 Re: single carb for parallel twins
A pic from both sides and maybe a pointed down angular with the tank removed and I'll nominate you for a Pulitzer
Posts: 8,393 Likes: 1
Posts: 8,393 Likes: 1 |
Do they have a photography Pulitzer? I could never win that one.
Edgar Allan Poe
C'mon man, it's a special BA.Com Pulitzer, work with us here.
Is that carb coming out at an angle? Can you take a side pic showing the engine along with the carb. Both sides appreciated.
Thanks Loads.
Worst. Marketing. Ever.
Hey, remember when we waited on "Pins and Needles" for the new Victory model, there was even a countdown clock. Maybe Chad knows what he's doing.
One million one hundred and sixty two, one million one hundred and sixty one, one million one hundred and sixty, one million.......
DAMMIT! I was almost taking a sip of coffee when I read that! You almost owed me a new monitor...
Chad is attempting to make a two into one intake that will feed and fuel both cylinders at the same velocity/fuel air in spite of our 270 degree timed engines? IMO, velocity management would be inherently easier to regulate on a T. 360 degree mill than our lopey engines. It may as well, take some trick researched out timing, and a necessary program change to our ignitions to fully realize any real gained performance beyond stock. He has the ambition and stated solid help with the engineering part, obviously he has time and money involved as well. Looking forward to the projects conclusion when Chad is ready to share it with us in its entirety. Make this work, Chad, and you will sell enough of these to make it all worthwhile. I believe in you.
Sometimes I forget to remember, I can always find sympathy in any dictionary, right between sh*t and syphilis
Posts: 3,995 Likes: 10
Posts: 3,995 Likes: 10 |
Nice job of showing Chad some "sympathy" Ryk  Joking,joking!Only joking!
I hope Chad can make it work too! Years back I was told of a single carb deal for my twin carb 600 VLX honda that supposedly increased power.I asked about it on a forum and was told ,why swap 2x36mm carbs for a single 40mm. Having ten thumbs and knowing nothing I didn't pursue it after that. I hope Chad makes this work.It'd be a great mod.if it provides more power.Only one carb to fool with.What's not to like? As a matter of fact Chad,you could maybe approach Triumph themselves once you get the little problems worked out.Jst a thought.
Yea, why didn't corporate Triumph offer or do this? They had the precedent one carb model, historically. Oh wait, they gave the Tiger name to another type of bike. I'm not sure that a bigger carb is needed as only one side hits at a time. I could be wrong about that, though. I wanted to try this since the first day I looked over the fuel arrangement. Back in the 70 s I had a 70 TR6R and a 76 TR7RV..Tigers, even factory racers had one carb, The TR6C. It's the damn 270 timing thing, that made me unsure as to not try and tig weld one up. I have a good condition sidedraft carb (SU) from a TR-4 sports car, I think that would work just dandy, not to mention would polish up and look cool.
I'm waiting impatiently to find out Chad's conclusions and I agree it's great people put themselves on the line to research things.I'm especally interested in more power with a carb change.
Thanks Ryk, for the support. I want to share with you guys and am excited about the project. I don't want people to see the set up and spend time and money on doing it with out the help that I have. It would be an exspensive failure. There is more to it than a "Y" and a big ole carb. That carb is modified tremendously and the intake is not a simple "Y". When its ready and the bugs are out of it. I will post lots of pictures, and information on it. It is going to be very cool when its done. I may have gotten over zealous and posted too early but, hey man, this is exciting stuff ya know. Thanks for all the support gentlemen.
Edgar Allan Poe
Posts: 7,694 Likes: 22
Posts: 7,694 Likes: 22 |
If you don't get gas the bike won't run. That is everything I know about carbs. Just to qualify myself as a serious expert on the topic. It sounds like a great undertaking. (We have two types of bikes among us with basically the only difference being the fuel system. Are the EFI bikes much more responsive with higher top end without the carbs?) So, why not make a carb replacement ie: a bolt on fuel injection instead. As stated above the hesitations and slow reactions are the problem as well as WOT not dumping enough fuel. (At 110 my bike runs out of HP IMHO) As you are inventing a solution to an obsolete form of fuel delivery. Will this be something the EFI bikes can retrofit for superior performance?
Many people who are "hot rodding" their bikes remove the fuel injection system to put on performance carbs. Mine will run right up to 120 easy right now. I need to get it on a track to really test it out though. I don't know how well the efi bikes are doing as far as high performance goes. I guess I should test ride one. Anyone with efi want to chime in I would be glad to hear your input.
Edgar Allan Poe
Posts: 1,669 |
Posts: 1,335 |
A single carb on a 360 engine I understand, but not sure how it will work on a 270 engine.
It will be interesting to see any dyno test results with a single carb versus dual.
Tom
Posts: 23,220 Likes: 61
Posts: 23,220 Likes: 61 |
They work on HD and those pistons are not at TDC at the same time. The older ones did fire off 1 set of points though.
Posts: 123 |
I am re-working the intake right now because I think I can get more out of it. A different tube showed a higher cfm. Last drag strip run was 110mph. I need to figure out how to raise the rev limiter rpms. If I didnt hit the rev limiter in third and fourth I think I would have a faster run.
Edgar Allan Poe
Posts: 123 |
Cool!- any chance of a left side model?
Edgar Allan Poe
Posts: 2,152 |
I always like the single carb bikes better on the old stuff.
+1 but the benefit was mostly ease of tuning wasn't it? Rather than performance.
My TR6C was always better running bike than any of the Bonnies I owned. Didn't seem to gain anything from the dual carbs and the better cam in the C model let mke walk away from them.
Can't see that S&S over a cable operated slide carb though.
Switching to a mikuni for the project the S&S is too limited.
Edgar Allan Poe
Posts: 85 |
yay!
I am no longer working with the guys I was working with because I have found that his carb system, while its better than a stock S&S its still just a tractor carburettor. I am still a bit concerned about the top end with the Mikuni but its better than only having top end and no bottom at all.
Edgar Allan Poe
Edgar Allan Poe
Posts: 198 Likes: 1
Posts: 198 Likes: 1 |
You're fighting a losing battle with one carb and restricting flow exactly where you need it, at the top end. That little filter will stop you getting to where you want to be on it's own without the airflow having to go round bends in the manifold. It'll be interesting to see your dyno runs.
Yea thats a thought, However I am already faster than it was with the freak mod, and now its faster than it was with the S&S. But its good to have neigh sayers because that drives a fellow like me. On the quarter mile track my hole shot is my weak point not my top end.
Edgar Allan Poe
Posts: 3,816 |
me and others (I think) would like to see Dyno result with power,torque curve and A/F ratio....not how fast it goes
Posts: 20,096 Likes: 2
Posts: 20,096 Likes: 2 |
Yeah Chad, and some mileage figures would be cool too. Ya see I'm particularly wonderin' if just runnin' the single carb there will increase the MPG.
(...you would think it would, but ya never know until ya get some real world tests)
Posts: 6,821 |
I'm wondering, with it off to the side like that have you tuned the intakes?
Long intakes too what have you done about turbulence inside for a good mix? Do you have it supported so all that levered weight isn't hanging on the studs on the head.
Posts: 3,937 |
I am no longer working with the guys I was working with...
Sounds like NOW you've got more "help" (from BA.com) than you ever could have imagined!
(Now, IF they'ed JUST throw in some MONEY!)
And you may see me tonight
With an illegal smile
J. Prine
I haven't done a dyno run yet for 2 reasons; I can't seem to find some one who will let me do it here in Houston, and I'm not yet satisfied with my street results yet. No Dwight, There is no fuel milage improvement, but I haven't tried tunning for that yet. In fact its worse not horribly worse but worse. about 40mpg as it stands. Yes Bill, we did tune the tubes for even flow to each cyliner as far as cfm goes. Ian, all of the above has been taken into account the wieght, and turbulance. The good thing is that the turbulance increased the cfm as well. Thats fun huh? Yea erle, Thats ok though. They keep ya thinking. \
Edgar Allan Poe
Real world results matter to me first.
Edgar Allan Poe
Posts: 198 Likes: 1
How do you know this? "Seat of your pants" is very deceptive for mods where you gain or lose small amounts.
I can't remember how many times I have modified something, gone for a ride and think, "wow this is much better", then go for a dyno run and have lost some power. Perception is a funny old thing.
With the mods you are doing, you do need to carry out a run on the same dyno after each mod, otherwise you don't know where you are or where you're going.
I concur with Mike. At the very least, a reliable wide-band AFM is necessary for optimal tuning purposes.
Posts: 123 |
that hsr is way better than the s&s for this app- get that thing tuned right and it'll smoke any pair of cv's out there- i'll guarantee it-
