Re: Regulator mod done !!!
Wade #504888 07/18/2014 12:13 AM
OK , all hooked up and this is my official result in the professional chart below.
RPM ------- Stock R/R -------- Shendingen R/R
1,000 ------ 12.5 ------- 13.9
1,500 ------ 14.1 ------- 14.3
2,000 ------ 13.8 ------- 14.3
2,500 ------- 13.8 ------ 14.3
Update : battery must have needed some juice, 'cause now I'm getting 15.0 volts over 1500 RPM all day.
Wade #504889 07/19/2014 12:48 PM
Wade, I may have just missed this but why did you opt for the non PNP version?
I'm installing Rick's R/R in just a few minutes. I'll post numbers shortly.
07 Speedmaster
14 Daytona 675R
Wade #504890 07/19/2014 12:52 PM
15 volts is a bit high. Battery acid might evaporate a bit. Should run around 14.6. Hope your voltmeter is just reading a little high.
foglefar #504891 07/19/2014 5:41 PM
Here are my results so far:
RPM ------ Stock R/R -- Rick's R/R
1,050 ------ 12.4 ------ 13.9-14.6
1,500 ------ 14.4 ------ 14.6
2,000 ------ 14.1 ------ 14.8
3,000 ------ 13.8 ------ 14.8
3,500 ------ 13.8 ------ 14.8
4,000 ------ 14.0 ------ 14.8
Not sure what's going on with the voltage swing at idle, but it's within acceptable tolerance I suppose.
07 Speedmaster
14 Daytona 675R
jackshakes #504892 07/19/2014 11:17 PM
I opted for the Shendig 'cause it's a very good unit, Yamaha uses 'em, not that Rick's is inferior, just wanted to try that one, and the reason for the non PNP was because I wanted the simple straightforward mainline wiring, three from the stator and two to the battery. That's my story.
Wade #504893 08/14/2014 8:18 AM
Hey Wade, Jackshakes and anyone else who is seeing @idle V go from 12.5 to 13.5+ with the new R/R -- is your bike idling better? I know the primary reason for the upgrade is to prevent battery discharge, but I have a new procom CDI that seems to dislike anything below 13 V so am considering the R/R upgrade. Already did the stock mod.
FLYFISH #504894 08/14/2014 8:30 PM
Mine was idling fine before, it just wouldn't put out enough voltage to light up the battery like it should. PM me and I can give ya some intel about the regulator.
Wade #504895 08/14/2014 10:50 PM
Pm sent - tx!
FLYFISH #504896 09/04/2014 8:41 AM
Those of you who opted for Rick's regulator/rectifier did you get the oem style or the "Hot Shot" verison and are both plug and play?
JD13 #504897 09/04/2014 10:16 AM
HotShot MOSFET - yes PnP
B02S4 #504898 09/04/2014 11:00 AM
Thanks, I believe that this will be my next upgrade.
B02S4 #504899 03/26/2015 11:25 PM
I installed a Ricks Motorsports Hot Shot R/R today and am quite pleased with the results.
I'm getting 14.6 volts from idle to rev limiter. I had done the 10 ga wire mod and was ok with that but wanted more. I was thinking about doing the 10 ga wire mod to the Rick's R/R but thought I'd try without first and found it is not necessary. I don't think I want more than 14.6 volts
I recommend the Ricks Motorsports Hot Shot R/R for peace of mind!!!
I've become comfortably numb
Snert #504900 03/27/2015 12:25 PM
Rick's Hot Shot R/R is the way to go.
B02S4 #504901 04/02/2015 4:07 PM
http://ricksmotorsportelectrics.com/part/10-004H/MDJUcmlBbWVyaWNhODAw
