Carbs backfiring and hesitation
#497151 07/31/2012 7:16 AM
QUESTION:
What are the different reasons that a carburetor would be back firing. I do not mean the popping on decel. I can hear the carbs popping through the air filters and there is hesitation. fuel mixture might not be right. It is very difficult to start with or without the choke. I have to open the throttle to get it to start. and it won't idle very well.
Carb popping causes:
1. vacuum leak
2. carbs need to be synched
3. carbs need to be cleaned (AGAIN)
4. fuel mixture is not right
These carbs were recently rebuilt at a local shop, and sadly, I don't trust the work from most any shop.
I have not rebuilt Triumph carbs, but I have rebuilt Honda Goldwing carbs, and Honda 750 carbs. So, I don't think I would have a problem doing this if necessary. But where is the best place to get a carb kit and a how to?
Re: Carbs backfiring and hesitation
goregalore #497152 07/31/2012 7:29 AM
Carb farts are generally a sign of overly lean mixture, either caused by a vacuum leak or improper tuning.
B02S4 #497153 07/31/2012 7:33 AM
I'd replace the four 'squirrel condoms' first.
oldroadie #497154 07/31/2012 7:43 AM
oldroadie,
that was the very first thing I did.
And with having to open the throttle to start, combined with carb farts?
lean mixture?
I think we are getting somewhere.
goregalore #497155 07/31/2012 9:33 AM
I all ways have to start the bike with the choke out and the bike backfired through the carbs during warm up....I just changed out the pilot jet to a 42 and put in Truxton needles...I don't need the choke to start,,didn't notice any carb backfire
goregalore #497156 07/31/2012 9:45 AM
oldroadie,
lean mixture?
Good about the vacuum caps. Since the carb is a CV and doesn't have an accelerator pump opening the throttle really doesn't do anything to start the motor. Have you opened the mix screws yet? Either that or one pilot size bigger is what I'm thinking. Go for the screws first, simple and cheap is always better.
oldroadie #497157 07/31/2012 11:12 AM
I have NOT made any adjustments on the carbs yet. I am reading my owners manual etc... I honestly do not know much about this bike.
Like standard settings etc.
I want to know the basics before I start screwing with it, so I can atleast get it back to where it was before I started tinkering.
goregalore #497158 07/31/2012 11:55 AM
I think what would help is what mod's have been made to the bike...so for example I have a 2006 speedmaster with British Custom cams, no air box K&N pods only and British Custom Cocktail Shaker pipes and I live at sea level.......all of this effects the jetting of the bike.
SDKimo #497159 07/31/2012 1:23 PM
exactly.
goregalore #497160 07/31/2012 4:32 PM
When you said they were rebuilt, could you tell us what the dealer installed in terms of main and pilot jets along with the type of needles and if they were shimmed. You may have to pull off the float bowls to see what is in your carbs.
Because the bike won't start even with the choke pulled I'd say something is messed up or you have a big vacuum leak as already been stated. The choke is really an enricher that allows extra fuel to be drawn into the engine through another series of feed holes. You shouldn't have to open the throttle (unless you are really really rich?).
The next thing is to know what modifications have been done to the exhaust and intake. That will dictate what you should have in place.
I would agree with Ed and richen the two idle/pilot mixture screws, one under each carb. You might want to pull the plugs to see if you really are too lean. White = lean, Black = rich.
edmspeedmaster #497161 07/31/2012 4:35 PM
There were 2 mods.
1. removal of airbox and replacement with K&H pods
2. Sceptre exhaust from team triumph.
So those 2 combined will probably need new primary, and main jets
I am trying to find out from the previous owner if he replaced the jets when he had the carbs rebuilt.
goregalore #497162 07/31/2012 5:27 PM
I am running 42 pilot, 145 main and truxton needles...like I said after I increased the pilot seemed to take out the carb backfire and need to use the choke on start up.
SDKimo #497163 07/31/2012 6:01 PM
Ah, modified at both ends. That's a horse of a different color; you'll need to open a carb up see what's in there before you can proceed. The main jet and pilot (slow) jet will need to be larger than stock with that much air flow.
oldroadie #497164 07/31/2012 7:41 PM
Those mods are almost 10 years old. He said he changed out the jets, and will try to figure out what he changed them too.
The other symptom, I was riding and backed off just a little on the throttle and it sputtered and wanted to die.
But on my way home I got it to 90 without any issue at all. I could have easily gotten more out of it. But I had the wrong helmet and glasses on to handle that speed.
And I will pull the plugs to see if they are lean or rich.
goregalore #497165 07/31/2012 8:19 PM
Carb to intake rubbers on the right way? (It does matter)
Sticky valve after sitting? ( you did say it sat a while)
I run an indicated 120mph on my way to work with no helmet and little round (John Lennon type) sunglasses.NOTGATT
The_Dog33 #497166 07/31/2012 8:59 PM
I will check.
Sorry, Big Dog,
I am not as much of a man as you are
goregalore #497167 08/01/2012 9:08 AM
Back in 2003 I recall when Robert had to reverse the direction of the manifold to carburetor rubbers. This was taken just after that exercise.
Click in this image for the post.
moe #497168 08/01/2012 12:58 PM
thanks for sharing that!
goregalore #497169 08/01/2012 1:18 PM
New jets came with the Septres, so I would guess if someone was paying close to $600 for mufflers they would have changed to the Team Triumph recommended jets. What does your bike idle at and what are your AF screws turned out to?
Also, I may be wrong, but I thought opening the throttle was not advised when starting.
Once you've got this sorted out, balance the carbs, you'll be pleasantly shocked.
MACMC #497170 08/01/2012 6:37 PM
Thanks Macmc,
I called the septre rep and he knows Robert. the previous owner.
He said the jets they send are 45 pilot and 122 main.
But robert also installed the K&N filters.
I have a tach on the bike but it is not hooked up yet. So, I don't know what it is idling at, yet...
But I am sure now that the best thing I can do is just pull the carbs and clean them again. check the jets. and adjust the pilot screws.
Now where is the best place to get a new carb kit or atleast the gaskets.
goregalore #497171 08/01/2012 7:23 PM
Not sure what altitude you live at but I bet you should have about a 150 to 155 main unless you have baffles in those Sceptres.
goregalore #497172 08/02/2012 7:07 AM
Thanks Macmc,
Now where is the best place to get a new carb kit or at least the gaskets.
You are NOT running 45/122s with the freak. No way. And you have at least one shim under each main jet needle. You shouldn't need a gasket kit or anything else for the cleaning. Without reviewing your post, have you run through several tanks of fuel mixed with seafoam? When you clean the carbys, pay attention when you drop the jets and air mixture screws as the part order is crucial and the itty bitty o-rings and washers are hard on the eyes. Hum, never mind as you have been there before.
moe #497173 08/02/2012 12:55 PM
From the research I have done and using the calculator. It should be 155 main and a 42 pilot with the pods and the exhaust, plus a shim.
But that sounds like a good plan. Run a couple tanks of seafoam might really help. The backfiring isn't that bad after it warms up.
Oh, and no bluing on the exhaust yet.
Oh man, please ALL the help I can get is great.
goregalore #497174 08/02/2012 1:55 PM
Your carb should be easy to pull, with pods only...take the tank off, and un-screw the carb...they should slide out on the kick stand side..there is a allen head screw on the side of the carb bowl to drain the fuel...un-due the screw on the bottom of the bowl...main jet has a nut and screw on it the pilot is in a "hole" and you need a skinny screw driver to get it out...the jet size is marked on the side of the jet...should take a'bout 1 hour to do it....
The_Dog33 #497175 08/02/2012 3:18 PM
I'm not sure the original Septres have baffles, mine don't.
MACMC #497176 08/02/2012 5:08 PM
Here is a shot of one of the plugs. Bike does appear to be running lean.
-I did put seafoam in the tank.
-I also adjusted the pilot screws. Right now at 3.75 turns out.
Plan on riding to dinner tonight so should be able to run some fuel through the carbs.
I live in Southern Indiana. SO elevation is not really an issue.
Also checked the exhaust. No baffles.
goregalore #497177 08/02/2012 5:40 PM
If that is the correct pilot setting you probably need a larger pilot jet.
The_Dog33 #497178 08/02/2012 5:43 PM
I just know they made baffles for the Sceptres, I haven't seen anyone running them yet but know some do.42 pilot jet is gonna be too small with open pipes and pods.
The_Dog33 #497179 08/02/2012 11:27 PM
Dogg the original Septres didn't have baffles available, but I think they became available in later years. Isn't there a jet calculator somewhere, to help him?
MACMC #497180 08/03/2012 7:21 AM
Seriously thank you gentleman,
Took an hour ride last night.
And it ran good but periodically had a carb pop. accel or decel, it didn't matter.
Then we got caught in a storm, riding a motorcycle with seeing that much lightening flashing across the sky right in front of you is awe inspiring. Luckily it wasn't raining that hard. But boy it hurt at times. I still loved it!
goregalore #497181 08/03/2012 5:48 PM
Okay,
pulled the carbs.
155 main 42 pilot, and no shims.
Needle designation NBAD
And again we know the bike is running lean since the the plugs are white.
SO, I will closely check the carb to manifold rubbers to make sure they are good. And if so then I should order shims and a 45 pilot.
goregalore #497182 08/03/2012 6:33 PM
I think we found the problem. This one is worse than the other. but both were cracked. Shall we say "VACUUM LEAK"
goregalore #497183 08/03/2012 8:58 PM
Ooh, that'll take the starch out of the throttle.
oldroadie #497184 08/04/2012 7:12 PM
Ordered the head to carb rubbers from madss.com.
9.99 each
RUBBER,HT, CARB TO HEAD
ENG NO 55616 AND HIGHER US CAL ONLY
bike bandit part #1388148 #8 on diagram
carb schematic
And ordered a 45 pilot and shims from fast eddys
goregalore #497185 08/04/2012 7:46 PM
I would throw on those rubbers and run it for a while to see how she does before doing any additional mods.
We have to assume the carb set up is what Robert was running and I don't recall him having issues.
mikemm03 #497186 08/04/2012 8:17 PM
Always best to make 1 change at a time to determine weather it is good or bad. If you make more than 1 change at a time you won't know what was good and what was bad if you have an adverse result.
The_Dog33 #497187 08/04/2012 8:50 PM
One thing at a time is the way to go. If I were you I would replace the rubber and see how it runs. Next I'd readjust the A/F screw and test that out. If all is well I'd sync the carbs before changing the jetting.
Captain_Midnight #497188 08/04/2012 9:25 PM
That is what I was thinking I should do. I was just getting prepared.
mikemm03 #497189 08/05/2012 7:33 AM
+1.
goregalore #497190 08/05/2012 7:40 AM
Kevin, doesn't that take the cake? Really. "Please de-varnish my carburetors mr stealership" Okay oldcustomerwhomweusedtolovenowwewillripyouoff. Big4Cycle, Way to go. Brilliant attention to detail. Marvelous work. Exceptional diligence.
R U KIDDING? Pull the carbs and not see the rubbers as bad?
