 Spinning starter motor...
Posts: 48 |
So I had an issue with the bike not starting. Solenoid clicked but nothing.. After lots of messing it appears the fuse box wire was loose.. But started up and then it dies... Probably Just cause it was cold.
Anyway.. Go to start again and solenoid clicks, relay clicks and starter motor spins.. Whirring away.. But nothing, no engage or turn over. Just spins. Battery is showing 12.7v and the. 11.02v when switch is pushed...
Any thoughts guys.. I'm miserable :-(
 Re: Spinning starter motor...
Posts: 544 |
You need a sprag cluch. Trying to start them with a low battery wares them out. You can 100% do it yourself.
Posts: 48 |
Thank you for the reply.. Wow.. That's an expensive item from triumph! I'll hunt around.. See what I can find. :-)
If the starter spins and doesn't engage anything, then you have one of two problems. 1st, the sprag clutch is slipping. Other fellows have had this happen. Make sure the battery is really charged up then try it again. It seems to slip when the battery is low on power. 12.7 is not that high for a charged battery. If it continues to slip, you might have to replace the sprag which is situated behind the left hand side engine case. It is part of the starter gear train. I think Grezgorz had to replace his some time ago.
The 2nd problem is a cracked case where the started idler gear rides. This is a major problem and could require the engine case to be replaced unless you have some machining skills.
Try the battery before pulling the side cover off.
Posts: 10,736 Likes: 8
Posts: 10,736 Likes: 8 |
the magnets inside my starter casing imploded recently and my bike wouldn't start either... hopefully yours is as easy to fix, the cracked engine case would be my worst fear
Posts: 48 |
Thanks for the replies guys. I'll give the battery a go first.. (I could hook it up to the car battery (with the car off) for a test yeah?
No problem there.
Posts: 544 |
Cross your fingers thsts its not a bad case. And if you turn out s.o.l. - I have 100% new sprag clutch set up. Mine did the same, I bought all the stuff to do the sprag ro find out the case was cracked. So now they're in a box.
Posts: 544 |
What was your symptom on that one? Hard current draw with no spin?
Yeah, but no spin of the starter motor either, just the click of the solenoid, the drop in voltage. my saga
Posts: 544 |
Haha oh man.. read threw that, carbon copy to my other bike.. its kick start only now..
Posts: 544 |
Well to add to that I rebuilt the starter twice to to not have it work. Found out last month when I was rewireing it that it had a dead "saftey relay" that only that year had and no one ever mentions on any fourm on this planet.... I bet.. I never looked....
Posts: 23,248 Likes: 64
Posts: 23,248 Likes: 64 |
Things like this is why a kicker would be so good. Broken case at the starter gear would not be such a big deal if you could still kick start it.
Posts: 688 |
EFI 865s don't have the case problem so no kicker needed. Just push start the older ones.
2011 Triumph America (10/2011 to 07/2014)
2012 Harley Davidson 1200C Sportster
2014 Harley Davidson Dyna Wide Glide
Posts: 1,690 |
Shoot...my 2005 is doing the same thing...but the problem goes away once the engine is warm...starts fine everytime, only when cold does she do this....Seems that if the broken case was the problem, it would do it all the time, right? Im thinking sprag clutch for mine....
probably
Posts: 3,816 |
for sure
Posts: 1,690 |
Got it out, not really seeing anything obviously worn or broken...no cracks anywhere on the case....$218...probably should do the clutch too since Im in there....
Make sure the wavy washer goes back where it belongs on re-assembly and everything is located correctly.
I replied on your other post but you are already there so .....  Let us know what's going on.
Posts: 1,690 |
$218.44 for this part....anybody have any ideas? No way to actually "fix" this part? If you could find a way to repair this part, someone could make ALOT of money! E-bay has nothing....crap!
try contacting Jryan and see if he still has the one he had still in the box.
Check with Pinwall Cycle on Ebay. Any of the 270 or 360 twin starter drive mechanisms should fit. Give em a call.
Posts: 386 |
Thanks for the info. Here is my present saga, Go to leave work at night. It is cold out. Bike wouldn't start, battery goes kaput and starter just spins.Get a jump it starts and go home. This thursday same thing, jump doesn't work, just spins. Trailor home.  Take clutch cover off and take sprag clutch out.Mind you I have afriend who is a very good mechanic helping . He checks sprag and cleans it. Says it is not that bad, it doing what it supposed to do. Triumph of daytona wanted $488.00 for sprag clutch and new cover gasket. bke bandit less than $300. Put cleaned old one back in and put back together. Disconnected plugs and tried it. Works so far. Was asked if I ever used a oil aditive. I did ,there was residue on got to hit a ace hardware fo a new bolt. Used RTV Blue to seal cover, Shouldn't leak. Will know tomorrow. Just turned 137,000 miles, Had a 120 miles on oil change, Saved oil.
Posts: 544 |
That's just about the best news ever right there
Posts: 5,068 Likes: 1
Posts: 5,068 Likes: 1 |
'speshly the part about the 137,000 miles wow !
Posts: 386 |
Bike works fine, so far. No leaks and runs good Had to wipe residue of additive off Had used it 2 oil changes ago hope it is not to much left in motor that can gum up clutch again . road about 10 miles so far. Had warrenty work on bike done about 10-11 years ago and they had a different bolt in cover. Only 2nd time that cover been off. Next comes a new battery.
Posts: 1,690 |
Stupid bikebandit tells me 3 weeks later that the part is "no longer available"...whatever that means...bike still sitting, nearly 2 months now....The bike has never had a brand new battery, always "re-conditioned"....Think Im just gonna buy a brand new battery and put the thing back together....
Posts: 1,690 |
Problem found.....the boss that holds the pin for the starter gear is cracked...about 1/8th to 1/4 inch long (not sure exactly), and only in one place...Devastating find. My only hope at this point is to find an expert welder that can close the crack up, and zap it with a MIG or TIG welder...I missed the crack before somehow, but it's definitely there...65,000 miles on the bike, and if it can't be fixxed by welding, It will be a total loss, as $2000 for a salvage engine, labor and all, simply won't be worth it...$4700 for a lower engine half from Triumph...Any ideas for the disposition of this bike would be welcome....
Posts: 514 Likes: 2
Posts: 514 Likes: 2 |
you could have a ring made that fits over the boss. the ring would have to have a thick wall of probably 3/8" and make the ring as long as you can. the bore needs to be an interference fit on the boss. If you measure the diameter with a micrometer you can file it round enough so that when the ring is tapped on it will keep the boss together. You could also use JB weld to strengthen the casing by putting it around the ring and over some of the webs nearby. I'm a machinist and could make the piece for you. Another way to keep the ring from trying to move is putting a couple of bolts from the OD to the case and when the bolt is snug tighten it with a locknut. Basically it's what we call a 'spider'. It's an easy fix. e mail me at blymeylymey@gmail.com Des
Posts: 1,690 |
Got the collar installed, looks good....new gasket installed for the side cover, but the cover won't seal around starter housing area....leaks as fast as I put the oil in...something holding the cover off...I have 2 washers, one is a flat washer, the other a thin "wavy" washer...any idea which one goes where? Should the thin wavy washer go on before the gear or the flat washer? Can't find a parts manual reference...right now, the flat washer is on first, then the gear, then the wavy washer...Im hoping the washer configuration is holding it off...will try swapping the position of them tomorrow....e-gad!
I don't show 2 washers in my manual, I have not had that apart so I have not seen them 1st hand. When you put the collar on did it seat all they way in? The collar couldn't be preventing the gear from sliding in to it's proper position?
I know that wavy washer goes on the outside of the gear
I didn't check, but isn't there a exploded drawing on the BikeBandit website available? Yes, I guess there is.  #6 is the wavy washer
Posts: 1,690 |
Side cover back on, no leaks, everything back together, hit the starter, and same CRAP...turns crank maybe 1 revolution every 4th or 5th try, then just spins....PIECE OF CRAP! Anyone want a POS America????
If the intermediate gear is fixed sounds like the sprag clutch is bad.
if it was cheap enough and you were close enough I would take it.
Posts: 1,690 |
Guess I'll have to come up with another $200....piss poor design....
I wonder if the sprag clutch contributed to the failure, slipping then catching putting extra stress on the case.
Hey Mark. How did you repair the case. Did you get one of these and fill in the missing metal?  Ian's point is also one you have to consider. Can't remember who had a sprag clutch issue not long ago due to adding some kind of snake oil additive which cause the sprag to slip.
Posts: 1,690 |
No, did'nt have a repair THAT elaborate, just a steel 1/8th inch "sleeve" fabricated to a close tolerance fit, then tapped it over the boss and applied JB weld...repair looks good, and the sprag clutch shipped yesterday (the 25th)...should be here in a few days maybe...
Posts: 1,690 |
BTW, where did you get that part from? Looks great!
Posts: 1,690 |
I suggest THAT mod for EVERY America and Speedmaster! Well worth the money, just a matter of time peeps....My bike is starting and running fine now..Sprag clutch fixed it...
Posts: 1,485 |
So I'm installing one of these. First time inside the motor so just a bit apprehensive. Get to the part of sliding off the clutch cover and it seems to be hanging on the gearshift shaft. Much tugging and pulling later it just pops off, probably just like it should have to begin with. Get to looking around and I notice the shaft is slightly bent. Any body ever seen this? I couldn't have bent it while wrestling with the cover, could I have? I'd like to think it's sturdier than that. Maybe it happened when I was kamikazied by the deer a few years back. How big a deal is this?
Anyway got the Safe-Start piece on and I'm letting it cure. I'll be reassembling in the next week or so. So what's the best way to get the new gasket on? I'd like to get it right the first time for a cahnge.
Thanks...
If the shaft isn't bent badly enough to cause a leak or bind I wouldn't worry about it. You can put some strategic dabs of silicone to hold the gasket in place until assembled.
Posts: 1,485 |
Cool on both points...thanks.
Posts: 48 |
Sooo… getting back to this after a long winter of doing nothing… which side is the starter motor located?
Posts: 48 |
i took the right side off…. not sure any of that looks right.
Posts: 48 |
Last stupid question for day. Is the left side dry or full of oil when I take the case off. :-)
Yes, there will be some oil, have a drain pan ready. It is a wet clutch after all.
Posts: 48 |
Got the cover off... Yeah it's buggerwd. Will post some pics once I've stopped crying... Something's slipped and is eating the case !
Posts: 1,586 Likes: 1
Posts: 1,586 Likes: 1 |
That was mine with a broken case.
Posts: 37 |
I know this is a little late to the game... A few years back I had the same problem with the boss on both the engine and the outer case crack and drop the gear and shaft out of position. My solution was to run a pin though the hollow shaft that holds the gear, drill a 3/8" hole in the center of each boss and reassemble. Coincidently I had the cover off for the first time last weekend and everything is fine, no wear or loose pin. I think it was a couple $100 when done, maily because I bought another engine cover and drilled that, the boss on the original was badly torn up and I was concerned it wouldn't hold. Anyway, I have added 15k miles to the bike since then including a trip to Key West and back with no issues. Considering I was being quoted for a new engine plus labor ...thousands of dollars, I thought this was the better alternative.
Thanks Max for the update. Didn't you post some pictures of the mods you made to the starter idler gear shaft and boss some time ago or was it another fellow? I read about this fix some time ago and wondered how well it lasted. Much appreciated.
