 Re: Rinehart slip-ons
Posts: 5,268 Likes: 16
Posts: 5,268 Likes: 16 |
Post a sound clip when you get those mounted up
Posts: 1,160 |
Ya if you can take a pic looking through them too. I would like more info once you get them and install them
Life need a little Triumph!
They have the look. Do they have the sound?
Posts: 6 |
Pic thief lol. See what I started.
Posts: 242 |
Hell of a deal !! Have friends with Rinehart mufflers on their Harley,s. They sound great. Just ordered a set for my America too. Can't wait to try em out.
08 America
Rinehart exhaust, Clearview shield, Viking bags and magic carb's
Posts: 124 |
guilty as charged. but it was such a fine example.
Posts: 457 |
My goodness, those look great. Please do post a clip with sound and, if possible, a pic of how they're mounted.
Posts: 3 |
Ordered mine. Cant wail to post a pic of my speedy.
Posts: 124 |
Got the Rineharts in late yesterday. Here's some pics prior to install. The Can  The End View  From the intake side
Posts: 42 |
Any idea how much rejetting they would require those look great.
Posts: 457 |
i'd probably use the jetting calculator and use the TORs setting.
Posts: 124 |
Here is a quick and dirty sound clip of the Rineharts. They sound so good in person... http://www.youtube.com/watch?v=nJ8HqXzE3dU
Posts: 42 |
I have epco's on now so hopefully it will be close.
Posts: 457 |
nice. even nicer: got the okay from the missus to get them in a couple weeks. yusssss!
Posts: 42 |
So, I'm not the only one. I feel a little better now. Maybe I should press my luck and go for the new coils at the same time.
Posts: 457 |
game_on, why aren't you sticking with the epcos? they're pretty nice from my understanding?
Posts: 42 |
I've had them for about 8 years they are great pipes,just feel like it's time to try a different look and sound and it's hard to beat that price.
Posts: 457 |
Posts: 1,160 |
Hay game on I would bet they would be the same jetting as emgo's they look very open. When you get them on do a before and after video if you can. I like the look of them and I am running emgo's I want a different sound.
Posts: 3 |
Posts: 42 |
I will see what I can do but I am what is called technologically challenged. I'm thinking it will work out fine right now I am running a little rich.
Posts: 3 |
Cool eh?
Posts: 42 |
Ok since I am copying everyone else, mine showed up today and I have one question: how did you all mount the rear of the pipes or are you just letting the header carry the weight. I was thinking about maybe a clamp on the lower frame tube going to the mounting brackets?
Posts: 124 |
Right now they are just hanging on the header. Doing just fine. I'll rig up mounts to the frame tube or center stand mounts shortly.
Posts: 1,160 |
I want a set so bad right now!!!
Posts: 457 |
Posts: 42 |
I don't know how the roads are where you are but up here they suck. I have a 3 mile stretch on the way to work which most resembles riding a jackhammer. I'm not sure I would trust it. I might try a heavy duty clamp on the frame tube with a piece of steel going to the bracket. If that doesn't work I have a friend who can weld something up.
Posts: 242 |
Just did about 250 miles today with mine just hanging on the header. No problems but I still plan on rigging some type of rear bracket. They sound so awesome. Really love em !!
08 America
Posts: 43 |
do the carbs need rejetted 2003 america
I love to go swimmin with bow legged women!
Posts: 457 |
Yeah. They will. I'm wondering how everyone's setting the jetting calculator for these?
Posts: 69 |
I have had mine on for about 4 or 5 years...no hangers...no problems, the sound is kickass [image]http://  [/image]
Posts: 3,937 |
How about a close up of your header wrap.
Did you lay a string or something over it and spray it with color wrap paint to get that "Marbled" look? Or am I losing my mind?
NICE!
And you may see me tonight
With an illegal smile
J. Prine
Posts: 457 |
just installed mine. very happy. using my same jetting as i had with my fully debaffled stock pipes. no brackets, i think they'll be fine. the mounts are kinda in a wonky spot for fabbing something up. big ups on my lady for the present.
Posts: 42 |
finally put mine on they sound great but I feel like I lost some low end power espically on take off I need to wind it up a little bit to get the same launch. Could this be due to the wider diameter exhaust causing a loss of backpressure? Or will I need to re-jet, any suggestions?
It does sound as if you need to add a restrictor to get your low end back. The torque at low RPM on these motors is paltry to begin with, so there you go.
Posts: 457 |
if youre still using the stock jets, use the calculator http://www.bonnevilleamerica.com/dinqua/friar/i'm doing pretty alright with it set up for fully debaffled stock cans.
Posts: 3,937 |
Milo appears to be "Out-of-the-Office" right now? Has only one post in three months. Shame, I REALLY wanted to see that pattern up close, or hear how he did it.
J. Prine
Posts: 457 |
so since these pipes are made for harleys, they're both expected to be on one side of the bike. putting one on the left means that either the brackets or the 'rinehart' etching will be kinda wonky.
to remedy this, i removed the tips and used a long no.7 drill to center a hole across from the middle one. the threads are 1/4-20, if anyone cares.
i'm also thinking about wrapping the baffles in fiberglass in the hopes of quieting them down a little bit. i like the sound as is, but i get off work at 2am, and would rather not wake the neighbors. yesterday, one plugged his ears as i rounded the corner on my way out.
Posts: 457 |
so i just packed the cans with fiberglass and i really like the sound better. i'll have to get a video later, i promised i'd take grandma out.
anyway, i wouldn't say it's subdued. off throttle it might be a little. i dunno. usually i'm better making words cooperate with other words. i like it. less hollow sounding. i also felt like the backpressure helps. i debaffled my stockers maybe 2 years ago and forgot what torque was.
the glass was eleven bucks at cycle gear, and cut in half it fit perfectly. i'd say go for it just to hear it in person. if you don't like it you're out not very much.
