accessory wire
#563594 03/25/2015 9:42 PM
I just installed heat demon grip warmers and would like to know if anybody can tell me what color accessory wire I can splice into on the wire loom that that runs into the headlight bucket to power the warmers Thanks Chuck
Re: accessory wire
chuck777 #563595 03/26/2015 3:34 AM
I put a set of oxford heated grips on my america and chose to use the battery as the power source which allowed me to use the fuse supplied, however to stop the risk of accidently leaving them on and flattening the battery I installed a relay switch which fitted nicely under the seat, the relay switch is powered of the tail light. I joined into the tail light under the back fender. This way if i'm going to blow a fuse it is only the tail light, relay switches take very little power, this set has worked fine for me for quite a while... good luck
Re: accessory wire
Peter_AU #563596 03/29/2015 11:10 PM
Thanks Peter for the advise Chuck
Re: accessory wire
chuck777 #563597 03/29/2015 11:18 PM
Similar to the way I wired my air horn except the relay is powered from the horn button.
