 Re: single carb for parallel twins
With the timing staggered as is our lot with 270 degree engines, is the fuel mix velocity the same to each cylinder? Seems that a 360 engine would naturally be easier to regulate a same same dose of velocity, fuel and air. Have you attached your set up to a Bonnie or a Thrux. yet? I totally agree with Ken, you need a set of headers with bungs, so you can attach a on board, ride along sensor, the dyno would only be needed to authenticate actual output, once you had the set up dialed in.
Posts: 8,393 Likes: 1
Posts: 8,393 Likes: 1 |
Yea thats a thought, However I am already faster than it was with the freak mod, and now its faster than it was with the S&S.
How do you know this? "Seat of your pants" is very deceptive for mods where you gain or lose small amounts.
I can't remember how many times I have modified something, gone for a ride and think, "wow this is much better", then go for a dyno run and have lost some power. Perception is a funny old thing.
With the mods you are doing, you do need to carry out a run on the same dyno after each mod, otherwise you don't know where you are or where you're going.
This is the best question so far, and thanks for the input. What I have been doing is controlled timed runs on a certain stretch of road that has very accurate measurements on it. So its a stop watch and a complicated marker to marker, throttle position, speedometer, and note book thing. I am finding it difficult to find a dyno to run on because most of the fellows here who have them will only run harleys on them or sport bikes. Weird huh? Thats the problem that I am facing right now. I do want to get some dyno results and I will eventually. I haven't found the guy who has one that will work with me yet. I cant afford to buy one or I would.
Edgar Allan Poe
Thats an excellent idea. That would help me to have very accurate fuel mixture reading through out the throttle range. I am going to look into that and see what would take. No I have not tried it on anything other than the America 790 as of yet I want to get it right there first and then go on to other applications. I will also try to get a fuel efficiency improvement tunning as well for those who are more interested in that as well. For now I still have lots of work to do to get this right. Thanks for all the questions and input, everybody, even the scepticts. It helps to not be the only one thinking. Because its easy to over look something or over think something and miss a detail.
Edgar Allan Poe
Posts: 23,239 Likes: 64
Posts: 23,239 Likes: 64 |
I think the timed run is as good as you can get for seat of the pants as long as you do what you say you are doing like record throttle positions, temp, etc... but I still think a dyno would be your best gauge if you can get one to use. Most guys I know with them will run anything as long as you have the cash to pay them.
When my friend Vic ran my SM he was amazed at the TQ and HP I got out of a stock 790. He normally runs HD and S&S HD knock-offs.
I think the timed run is as good as you can get for seat of the pants...
That is true for WOT runs, but not so much for things such as driveability, fuel economy, idle quality, cruise, throttle & fuel circuit transitions, & other things that really matter in the real world.
No, you can make runs at certain throttle position and accelerate from one throttle position to another from one marker to another, and decelerate as well. Yes its harder than a dyno but what else can I do right now?
Edgar Allan Poe
Posts: 198 Likes: 1
Posts: 198 Likes: 1 |
With timed runs it's crucial that your take off is identical on each run. If you open the throttle at a slightly different rate from one run to the next, your figures will be out and might make you think you're doing better or worse than you really are. It's really hard to be accurate enough for subtle differences, but I wish you the best of luck with it as that's the only option available to you right now.
Get a wide-band AFM for starters.
Why you would engage in pioneering development work without that, in this day & age, is beyond me.
Because you do not understand does not make you wrong, or right. It only means you do not understand, and thats ok. The knowing is the most important part of the doing, but the doing does not happen just because of the knowing. On this project it is the same, The knowing and the doing are equal.
Edgar Allan Poe
...The knowing and the doing are equal...
Eh? ...
Posts: 3,937 |
Eh? ...
Ancient Chinese Proverb.
And you may see me tonight
With an illegal smile
J. Prine
Edgar Allan Poe
Posts: 123 |
I have been too busy to mess with it much. I am running it on my bike now and prefer it to the two carb set up. I was working on a way to shorten the intake manifold, but have been too consumed by working on customer bikes to do anymore testing. All I need is a dyno run to have some paper results to post. About 20,000 miles of running it on mine has me personally satisfied with the results.
Edgar Allan Poe
Posts: 558 |
Man, has anyone told you that you need a dyno?
Yes, that was a joke. Lots of doubters in this thread but I think it's bad ass. Keep working!
...About 20,000 miles of running it on mine has me personally satisfied with the results.
since March 11, 2012?
Wow, now that ya mentioned it thats a lot of miles. Nearly nine months and didnt much consider how many mile that mounts up to.
Edgar Allan Poe
I rode an America the other day rejetted drilled box and custom exhaust. No comparison at all can be made to the way Matilda runs.
Edgar Allan Poe
