properties box. One is the address (not the photo), the other is location (which in this case ends in .jpg and is the photo).
Using the 'Image' link in the 'Instant UBB Code' box, if you highlight the link to the image, and 'copy' using right mouse click or 'ctrl' key and 'C' (to copy to the clipboard) then click into the UBB code box for images and right click and paste (or 'ctrl' key and 'V' to paste from the clipboard).
Again, the file has to have some kind of image extension. The file you copied is the image address, the actual file name should end in .jpg
edited to add: I had the photo of the Beezer posted for a while, then the link died.
bear640 #79151 08/04/2006 9:23 AM
Soren Offline OP
No, you are not. Just read the instructions slowly and go exactly step by step.
Arsenalfan #79152 08/04/2006 5:24 PM
Anonymous
Unregistered
Anonymous
Unregistered
OK here goes
Ureka...its works.
And the fact I've told you twice how to do it didn't help eh??
jj_ #79153 08/05/2006 1:24 PM
just testing as well
http://i77.photobucket.com/albums/j50/emehlig/CIMG2995.jpg
wow It worked!
EDITED: Photo link still works, the image tags were removed as the image size was excessive...
Erwin
05 America
Erwin #79154 08/05/2006 1:26 PM
Thanks JJ
Erwin
05 America
Erwin #79155 03/26/2007 11:21 AM
Soren Offline OP
Bump, since there has been a bunch of questions lately.
Soren #79156 04/16/2007 7:56 PM
OK, let me try this again, Pic of an early Blue Ridge ride,
Hey! it worked! thanks Soren! now I have to get a more current picture, she does not look like that anymore.....
AngusPT #79157 04/17/2007 3:47 AM
testing[image]C:\Documents and Settings\Owner\My Documents\My Pictures\2007-04 (Apr)[/image]
jefferson #79158 04/17/2007 6:24 AM
Soren Offline OP
Two problems here. First you need to have your picture loaded up on the internet somewhere. Second, it looks like you are listing just the folder your picture is in and not the picture itself.
Soren #79159 04/18/2007 12:18 PM
[image]http://www.bonnevilleamerica.com/photopost/data/500/487Picture_005F_Small_-med.jpg[image]
kennymc #79160 04/18/2007 1:26 PM
Kenny,
In your closing image tag, you missed the '/'. Should have been [/image].
See what I mean?
bonnyusa #79161 04/18/2007 4:57 PM
Every once in a blue moon, I try to post a pic and it comes up just text like that. Funny thing is, I've never typed it in. alwayse use the "image" instant UBB code button.
bennybmn #79162 04/18/2007 5:57 PM
I've seen that and cannot explain it. I hardly ever use the 'buttons' below. I tend to just type img and /img (with the obligatory brackets [] of course). Same with quote, /quote, and the others.
bonnyusa #79163 04/18/2007 6:23 PM
For me it's purely habbit.
Re: How To Post Pics In Messages *DELETED*
Soren #79164 04/23/2007 5:42 PM
Post deleted by lynchphoto
lynchphoto #79165 04/23/2007 5:44 PM
lynchphoto #79166 04/23/2007 5:46 PM
Only took me four years to figure it out!!!! Awesome!!!! Ride safe...Gordon
Mlessard #79167 04/27/2007 10:15 PM
pop Offline
ok, I'm going to try as well, here goes!
pop #79168 04/27/2007 10:19 PM
Soren Offline OP
Good Choice Too!!
Soren #79169 04/29/2007 11:44 AM
testing
[image]http://im1.shutterfly.com/procserv/47b7da09b3127cce84403919db6f00000016100EbMWjFm1asf[/image]
Zmilin #79170 04/29/2007 11:47 AM
any ideas what my issue is? The first one I used the image button and the second one I typed it out.
Rat.net uses this same process and it worked there. Im confuzled!
Zmilin #79171 04/29/2007 11:51 AM
Let me see...
Nope not workin for me either. Shutterfly may just be one of those testy sights. Do they work at rat.net?
Oh I know with my photopic site, I need to go into the "edit" feature, and click on the pic. Then there is a "info" button that gives me the direct URL for the pic that you can use for posting. Maybe that will point you in the right direction.
bennybmn #79172 04/29/2007 12:01 PM
Yes it works on rat.net
Ill try another one just to see what happens...
[image]http://im1.shutterfly.com/procserv/47b7dd34b3127cce829a3634b8e100000016100EbMWjFm1asf[/image]
Zmilin #79173 04/29/2007 12:47 PM
Soren Offline OP
It is because the image name needs to end in .jpg or .gif to work on this site.
Page 1 of 4 1 2 3 4
