Re: Star Bolt
outerbanks #517473 05/08/2013 8:50 PM
When you see a boxer twin like this classic what comes to mind first? BMW of course. But this bike is a Harley-Davidson built during WW2 at the request of the U.S. Army when they saw the shaft drive German BMWs performance in harsh desert enviroment. After the war Harley could have continued to build and improve in the boxer twin design but I suppose they decided that wasn't their style.
According to a Popular Mechanics writeup in, maybe, '44 the opposed twin XA and the Indian Guzzi were both way underpowered as compared to the 45 inch WLA V twin, and more expensive to build.
Oddly enough, the first BMW opposed twin was based on a 1920's HD model and another flat twin made in the UK.
Re: Star Bolt
Greybeard #517474 05/08/2013 9:11 PM
Douglas had a motor like that. As did another manufacturer of that era that I can't recall right now. Starts with a "G" I believe, 7 letters.
I wish I knew why my brain works (or doesn't work) the way it does!
Re: Star Bolt
Hermit #517475 05/08/2013 10:31 PM
Douglas Dragonfly
Ride like you mean it.
Re: Star Bolt
Greybeard #517476 05/09/2013 5:24 AM
Wow and I thought the rear cycinder of a V-twin didn't get enough cooling air flow. That configuration had to run HOT!
Acording to war experience in the North African desert the BMW longitudinal mounted boxer twin ran much cooler than Harley's V-twin and the BMW shaft drive was far more reliable without maintenance than a chain in desert sand.
edit: You are correct the original Harley-copy of the BMW boxer twin was more expensive but that's to be expected since Harley had to quickly design and produce all new tooling to build the engine and shaft drives will be more expensive than chain. As for power the Harley XA was a side valve and by the time it hit the front BMW had advanced to overhead valves for more power.
Of course it hardly mattered because the U.S.Army quickly realized the Jeep was the ultimate all-terrain durable messenger/scout vehicle. It was also incredibly versatile performing jobs no motorcycle could match.
Re: Star Bolt
erle #517477 05/10/2013 4:27 AM
Just read in a Mag 46 HP and 55 Ft Lbs Torque for the mighty bolt!
That's ALMOST as bad as ours!
Yamaha lists the Bolt at 540 lbs - 10 pounds less than an America so acceleration should be ok for a cruiser.
I would think a mag would just run it on a dyno and would not be listing crankshaft horsepower.
Re: Star Bolt
outerbanks #517478 05/10/2013 7:41 AM
Some magazine reviews list dyno numbers.
Some show the dyno chart, which often tells more than the raw numbers.
Kevin - Luceo Non Uro
Re: Star Bolt
outerbanks #517479 05/19/2013 5:16 AM
...Yamaha lists the Bolt at 540 lbs - 10 pounds less than an America so acceleration should be ok for a cruiser.
Prefires check in at 497 dry. Triumph's addition of 53 lbs to our rides is another line item on a long list of sorrow.
Re: Star Bolt
moe #517480 05/19/2013 10:03 AM
Star Bolt.
Air cooled V-Twin - check
Belt drive - check
Sportster styling - check
And now Star is bragging the Bolt has real steel fenders just like Harley.
Just get the real thing.
Re: Star Bolt
outerbanks #517481 05/20/2013 5:16 AM
Druthers...
Rather have the modern engineering of the Yamaha than the alchemy of the Hardley Davidson.
Although is it mystical every time I walk into a HD apothecary.
Re: Star Bolt
moe #517482 05/21/2013 9:17 PM
If the Bolt runs like Yamaha has made the Stratoliners and Raiders run, I d bet it moves quite well. HD cant keep up with the Strats or Raiders, unless they spend tens of thousands more just to get close.
Re: Star Bolt
HeneryHawk #517483 05/23/2013 8:06 PM
Here is an interesting article.... Sportster vs Bolt vs Bonneville
Re: Star Bolt
BCarnage #517484 05/28/2013 9:40 PM
Seems like more often than not, the Triumph shreds the competition in these comparisons, even with the America and Speedmaster going against cruisers. Displacement and torque can get any bike down the road, but useable range and handling, along with a smooth ride usually win the overall prize.
Re: Star Bolt
roadworthy #517485 05/30/2013 11:17 AM
A article in last month's Motorcyclist magazine quotes Star Corporate as stating that design cues came, not from the Sportster, but as a natural extension of the Yamaha XS650 (as customized by owners). O...kay.
Re: Star Bolt
Hermit #517486 05/30/2013 1:26 PM
They used to have a Virtual Bike Show on their site, here, but it does not appear to be working at the moment. It was pretty cool to see what people had done to customize their bikes. I think every brand should have something like that on their site.
Re: Star Bolt
Hermit #517487 05/31/2013 5:16 AM
...a natural extension of the Yamaha XS650 (as customized by owners.)
The xs650 EXUDES Hardley's sportster v twin looks. NOT.
Re: Star Bolt
moe #517488 05/31/2013 3:31 PM
Well, like I said much earlier in this thread, I think this Star Bolt WOULD HAVE made a great looking Street Tracker, and ESPECIALLY because of two reasons:
First, most of the BEST looking custom XS650's people will see out there on the road HAVE been turned into Street Trackers.
And Secondly, other than Harley's XR1200, there STILL is not one major M/C manufacturer that has tried to tap into the Street Tracker market, which I believe has the potential to expand at this time.
Yep, all Yamaha/Star has done is make another copy of the Cruiser-ish Sportster models, THAT'S all....yawn!
Re: Star Bolt
moe #517489 05/31/2013 3:39 PM
True, but they're one of, if not the number one, motor of choice right now for garage built, low buck bobbers.
Re: Star Bolt
Dwight #517490 05/31/2013 3:44 PM
...First, most of the BEST looking custom XS650's people will see out there on the road HAVE been turned into Street Trackers.
What ya got in that 401K!???
Just thinkin' out poud.
Re: Star Bolt
erle #517491 05/31/2013 3:45 PM
Yeah, but evidently AND unfortunately erle, it LOOKS like they're turnin' 'em into monstrosities like the one Jim just posted a pic of up there!!!
Re: Star Bolt
Dwight #517492 05/31/2013 3:47 PM
Yeah, to quote the FIRST response I got when I joined this site, "Not my cup of tea."
Re: Star Bolt
BCarnage #517493 06/06/2013 3:26 PM
That 360 degree Bonneville runs away from the America too. its a zippy bike. The America runs mid 14s in the 1/4.
I like the Bolt. Yamaha makes a very good V-twin. I think it will sell well.
Re: Star Bolt
satxron #517494 06/07/2013 4:09 AM
First lines of the test summed it up nicely:
There’s no disguising what bike Star Motorcycles had in its sights when the 2014 Bolt was released. And with good reason. The Sportster has been a best-selling model for Harley-Davidson for ages and has made it into the production line yearly since 1957.
The Star is just another copy.
The Bonneville is unmistakable, a Triumph. Might be why I've heard so many compliments on my Triumph from Harley owners. Albeit usually old, giezer Harley owners...
Re: Star Bolt
outerbanks #517495 06/15/2013 11:09 PM
Tested one today (well, OK, technically yesterday). Here's the summary, post # 859 here: ADV Bolt Thread
I could not wait to get back on my SM.
Re: Star Bolt
B02S4 #517496 06/17/2013 2:18 AM
I tested one today also. I just happened to be riding by a big multi-brand shop on my way out of town and saw the truck. There was no line. Well happy Father's day to me...
I like the way B02S4 did his review (so I'm using that as my outline), though I don't know or perhaps just didn't pay as much attention to details,but...
The good:
great cornering/handling. The bars were pretty comfy and the bike does feel much lighter than it is.
strong low-end torque, yes the extra bit of torque was nice and noticeable. We got on the freeway and it was right at 70mph no problem and very quickly.
I thought the suspension was good.
sounds great at idle
I also thought it seemed small and actually wanted to put my feet out a little farther, I'm 5'10" with a 31 " inseam and I felt a little cramped.
I really like the seat.
decent brakes
I also thought the bike seemed of pretty decent quality as well.
I fell like the only one in the world who likes that taillight. Maybe it's because I just put a 34 ford taillight on my bike.
The bad
No tach
I thought it shifted kind of clunky, and I got a lot of false neutrals.
I felt like I ran through the gears rather quickly
The exhaust, all modern Yamaha's have ugly exhausts. It would be my first thing to change.
The whatever
That digital display, though I like the placement was a pain to see. Weird that it is so dark. It actually might be better at night.
I also don't have any problem with the seam in the tank. It doesn't bother me and never has, on any bike. People seem to go on about it.
Overall it has a lot of the styling's that I have done to my Speedmaster. I have no need to buy a bike similar to my own but I really enjoyed riding it and I hope it does well for Yamaha. I would recommend one to a friend especially if they are shorter in stature than myself. Like our bikes, I think it is a good size that a person may have for a very long time because it is pretty versatile.
Re: Star Bolt
BCarnage #517497 06/28/2013 1:28 PM
I was in the neighborhood yesterday and stopped by the dealer. He tried to get me to take a test ride, but since I was dressed in my usual attire of shorts, T shirt and flip flops, I declined. After all; this is a real motorcycle - not a scooter! Anyway, it sat pretty nice. Maybe good for a couple hundred miles w/o complaint. Dealer says he's sold about 15 so far.
Re: Star Bolt
Hermit #517498 06/28/2013 4:04 PM
Arg, nice looking bike for the most part but the exhaust and the front forks got to go, the front end looks week in comparison to the rest of the bike, kind of like having a big chest and arms then real skinny legs!
