Custom Jetting Products
#562533 03/10/2015 8:20 PM
http://www.amazon.com/Triumph-Bonneville...m_cd_al_qh_dp_t
Has anyone used this company before? Thoughts on a service like this?
Good friends, good drinks, good times.
Re: Custom Jetting Products
StewartSchroer #562534 03/10/2015 8:36 PM
Seems expensive to me, but I wouldn't need things like the drill bits. Depending what year you are working on you wouldn't need them for the slide hole mod since later carbs already have the larger hole. Jets are cheap, not sure what they are selling you for springs but they are not a generic item and really depends what you are going for in that department. Needle shims are really just washers and also very cheap.
The_Dog33 #562535 03/11/2015 7:57 PM
its an 06'
It seems like they are really selling their instructions and expertise. Ive never tuned a carb before and i wont have the slightest idea of what fixes the various problems.
Dinquas jet calc suggested 157.5 main jets and that cant be right based on what ive been reading.
BUB pipes with the baffels intact
K&N pod filters
AI removed
1200 above sea level
StewartSchroer #562536 03/12/2015 6:06 AM
Can't look at just one component alone, each effects the other.
StewartSchroer #562537 03/13/2015 10:44 AM
its an 06'
K&N pod filters
AI removed
Thats not what the calculator gives you. Are you running factory size pilots? I am at 2k ft above, stock piots with Bubs and dual pods with 154 mains. Which is what the calculator should give you as well.
edmspeedmaster #562538 03/13/2015 3:19 PM
you are correct sir! after running it again it came out to 154 main jets. So at least I've got that gong for me. Did you have to use any shims or change any springs or anything?
StewartSchroer #562539 03/13/2015 4:26 PM
Dinq s calculator gives you a good reference for a starting point, results can and do vary. On two differently configured bikes, an '05 and a '06, both calculator references ran a tad on one to very rich on the other. Do I endorse the calc, hell yes.
Ryk #562540 03/13/2015 4:56 PM
I found it to run rich too but gives a very good starting point. On a side note, the stock pilot is too small for any intake and/or exhaust change.
The_Dog33 #562541 03/13/2015 5:11 PM
I agree, if i had the bike this year i would have gone up one size on the pilots and kept the 154's in, i also had the BC intakes on it so uppin the pilot size would have been the right thing to do for sure.
StewartSchroer #562542 03/13/2015 5:13 PM
no i did not, i felt the bike ran fine with just the new mains, direct swap. But i was not lookin at getting the most out of her, and i would rather she ran a little rich than lien.
edmspeedmaster #562543 03/13/2015 5:33 PM
Switching to TBS needles, no shims and Kawa springs was a real enhancement for me as well , now remembering back. If you really want to get a grasp on our carbs, read all of B02S4 s posts on the subject, he is a fuel/air mix, guru for a lot of us.
Ryk #562544 03/13/2015 6:54 PM
I agree, I can tune a carb but he has gone way beyond anything I have time or desire to do.
The_Dog33 #562545 03/23/2015 3:58 PM
Thanks for the help guys. Will post an update after i get things put back together. I really cant wait because the weather is getting way too nice outside to be on four wheels.
StewartSchroer #562546 03/25/2015 10:48 AM
