Page 2 of 3 1 2 3
Re: major mechanical wish list....
The_Dog33 #479168 02/08/2012 1:51 PM
I say kick start only for the R3. (that will weed out the casual riders)
I do like the factory 904 and 6 speed ideas for the smaller twins.
mag10 #479169 02/08/2012 2:01 PM
another vote for threaded valve adjustment. that would be so awesome.
steve0suprem0 #479170 02/08/2012 2:10 PM
Threaded valve adjustment is so much easier boggles the mind why anyone would use any other method.
The_Dog33 #479171 02/08/2012 2:46 PM
It would be interesting if there was a way to have a hydrolic valve adjustment and still keep the OHCs.
larger cc displacment the closer to 1000 the better. 6 speed definately. no more air boxes pod style air filters in perferated metal covers. Slip in adjustable baffles. some type of built in air fuel mixture adjuster that would allow you to dial up the fuel.
steve0suprem0 #479172 02/08/2012 2:50 PM
YES! No shims! I hate shims! Adjusting valves on aircooled VW engines was so much nicer (other than that whole crawling-under-the-car thing).
The_Dog33 #479173 02/08/2012 2:52 PM
I would guess because maybe Shim (either Over or Under) Bucket is a more direct approach to opening and closing the valves and thus has less reciprocating parts than would a threaded arrangement, which would necessitate the need for an additional rocker-arm in order to hold the threaded adjusters, which in turn would make the shim-style engine capable of higher RPMs.
Plus, because of the lack of that additional rocker-arm, it would make the Shim designed engine less expensive to manufacture.
Dwight #479174 02/08/2012 2:55 PM
Buzzkill...
FriarJohn #479175 02/08/2012 3:03 PM
Well, I was answerin' Ian's question here, John!
Though of course, other than costs, there really is no reason why Triumph couldn't have designed a threaded arrangement for the Bonnie line, as they're certainly not all that high-revving of engines.
Dwight #479176 02/08/2012 3:28 PM
I see no reason why they couldn't have done it that way though since many automotive engines have over head cams with cam followers and are adjustable through a threaded part that makes contact with the top of the valve stem. The cam follower goes under the cam and sits on a pivot on the opposite side of the valve and has an adjustment over the valve. I have seen these where that pivot is hydrolic as well.
The_Dog33 #479177 02/08/2012 3:45 PM
True Ian, but once again, those cam followers would be an added expense for the manufacturers, wouldn't they?
Dwight #479178 02/08/2012 6:32 PM
Had it been initially designed that way I don't think it would have effected the retail price much.I think time saved with adjustment during assembly would cancel out added material cost.
The_Dog33 #479179 02/08/2012 7:27 PM
Totally agree with ya on this!
The_Dog33 #479180 02/08/2012 7:33 PM
I'm assuming valve shims is a legacy design and their philosophy is if it ain't broke don't fix it.
FriarJohn #479181 02/08/2012 7:39 PM
Yeah, you're probably right, John.
Plus, I'll bet all the Service Managers at all the Triumph dealerships worldwide just LOVE that they're designed the way they are, TOO.
(...it's called "Job Security", ya know!)
Dwight #479182 02/08/2012 7:47 PM
What do you mean by legacy? If you mean harkening back to the twins of old then no. The twins of old had threaded adjusters.
Dwight #479183 02/08/2012 7:48 PM
Could they have replaced the shim system and still retained the classic Triumph looking engine or would it look more like the T-bird?
One of the reasons I like the America/Speedy is because it looks like a Triumph engine.
Easier shim adjustment would certainly be great though
"I just ride 'em.I don't know what makes 'em work"
findlay13 #479184 02/08/2012 7:50 PM
I'm assuming that most of the Bloor era bikes have shims for adjusting valves, but I don't know. That's what I mean by legacy. Dealer service departments already have all the tools and shims and such to support that technology.
findlay13 #479185 02/08/2012 7:53 PM
I think they could have done it and retained the nostalgic look.
The_Dog33 #479186 02/08/2012 7:53 PM
Ok so they could keep the tradional look.
Easier adjustment would be great.Maybe even I could do it!
The_Dog33 #479187 02/08/2012 7:53 PM
Unless I read him wrong, I think John meant that after all this time of the Hinckley twins having this arrangement, they're not likely to ever change to the threaded design, Ian.
Edit: I see you've answered Ian in the meantime here, John.
findlay13 #479188 02/08/2012 7:55 PM
I see and that is probable, too bad they couldn't use the lever system to push the valve down and pop out the shim instead of pulling the cams.
The_Dog33 #479189 02/08/2012 8:00 PM
Yeah, I think so too, Ian. The only issue I can see with that might be that the valve cover might have had to be slightly higher in order to have room for any rocker or cam followers.
Dwight #479190 02/08/2012 8:10 PM
Well, pursuant to my brief discussion with Ryk about stainless steel exhaust systems from the factory, none of us has the perspective to know how they arrived at what they sell. There are a myriad of factors involved in created such a complex (but seemingly simple) organism.
FriarJohn #479191 02/08/2012 8:18 PM
It's great that Triumph was re-born at all.
findlay13 #479192 02/08/2012 8:30 PM
John Bloor is The Manâ„¢.
FriarJohn #479193 02/08/2012 11:41 PM
I would love to see the motor that comes in the T-100, 360 degree crank, more power, what's not to love? Oh and by the way, I'm also in the threaded valve adjustment camp. I had an old airhead BMW it was so easy to adjust the valves , it was a one beer job!
mailman #479194 02/09/2012 12:04 AM
+1
Keith #479195 02/10/2012 2:23 AM
Better suspension is my only complaint really. The rest of the stuff I've done is because its the way I wanted it, pretty much all looks. However, 904 factory would of been sweet.
Keith #479196 02/10/2012 4:48 AM
+1
That would be great.
findlay13 #479197 02/10/2012 10:43 AM
Turn the head around so the carbs are in the front and the exhaust could go straight out the back. Speedo in the head light bucket no dash with dummy lights.
StandingBull #479198 02/10/2012 10:52 AM
Haven't looked at it closely enough but you could probably turn the head around if you wanted to. Used to do it on the old twins. Cams would turn the wrong way but not sure if the way they are ground if that would be an issue. Also not sure if the chain is centered or off to one side anymore.
The_Dog33 #479199 02/10/2012 12:18 PM
You would loose the "classic" Bonnie engine look with that. But I agree get rid on the harley looking center console put a tach in the speedo or a seperate unit along side of it.
PES #479200 02/10/2012 1:27 PM
The genesis of that
...harley looking center console...
was the '37 speed twin.
moe #479201 02/10/2012 8:42 PM
The genesis of that
+1 along with the passenger peg hangers that I have been told is Triumph trying to make them look like the old HD tool boxes. Well Triumph had those tool boxes I think in the late 30s too but could have been 40s.
moe #479202 02/10/2012 10:06 PM
The genesis of that
I don't see no stinkin console on this, although there is something on the tank I just can't make out.
http://classic-motorbikes.net/images/gallery/10637.jpg
PES #479203 02/11/2012 8:35 AM
moe #479204 02/11/2012 7:57 PM
Ahhh...so Harley copied it off Triumph. That figures.
PES #479205 02/11/2012 8:29 PM
Anyone care to take a guess when Triumph had the first belt driven bike?
Trumpeteer #479206 02/11/2012 8:45 PM
From the very beginning of manufacture, Matt...1902, because almost all early 20th Century motorcycles had a belt which ran directly from the crankshaft to the rear wheel with no transmission, and a ratcheted tightening pulley which would engage the power to the rear wheel.
Dwight #479207 02/11/2012 8:51 PM
You mean to tell me that Harley didn't invent that with the evo engine???
Page 2 of 3 1 2 3
