HELP!....NO START...WANT RIDING TO HAPPEN!
#494159 07/01/2012 11:31 AM
Yeah the other night, turned the key, hit the starter, just a chirp and then the headlight died, now nothing. I checked every fuse, none broke, switched a couple mains around with the spares. Nothing
Any ideas?
Re: HELP!....NO START...WANT RIDING TO HAPPEN!
brokenfixed #494160 07/01/2012 11:54 AM
Any ideas?
What is the battery reading?
mikemm03 #494161 07/01/2012 12:11 PM
That $35 OEM relay on the frame spine, 'neath the tank, that you can get at the electronics store for $3 and change? I have had the exact same experience twice now, two diff. bikes, both times the relay.
Ryk #494162 07/01/2012 2:15 PM
My first guess also. Relay gave up.
oldroadie #494163 07/01/2012 4:45 PM
anyone got a pic? I cant find an under the tank shot right now for some reason.
brokenfixed #494164 07/01/2012 6:47 PM
No but you have to pull the tank anyway and it'll be pretty obvious. Right side of the backbone next to the flasher relay.
oldroadie #494165 07/02/2012 3:30 AM
hey Tom do you have blinkers and horn still working? if not then my money's on the ignition died.....
islandbum #494166 07/02/2012 6:57 AM
Nothings working right now Benny, no headlight, nothing.
Ryk, you still think its the relay?
brokenfixed #494167 07/02/2012 7:18 AM
alright heres a schematic link...
http://www.bikebandit.com/2003-triumph-america-electrical-equipment/o/m17614sch566741
are we talking about #3 "Change over Relay"?
Where did you find one Ryk?
brokenfixed #494168 07/02/2012 3:26 PM
brokenfixed #494169 07/02/2012 6:57 PM
Yes. Might want to clean that socket considering the condtion of those pins. Tommy, take that relay down to Pep Boys and get a new one.
brokenfixed #494170 07/02/2012 7:26 PM
I'll give you my SlingBlade explanation of what might have happened... check the battery cables for looseness. This happened to me, the black negative cable was practically falling off. I tightened it up...VROOM!
... or maybe it's out of gas.
(the real SlingBlade explanation )
brokenfixed #494171 07/02/2012 9:27 PM
is this it?
http://www.ebay.com/itm/Triumph-Speedmas...=item2c46700e00
That be the rascal, a'right.
brokenfixed #494172 07/03/2012 1:46 AM
is this it?
Looks like a lot of corrosion on the one connector. Be that your culprit?
Keith #494173 07/03/2012 6:57 AM
haha....nope thats a picture of one on ebay. I havent had time to take the tank off and fiddle with it.
Pep boys sells them? Man I cant stand going to a place like that and asking for a part that their computer cant help them with.
"doesnt look like we have any parts here for a Triumph, do they still make those?"....."2 wheel drive, or 4 wheel drive?"
brokenfixed #494174 07/03/2012 7:04 AM
Don't tell them anything, just say you need to replace this relay. Hand it to them, the pin out and schematic are on the can. Autozone managers take training from a corporate lesson plan to learn the parts business so you might go there. I just seemed to remember a lot of Pep Boys joints in that region when I was in high school.
oldroadie #494175 07/03/2012 7:17 AM
Napa might be an option as well, if y'all have them in your locale. Roadie s advice about "just give me one of these" is spot on, best not to confuse the kid with pimples with undata ed requests.
Ryk #494176 07/03/2012 7:50 AM
I have had that happen to me on a number of occasions...ALWAYS the relay was at fault...you can remove the relay and pop the black cube cover off of it...clean(sand) the contacts (like you used to do with automotive points) and that should buy you some time till you find a replacement...then keep the cleaned on in a saddle bag as a back up...I have had to replace that relay 3 times...I never paid $35 for the Truimph OEM relay ($12.00) but as others have said a $3 or $4 dollar item at most automotive retailers
RobBA05 #494177 07/03/2012 7:55 AM
Also no need to remove the tank to access it...you can get at it without doing so...but the first time you might want to at least remove the rear bolt holding the tank (under the seat) to be able to "hinge" the tank up to see it and how/where it connects to the bike (little rubber slot on the relay holder)
BTW...DO NOT attempt to remove this relay with out removing the tank when the engine is hot!...don't ask how I know this
RobBA05 #494178 07/03/2012 11:22 AM
Yeah I usually go to Advanced Auto cause theyre just like NAPA but are actually open and have parts in stock...haha. (N.A.P.A.=Never Any Parts Available)
Thanks for the info Rob, you got me really hoping its just that relay since my bikes an 03 and Ive never replaced it before. Nice to know I can get to it without taking the tank completely off.
Can you remember which ones the relay when looking down on the backbone of the bike?
brokenfixed #494179 07/05/2012 9:49 AM
No but I can check later today
STILL NO POWER
RobBA05 #494180 07/07/2012 10:28 AM
got a relay from pinwall
nothing good happened
anything else to check?
I checked all the fuses with a test light
cleaned the terminals on the battery
cleaned the terminals on the starter solenoid. Could this be bad?
how could I check my ignition?
how can I check the battery with a multimeter?
Re: STILL NO POWER
brokenfixed #494181 07/07/2012 10:39 AM
You can check static voltage on the battery with a multimeter, however that won't tell you the full story. If the resting voltage is less than say 12.6v it either needs a charge or a replacement. A load test is necessary to confirm. If you don't have a load tester then you can pull the battery & take it to one of the chain autoparts store & ask them to load test it.
Re: STILL NO POWER
B02S4 #494182 07/07/2012 11:16 AM
but do batteries just ZAP like that?
all is well, hit the starter, BOOM no battery?
Re: STILL NO POWER
brokenfixed #494183 07/07/2012 11:21 AM
They can, yes, although I'm not saying that it did. Load testing the battery will rule that out, however.
Re: STILL NO POWER
B02S4 #494184 07/07/2012 11:37 AM
yeah i guess I'll run over there and check it out.
any other ideas?
Re: STILL NO POWER
brokenfixed #494185 07/07/2012 12:49 PM
Jump across the starter sol. to see if the starter engages and turns the bike over
Re: STILL NO POWER
SDKimo #494186 07/07/2012 2:53 PM
Tell me that you've checked the fuses by pulling them out and cleaning the sockets.
Re: STILL NO POWER
oldroadie #494187 07/07/2012 5:27 PM
hey Tom hope you got good walking shoes buddy.....guess you've been doin a bit of that lately huh
as for the ignition this was mine when i opened it up
Re: STILL NO POWER
oldroadie #494188 07/09/2012 7:01 AM
Didnt clean anything, but I took out each fuse and put them back in a billion times. Didnt see anything dirty or corroded really.
How do you clean something like that?
Re: STILL NO POWER
SDKimo #494189 07/09/2012 7:05 AM
how would I be able to do this?
Re: STILL NO POWER
brokenfixed #494190 07/09/2012 7:06 AM
Benny I'm checking out that ignition as soon as I can.
Re: STILL NO POWER
brokenfixed #494191 07/09/2012 7:18 AM
all good Tom looks like my money's safe atm
Re: STILL NO POWER
brokenfixed #494192 07/09/2012 7:34 AM
Didn't clean anything, but I took out each fuse and put them back in a billion times. Didnt see anything dirty or corroded really.
I use a cleaner called DeOxit. Spray a little on the surface and then plug the fuse, in a couple of times to burnish the surface, followed by dielectric grease to seal the connection. Really, you could do the same with WD-40, I just use DeOxit at work and it's my favorite cleaner for these situations.
Did you swap the main fuse out? Sometimes they look ok but are really blown.
Re: STILL NO POWER
oldroadie #494193 07/09/2012 8:16 AM
I had a similar issue recently. It was hard to tell, but one of the 30 amp fuses was blown. I replaced them both and I had power.
Re: STILL NO POWER
brokenfixed #494194 07/09/2012 9:17 AM
Pull off the right side cover you will see the starting solenoid...make contact between the two large bolts (I used a quarter I had in my pocket) BE SURE THE BIKE IS NOT IN GEAR AND THE SIDE STAND IS UP!
Re: STILL NO POWER
brokenfixed #494195 07/09/2012 9:38 AM
I took a 12 gauge wire and put it across the two large terminals on the sol....my bike turned over...don't hold it there just bump it
Re: STILL NO POWER
oldroadie #494196 07/09/2012 12:19 PM
AH...I think I have some deoxit somewhere that I used on my buddies fender amp. I'm on it
I tested both 30 fuses with a test light, they were good.
Re: STILL NO POWER
RobBA05 #494197 07/09/2012 12:23 PM
so ingnition on, then bump the terminals briefly?
but I dont have any power going to anything right?
So starter not working isnt even my concern at this point, its just seeing my headlight, blinkers, brake light work no?
Re: STILL NO POWER
brokenfixed #494198 07/09/2012 12:47 PM
So you're thinking the switch? Have you tried the other switch position to see if there's power?
