Re: My "Blue"...Transition - Update!
Fasteddy #507247 01/18/2013 8:54 AM
the brass would look good against a black engine too, black and gold go very well together.
Fasteddy #507248 01/30/2013 1:00 PM
Great choice on keeping the stock rear fender.
I can see why this stuff can get addicting. Photo's to come as soon as I get the handle bars squared away.
Drag bars for sure maybe Speedy (like the wider bar which will equate to better control). I placed Deuce risers on it, like it better than the Speedy Risers as it does bring them back more and up but gives the appearance of sitting much much lower. Had to drill the top triple tree as the Deuce have a 1/2 inch bolt rather than 10 mm. Makes it look squat but don't have to lean forward so ergonomically better on the back. Remember, goal here is look cool and still be able to ride a 200-300 mile minimum day and still walk!
Found a programmable electronic Speedo that will fit into the tank console but have to make sure that I can match up a converter that will work with stock pick up. This will add to the lower profile and clean up the look dropping the highest remaining point on the bike.
I am trying to maximize optical changes that give the appearance of physical changes to squat it out. So far the ideas have been working.
Fender. Bobbing is the trend in production, I want to stick with the long look of stock rear. Going to enhance it by removing the plate and tail light, cleaning it up. Moving the tail lights to the fender struts and including the brakes with the turns and move the plate down low somewhere likely on axle or at the end of the fender to make it look even longer, similar to the mounting location on the Thunderbird and new Speedmaster.
So there you go, really photo's as I flesh it out.
Ryan7771 #507249 11/15/2014 2:14 PM
Where she sits today in transition.
Fasteddy #507250 11/15/2014 6:45 PM
Nice looking bike Eddy.
britironrider #507251 11/15/2014 6:47 PM
Very nice
Martin62 #507252 11/15/2014 9:48 PM
Very nice Eddy.
edmspeedmaster #507253 11/15/2014 10:12 PM
Looking real nice Eddy!
2013 Speedmaster Matte Black
TriumphLance #507254 11/15/2014 11:29 PM
You get your shiny bits from your own website I 'spose. Not fair. Nice look Fast One !
Wade #507255 11/16/2014 1:53 AM
OoooooH! Cool AND Blue!
findlay13 #507256 11/17/2014 11:34 AM
not to nit pick (because it is a good looking bike), but why is there a reflector on the right fork leg only?
mag10 #507257 11/17/2014 3:23 PM
Cause thats its good side
mag10 #507258 11/17/2014 3:28 PM
Because...I don't look at both side at the same time and I am a risk taker..half the time!
Fasteddy #507259 11/25/2014 10:02 PM
Real nice. And I like the little add on lights under the bucket. Keeps it cleaner than having them stemming out on both sides of the forks.
perceval #507260 11/30/2014 3:37 AM
Eddy how effective are those mini spotlights compared to the big,hang off the lightbar ones.They certainly look better.Also how many dollars?
Edit.I just looked up your site.They're the $74.00 U.S. a pair, correct?
findlay13 #507261 11/30/2014 9:53 AM
Lance, yes, $74 for just the lights no mounts. They are 55 watt, most driving lights are 35 watts so gives you an idea, they are killer bight, approximately 800 lumen each.
eddy
Fasteddy #507262 11/30/2014 6:34 PM
Thanks Eddy,They look good mounted there.There's two bolts with nuts that come down under the triple trees.I guess that's where you attached them?
Paul/
findlay13 #507263 12/01/2014 7:41 PM
Nice looking scoot, Fast One! Although....... a bit to Chromey... :-)
findlay13 #507264 10/09/2015 7:47 PM
See you run modified 20184 map, Me too. Would like to discuss changes and how it's running, I am now running 904 wiseco 10\1 pistons with extensive port work, std cams and temp adjusted map 7% more fuel everywhere, seems to work well but will probably be too rich/lean in places.
Capt
Mick McColl Northam WA
