Page 1 of 3 1 2 3
Foot peg relocation brackets
#515326 03/24/2013 11:56 PM
Going to get these on the bike this week (God willing) but thought I would post a couple pictures along the way. Having installed the 2-1 pipe in Dec, I've been working out the best way to relocate the controls and came up with a couple mounting plates as close to the frame as possible which will have 'busa controls mounted.
The original pattern for the mounting plates was more intricate, but the setup costs for the water-jet & mill were too costly. I ended up creating most of the CAD drawing myself in order to reduce costs, so this simplified design made it a little easier on me as well.
As a reference, the pegs sit about 4.5" below the swing arm bolt & the new shift lever clears the gear shaft assembly/lever by about 1/2". The toe of the new lever is slightly in front of the gear shaft.
I'll put up more pictures when I mount them.
This is a rough mock up while checking fitment. The sprocket cover will cover a portion after some "trimming"
Re: Foot peg relocation brackets
dardoonk #515327 03/25/2013 6:22 AM
very nice set up
chuckyj #515328 03/25/2013 7:37 AM
Pretty amazing. Show some pictures with you sitting on it - would be easier to see the proportion and ergonomics in this position!
Dan
MOTOSICKLE #515329 03/25/2013 1:03 PM
NICE!!!
Edwin #515330 03/25/2013 7:13 PM
oh jeez, can you trace them with dimensions for me (us) please??? i could totally counterfit some on the mill at work!
steve0suprem0 #515331 03/25/2013 8:42 PM
Trace them??? Hell, I was the one that made the drawings!
These were the first cut, so I had to make a couple alterations when fitting them. I need to make those corrections before more are made. Also, bear in mind, I've fitted a Tec 2-1 pipe, so I am not even sure if the current design will clear the stock pipes.
dardoonk #515332 03/26/2013 5:19 PM
these were the first cut, so I had to make a couple alterations when fitting them. I need to make those corrections before more are made. Also, bear in mind, I've fitted a Tec 2-1 pipe, so I am not even sure if the current design will clear the stock pipes.
Let ME know if ya have to throw them away and start over!
erle #515333 03/26/2013 7:36 PM
Uhm.....Ditto!! Nice work
dardoonk #515334 03/26/2013 8:19 PM
so uh... are you willing to share?
steve0suprem0 #515335 03/30/2013 6:03 AM
my son is very interested in how these go as he would like them on his speedmaster (when he buys it).
Duck Road Rabble MHi
duck #515336 03/30/2013 10:40 PM
OK, so I haven't got them completely on yet, but here's where I stand. On both brackets, minor adjustments are still needed to simplify the installation in the future. I made everything fit, but the right peg holes needs to move forward & down about 3/8". On the left bracket, the lower bracket mounting hole & the location of the peg holes need to be lowered about 1/4" to 3/8". Each of these changes are needed so mounting bolts clear the frame without modification.
Here's a teaser pic of my fat arse on the peg. I am 6' tall with a 33" inseam. My seat is about 1/2" lower than factory.
Will post more as I finish.
duck #515337 03/31/2013 7:51 AM
Oooh, me likey :-) I'm thinking that might get me back on the America and off the standard.
dardoonk #515338 03/31/2013 12:30 PM
Beautiful design and machining here, Kurt!
Ya know, a while back I did something very similar to what you're doing here, and I gotta say having my feet placement underneath me and the controls there like that just feels more natural than having then out there in front, besides the fact that I no longer am having to sit on my tailbone and the subsequent lower back pain which I found often accompanied such a peg location...especially when I'd hit some larger bumps in the road.
One question here: I can't quite figure out how or where your brackets attach to the bike. Would you expand upon this for me, please?
(...oh, and btw, I like your exhaust system there too...looks like an Arrow 2-into-1...is that correct?)
dardoonk #515339 03/31/2013 1:49 PM
Sign me up! Id love to give those a shot.
Looking forward to hearing about the test ride and clearance when cornering.
Also adding this thread to my favs. Ill be following this for sure.
Zmilin #515340 03/31/2013 10:58 PM
sign me up to
duck #515341 04/02/2013 10:37 PM
... Need to bleed the rear brake & re-jet for the new pipe.. Took her for a short spin this eve. Pegs are comfortable & shifting is solid with no play. Overall, I am very pleased. There is some work to be done before I would offer them to anyone..
Three holes don't give enough room for bolt clearances in the back & trying to use the bolt hole for the brake switch as a mounting point proved pointless. The top bolt on each footpeg intrudes on the frame just below where the swing arm pinch bolts attach. In order to fit these brackets, I had to trim the frame a bit. Nothing major & all excess metal anyway. Regardless, it needs changed.
My original plan was to counter-sink the holes that mount the plates to the bike, but I had to cut down on the machine costs.
Here it is finished with the modified sprocket cover in place.
Left side.... I tried to give view to put some perspective on the clearance.
Right side.... you can see the three hex bolts behind the master cylinder that bolt thru the frame.
dardoonk #515342 04/02/2013 10:39 PM
Here's the sprocket cover now.
dardoonk #515343 04/03/2013 4:32 AM
As said months ago - want one!!!
Very good work!
Dan
MOTOSICKLE #515344 04/04/2013 5:16 AM
very nice work son will want one as well
duck #515345 04/04/2013 7:12 AM
nice work. that 2 into 1 exhaust and the mid mount controls really change the whole look of the bike.
dardoonk #515346 04/06/2013 8:51 AM
You going to try and make some extra cash ??? How much ? Enquiring minds want to know !
hill8586 #515347 04/11/2013 7:28 PM
very nice
02 bonneville america, only bike i've owned, bought new. tpusa 994 big bore, Carillo rods, stage one head work, fcr 39 carbs, bc bomber pipes
deuk #515348 04/20/2013 11:58 PM
Very nice work, looks solid. Maybe I'm a jerk but why didn't you just buy a bonnie?
MercKing #515349 04/30/2013 2:38 PM
So hows it going? Did you finish your pegs? We all want them...
Well I want them!
Dan
MOTOSICKLE #515350 05/01/2013 8:20 PM
Well I want them!
Dan
I was just thinking the same thing. Status? You making any to sell off? Brackets only would be fine for me.
Zmilin #515351 05/01/2013 9:34 PM
ya,i would entertain that mid mount as well, might be much nicer for balance and back stuff :-) or it could be i am just getting to bloody old! LOL
edmspeedmaster #515352 05/09/2013 11:17 PM
Sorry guys.. Little JR is 11 months old & my job has had me swamped. I'd like to sell a few off for whatever they cost me to get made plus whatever any member would want to pitch in to help me cover paying the CAD guy who set up the program. I figure if 10-12 guys want to get them & they pitched in $15 bucks above whatever they charge me to make them, I'd be happy.. I have $300 bucks tied up in the original set including the CAD work. These are 1/2 alum plate that is cut on a water-jet & only a single copy. Additional sets would cost much less, especially if they were going to make a number of copies. If I could get a head count of who is seriously interested, I'll get a price from them... Selling price would be whatever they charge + shipping + any "donation" to help me feel like I didn't just blow as much money as I did...
I would propose I make a couple alterations now that I have installed these. Mostly, they are inconsequential, but would allow some flexibility to anyone choosing different rear-sets to install.
1] I will modify the mounting bolt hole locations. Only two are needed & one bolt head interfered with a peg mount anyway. I originally intended to recess the mounting bolts, but that required additional machine time, & I had to cut costs.
2] Minor change to the area where the rear-sets attach is needed to allow for other pegs & to clearance a piece of the frame just in front of the swing arm. I had to grind a bit away in order to fit one of the bolts.
3] I would recommend that the holes to bolt the rear sets be drilled at the time of install, rather than at the machine shop. Primarily, this would be to allow different donor parts to be used. I trust anyone wanting to do this would be competent enough to get 6 holes in the right place.
FYI-- sure, I blew off posting anything here (don't shoot me), but I found time to make mod #3 this year..
http://www.bonnevilleamerica.com/forums/...vc=#Post593254
MercKing #515353 05/09/2013 11:24 PM
No offense taken... I've asked myself that for about 4 years now... bottom line: this is paid for & I'd just end up tearing crap off a Bonnie and changing it anyway..
Plus, if I want to ride more "spirited/ retro feel" than the America wants to deliver, I break this out..
dardoonk #515354 05/10/2013 8:56 AM
Ok I am in...would like a set
SDKimo #515355 05/10/2013 11:00 AM
hey Kurt any chance you can post a pic with you on the bike, i would like to see where your legs and feet and up and the angle of the shifter etc. that would be great, but this might be the answer to my "can't find that sweet spot" seating position for my SM. thanks.
edmspeedmaster #515356 05/10/2013 12:42 PM
I'll snap a couple this weekend.
dardoonk #515357 05/11/2013 1:20 AM
good stuff, thanks.
edmspeedmaster #515358 06/13/2013 10:15 AM
I've had some plate steel sitting around for about 5 years thinking I would get around to making myself some of these too... hasn't happened yet Keep us posted!
dardoonk #515359 06/14/2013 7:44 PM
Count me in for a set.
Zmilin #515360 06/14/2013 7:47 PM
heck... Depending on price maybe two sets.
BTW... If you have the drawings or program I can check with the guy that does my plates on pricing.
Zmilin #515361 06/14/2013 8:47 PM
I'll commit to a set. let us know.
Ryk #515362 06/15/2013 12:35 AM
me too!
edmspeedmaster #515363 06/21/2013 5:53 PM
Holy crap. Me too. I need a set
jryan #515364 06/30/2013 1:37 PM
I would be in on a set!!! Even the Cad drawing for a donation
2004 Speedmaster, British Customs Bomber exhaust, Airbox removal, 45,000 smiles and counting!
saskhinckley #515365 07/05/2013 2:58 AM
After showing us your Plastidiped bike ( New Look for America ),
we DO want the brackets even more!!!
Dan
MOTOSICKLE #515366 07/05/2013 4:16 PM
I've got enough people saying they'd be intersted, so I will go by the machine shop next week and discuss numbers with them on getting them done in bulk.
dardoonk #515367 07/05/2013 11:41 PM
Hey, we will sign an oath in synthetic motor oil, please do
Ryk #515368 07/06/2013 7:56 AM
He'd have to settle on taking my 1st child as collateral.
The high cost of synthetic these days make that prohibitive.
erle #515369 07/08/2013 2:05 PM
edmspeedmaster #515370 07/25/2013 7:15 AM
Please add me to the list mate. Would love some mid mounts then just stick the old pegs on the front for bad ass clamshell cruisin haha
Keenaz #515371 09/09/2013 9:29 PM
Are there any updates on dardoonk's mid controls for the Speed/America?
Thanks,
53bsa
53bsa #515372 09/10/2013 7:26 AM
Ive been in touch via PM and just waiting on a response.
Keenaz #515373 09/10/2013 9:48 PM
Keenaz.
Can you let us know when you hear something?
Thanks.
53bsa
53bsa #515374 09/12/2013 10:49 AM
edmspeedmaster #515375 09/22/2013 4:46 AM
Unfortunately I think Kurt's not been well so no response yet. Here's hoping he's on the mend!
Keenaz #515376 10/10/2013 2:45 AM
I'm wondering if anybody knows whether or not dardoonk has got any further with getting the brackets made. If it would be acceptable with dardoonk i could make the brackets for the people that want them. I certainly don't want to steal his idea, but maybe i could work with him and it would also expand the range of the parts i make. Des, AAMMP
mcfcinusa #515377 10/12/2013 1:29 PM
I replied to the wrong thing...
mcfcinusa #515378 01/12/2014 9:21 PM
Hey Des, I am wanting to move the footpegs and controls back towards the driver. Do you make a kit like that for the America or know of someone who does? Yes, have already seen the Norman Hyde kit on-line but wanted more of a change from feet-forward cruiser style to a mid-peg style for my 28" inseam legs. Thanks for a reply.
Ride to Live, Live to Ride.
frankfxwork #515379 01/12/2014 11:27 PM
Those are called Bonnevilles
Ryk #515380 01/13/2014 9:59 AM
I used the mounts from Des, 2 back and 1 down. They made a big difference, more that you may think. Highly Recommended.
Tin Man 2
Ryk #515381 01/13/2014 9:06 PM
Thanks Ryk. Have tried the Bonneville T-100 and liked it for myself but found it too cramped to be enjoyable for two-up riding for a week or two at a time. Think that if I can modify the America enough it will be comfortable and functional as a light-weight cruiser. So what has been the experience of riders using the Norman Hyde-type mod vs the much greater change to a mid-peg mod? There have got to be a number of riders 5'8" or less with a 28" inseam out there.
tinmantwo #515382 01/13/2014 9:38 PM
Thanks TM2. So how do we get these recommended mounts?
frankfxwork #515383 01/14/2014 4:38 AM
frankfxwork, just seen your posting. I have a website, aacycleproducts.com to show you what i make. I have been having problems with the site not accepting orders and i have to get it sorted out. Please e mail me at blymeylymey@gmail.com Thanks Des.
mcfcinusa #515384 01/14/2014 4:41 AM
Tin Man 2, thanks for the kind words. You made an old geezer smile a bit. Des.
Keenaz #515385 02/26/2014 3:04 PM
any updates on kurts mids?
MikeVanTso #515386 02/26/2014 6:41 PM
Once i have a set of pegs & levers & master cyl. from whichever bike they come from i can "reverse engineer" the adapter brackets that bolt to the frame.
If someone has a drawing i can make them from that too.
I've not heard from the original maker/designer of the brackets.
Do people only want brackets made or are they looking for a complete kit that bolts up straight out of the box? I don't know how much it would cost or what people are willing to pay for this type of modification. Des.
mcfcinusa #515387 02/26/2014 11:45 PM
des, i think ideally we'd like to just remove tyhe whole assembkly and bolt it back down in the back. i also think it's not that straight forward.
steve0suprem0 #515388 02/27/2014 12:22 AM
SteveO, the parts that are in the pictures definitely aren't off an America or a Speedmaster so if people just want to move their own controls further back i could come up with a bracket to do that. Seeing as i have a 2009 Speedmaster i can see what needs to be done.
If other members would give me some idea of what they want i can do it. The gear change mechanism is simple.
The rear brake would need another brake line making. It could be the regular brake line or maybe a Flexible SS hose type. I need input from other members so it's worth the effort. Des.
mcfcinusa #515389 02/27/2014 12:52 AM
My input: id like mid controls.
MikeVanTso #515390 02/27/2014 10:20 AM
The controls were off a Suzuki Hayabusa, "'busa controls mounted". There are some really nice after market sport bike controls. I had a set from Vortex on my Ninja...
https://www.vortexracing.com/shop/product/17343/1526/
As you can see they are adjustable up and down for fine tuning to the riders needs
SDKimo #515391 02/27/2014 8:45 PM
$400? who has that kinda money?
steve0suprem0 #515392 03/01/2014 1:09 AM
I'll start on designing brackets next week. Just finishing off a prototype for extending the pegs forward for bikes up to 2011. Left side is done & right side is testing my patience.
mcfcinusa #515393 03/01/2014 3:41 PM
Finished the prototype for the FPF (foot peg forward) kit. I'll get them posted on my website with more pictures. These fit America's & Speedmaster up to and including 2010. Price is $149.95 set.
Des Young AAMMP
steve0suprem0 #515394 03/02/2014 4:58 PM
Ture but they shift nice..you don't have to get these, there are a lot of stock sportbike rearsets on ebay...
steve0suprem0 #515395 03/05/2014 11:42 AM
So if I got a rearset you think you could make a set?..if so I will get a set off a common sport bike on ebay
SDKimo #515396 03/05/2014 2:56 PM
SD, The left side looks fairly straightforward. I haven't removed my chain cover on the right side yet.From what i have seen in other photo's people have had to cut the chain cover to allow the bracket to fit. Of course it all depends on what type of rear set is bought. I was thinking of making brackets for adapting the original/stock levers to fit . All manufacturers have their own dimensions so making a bracket to suit them all would be quite an undertaking. At least with using stock controls (which we all have) makes it a lot easier but who knows yet what may transpire once i get my scheming little brain in action.
mcfcinusa #515397 03/05/2014 5:06 PM
I agree stock controls would be best. I was just thinking that the ones in the picture were off a Hayabusa, if that had anything to do with it...For me there is no worries about the change cover I took it off, but when making something like this you need it to fit most bikes...A true mid-peg has been my holy grail search...
SDKimo #515398 03/07/2014 10:45 AM
This has been driving me crazy...I have been looking at the picture on page 1 and it looks like he drilled and tapped the plate what the swing arm mount to. So the big hole is where the swing arm nut is...
SDKimo #515399 03/07/2014 7:27 PM
Another idea..would need to add the mounts for sifter and brake
http://www.bonnevilleamerica.com/forums/...part=1&vc=1
SDKimo #515400 03/27/2014 1:10 PM
I'm sorry but i haven't got started on them yet. Lots of other stuff got in the way. I'll post an update on progress. Des.
mcfcinusa #515401 04/26/2014 6:06 AM
something like this would maybe sway number 1 son away from dreaming about a Yamaha bolt
duck #515402 04/27/2014 4:54 PM
that bolt is pretty rad, though.
steve0suprem0 #515403 04/27/2014 10:51 PM
I test rode the Bolt, just for fun, and I would say definitely in the same class as our bikes, and really fun to ride. Yamaha really knocked it out with that bike in my opinion. (except for that ugly exhaust pipe)
BCarnage #515404 05/08/2014 9:44 AM
edmspeedmaster #515405 06/16/2014 6:54 AM
any update on what is happening with these pegs
duck #515406 06/17/2014 1:31 AM
I do apologize to everyone wanting the midsets (at least that's what i call them). There's only one of me and enough work around the house for 10 of me. Plus the WORLD CUP has just begun and it only shows up every 4 years, anyway i'll dedicate some more time to the brackets. I bought some 1/2" thick aluminum a few weeks ago to make them from. Des.
mcfcinusa #515407 06/19/2014 6:59 AM
I Plus the WORLD CUP has just begun and it only shows up every 4 years,
I fully understand this...
As long you do not forget about the rest of us later...
Dan
MOTOSICKLE #515408 06/27/2014 4:30 AM
That's alright, do have any idea on what the cost would be
Thanks
duck #515409 06/28/2014 12:11 AM
Let me finish watching Football first. I've got to do some measuring and thinking first. Des.
mcfcinusa #515410 07/04/2014 12:54 AM
Today i received two emails from Kurt Darden aka dardoonk the original designer of the midsets. He sent me pictures and drawings of the brackets and then he called me on the phone and we talked for 45 minutes. He's given me the ok to use his design and make any modifications that may be needed so people can use their original gearshift and brake assys.
He's had some health issues which he's recovered from and is doing ok now.
We are going on vacation soon and will be fairly close to where he lives in North Carolina so i may get to meet him.
I've offered him my services as a machinist in return for passing the info. onto me. I told him that "if you can dream it, i can probably make it for you".
Just thought i'd pass the info along for people who know him.
mcfcinusa #515411 07/04/2014 2:36 PM
thanks for the update, des.
steve0suprem0 #515412 07/07/2014 10:39 AM
What...you are taking a vacation and not helping us out???,,,LOL have a good time...
SDKimo #515413 07/07/2014 12:36 PM
i would be in for a set of mid mounts
mcfcinusa #515414 07/14/2014 11:31 PM
It's been a long time, but I am happy to see someone is willing to pickup on my brackets. I've passed along my drawings. I've linked a couple pics below from a weekend at Deal's Gap last month. You'll see mine are set pretty far back, but they could be made a bit more forward, but would need different rear-sets (mine are from a 'busa) and probably set a little farther out.
In hard riding, my left tow scrapes if left under the shifter, so my toes are back on the peg in the pic. I had to remove those inch long feeler things too. I can "almost" get to the edge of the tread (Conti RoadAttack 2) I am running right now.
dardoonk #515415 07/15/2014 10:47 AM
Nice. That is what I am looking for
SDKimo #515416 07/17/2014 1:25 AM
I need to find out the types of finish people would want on the brackets.They will be made from Aluminum with a variety of finishes.
Powder coated ( any color you desire).
Unfinished ( just plain aluminum).
Polished.
Jewelling/engine turned ( overlapping circles).
If any one has any other ideas let me know Des.
mcfcinusa #515417 07/17/2014 3:33 AM
Just do them plain aluminium. Black or clear. Usually frames (where they are mounted to) are black...
Dan
MOTOSICKLE #515418 07/17/2014 9:59 AM
I would want black
dardoonk #515419 07/17/2014 10:02 AM
dardoonk
First off glad to see that you are up and about. Didn't you come up with a front brake bracket that allow you to mount 4 piston bakes?
SDKimo #515420 07/17/2014 11:32 PM
Yes, I run a Thruxton front rotor & a left 4 pot lifted of a Thunderbird (new one). It clears the front spoke by a little more than a quarter inch.
dardoonk #515421 05/23/2018 6:34 AM
I have been off the forum for the past couple of years and was wondering if the mid mount controls ever got off the ground and got made
duck #515422 05/24/2018 2:21 AM
@duck: Not as I know. There are still no readymades available. Nearest thing are the ones from Norman Hyde and eve they got less and less to sell. Our bike is not in production anymore, so special parts are not produced anymore.
Most of these relocation brackets weren't any real Mid-Pegs, just about 10cm (bout 3inches) closer to the rider.
But it is not so hard to produce one for yourself, you need sheet metal or thick aluminum to produce a plate (fixed mostly to the holes where the passenger foot pegs are mounted) and the place the original footpegs on these plates, finde a long enough linkage or use an exiting one from a donor bike and there you go...
All in all a two-day job if you got some low fabricating skills (including buying the stuff you need).
BUT: Make a cardboard mock-up first, measure twice before fabricating and make REALLY sure that the Plates are strong enough. Otherwise you shifter gear will break down and baddest thing: YOUR BRAKE WILL FALL OF!
So beware if you foo this by yur own - get some help by someone who knows what to do if you do not feel good about it.
MOTOSICKLE #515423 08/07/2018 8:03 AM
Never got round to making them, my lathe and mill are still in pieces after the move to NC. Can't promise anything yet till get machines running. Des. aacycleproducts.com
mcfcinusa #515424 09/10/2018 9:55 PM
Did these not get made? Anyone have the specs or CAD data for them? One of my employees' husband has a machine shop...
Mike_D #515425 09/11/2018 11:58 AM
I'm on vacation in England at the moment and don't have access to the drawings.i can send you the info when I return in a month.
mcfcinusa #515426 09/11/2018 2:06 PM
Excellent, thank you! Have an enjoyable vacation and a safe trip home.
Mike_D #515427 09/20/2019 11:38 AM
Does anybody know what happened to this thread? It just stops and there is no followup.....
prowler #515428 09/22/2019 12:02 PM
He has his shop open again, message him.
dardoonk #600270 06/07/2020 1:25 PM
Resurrecting the thread, I'm looking to add an extra set of pegs at the mid point. " not relocating the entire brake and gear shifter"
Just a second set to take some pressure off the tail bone. I believe Chy and a few others have this set up. Anyone one have any information on this mod? Pictures, and old set of brackets laying around your parts bin maybe?
dardoonk #600294 06/12/2020 11:35 PM
Just came upon this thread and need to let everyone know that i never got around to making the "mid mount" brackets that i said i would.
My wife died in January this year and i have just fell apart, so much that when i told my son in law to move out of my house due to him verbally abusing me that i snapped, the situation turned VERY ugly and this time last week i was put in jail. Bailed out after 3 days but have been charged with two Felony's and two Misdemeanors. I have retained an attorney that is confident that he can keep me out of prison.
Can't say any more on the issue but obviously i am not able to proceed forward and make them.
dardoonk #601176 12/06/2020 9:53 PM
did you ever find something to hang some pegs off of ? I have a pair of New Bonneville peg relocators for the passenger that might work for you they came from my 07 Speedmaster.
Page 1 of 3 1 2 3
