 Re: Zmilins build (break in done!)
Posts: 5,616 |
Man...that was the longest 750 miles E V E R ! As of this afternoon all three stages of break in (50, 200, 500) are DONE! Ive swapped back over to my Amsoil and can't wait to get it out tomorrow and see how she really feels over 5k RPM.
I doubt Ill go to crazy with it as I still don't know if Im running rich or lean at WOT. I do have a good idea that Im a bit on the rich side. Why... cause Im getting on average in the mid to low 30 mpg and when I pulled the plugs yesterday they were dry and sooty but not too bad.
Stay tuned for a but dyno report tomorrow eve.
NEW: 19 Goldwing Tour DCT
 Re: Zmilins build (butt dyno report)
Posts: 5,616 |
Today was the first day out without having to worry about RPMs and being able to twist the throttle to my hearts desire.  Keep in mind that the carbs are running rich. Richer than I thought at RPMs over 5k. I know this cause of the amount of black soot on my exhaust tips AND from feedback form my riding buddy today. He said that when I whack that throttle he can smell fuel. LIke I said before... right now Id rather be rich than lean. Throttle response - you know how on the stock carbs when you whack the throttle there is that delay... or when your rolling on it doesn't seem like its doing anything so you roll a bit more then all of a sudden the surge hits and you have to back off... yeah, none of that exists anymore. With my current set up if you twist there is a reaction. No delay, just go! Idling - I have a slight issue at idle. At long lights I get a cough then the bike wants to die. Carlos says this will go away once the carbs are tuned on the dyno. He has not said anything to me that has not been true so I have to believe this. There is a lot going on with these carbs and I think they are close. Right now very rich but close. Power - hehehe... ok. 1st gear, whack the throttle and 7k comes up faster than you ever could imagine. My buddy today said that he saw my front end get light each time I nailed the throttle. From my perspective when I nailed it it felt as if someone was grabbing my collar and trying to get me off the bike. Not to an uncomfortable level but significantly more than I expected. The way the RPMs jump between 5500 and up is amazing. Like a NOS button. In all honesty I was not mentally prepared to go over 7500k. I only tried once today to get over 7500k and I did and I ran out of road really freaking fast. The bike cruises at 70mph in 5th at about 3500 rpm (I have a 19T sprocket up front). I was coming up to an incline where in the past I always had to downshift. Today I went from 1/4 throttle to 1/2 throttle and watched my speed increase as I climbed the incline. I was impressed. I certainly did not expect to be able to do that. Passing traffic is as simple as twisting the throttle, no downshifting needed. Passing on a two lane (legally) is no longer filled with thoughts of "do I have enough room to make this pass?"... its pretty much a flick of the throttle and pass. My buddy was on a Goldwing and granted he is fast on that thing. No way I can keep up if he really nailed it BUT today I was on his 6 each time he passed a car I was there in his mirror. In the past its always been me catching up. So yes, the bike is faster the it used to be. No, I don't go racing at each green light. I feel the bike is now what it should be. Responsive, more fun to ride that it used to be and I no longer wonder if I have the power needed. I am more confident knowing that the power is there if I need it and when I need it it will be delivered quickly, smoothly and (after tuning) efficiently. So... would I do it again? YES! I don't know how much the headwork adds but between the carbs, cams and HC pistons this is one hell of a great mod and IMHO worth every penny.
So how many pennies so far?
Great butt dyno report! If I wasn't addicted to guitars (can never have too many) I'd be doing engine work on my bike too. It's very inspiring to read about your performance gains!
Posts: 5,616 |
A LOT!  My buddy asked me that today too... about 3.4 K. Keep in mind... my little bent valve adventure added 1400 unexpected to the mix.
Do you count the high compression pistons as part of the 1400 unexpected? $2000 for cams and carbs and headwork, including tons of tech support doesn't actually sound that bad.
Posts: 3,816 |
since I got my big bore fitted no downshift is needed to overtake(mostly) but now after remapped CDI by Pieman acceleration is even much quicker
Posts: 5,616 |
John, No, the pistons were included in the big number. The head that I keep referring to as a stage 1 is actually a Street Plus. Per the TPUSA website... TPUSA headworkStreet is a ported, polished, reshaped, 5 angle vjob, new parts as needed (meaning valve guides, springs, retainers, etc...). Street Plus is above and port match intake manifolds and oversize valves. Heres the breakdown on my build so far (not including tax).... Carbs - 989.00 865 Hi Po kit - 969.00 Opt 3 igniter - 249.00 (I forgot about this in the initial reply to you) Street Plus head - 1400.00 Heres what it was supposed to be... Carbs - 989.00 Cams - 695.00 (I was not supposed to be doing the pistons originally) Opt 3 igniter - 249.00 Headwork was never part of the plan for this year. Cest La Vie! I will say this... if your only thinking of doing cams with no intent on a big bore later then you should consider doing the Hi Po kit!  If you go to the Triumph Twin Power website and check the dyno sheets. He's got a run for a a 270 degree motor running the TPUSA Hi Po kit without his igniter and OE carbs making 70RWHP/49Tq, add his igniter and it goes up to 73RWHP/50Tq.
Posts: 5,616 |
Next year I will be pulling stumps out of the ground like you  For now I am happy with my giddy up!
Posts: 3,816 |
first we want to see dyno numbers
Posts: 5,616 |
7 more days!
Posts: 3,816 |
Man I never been so curious about someone elses dyno result before
Posts: 5,616 |
And I have never been so worried to let someone else mess with the setting on my bike
I expect to see a significant increase in HP and a minimal increase in torque. Of course all of that will be dependent upon how well the carbs can be tuned by the operator.
Posts: 641 |
Where are you having the Dyno done???BrothersPowerSports in Bremerton have a great reputation but a little bit of a spin for me..They quoted me $700 for installing and purchase of PowerCommander3 and set-up with Dyno for my Rocket..Perhaps if you have a pleasant experience with their service,check with them for PowerCommander and set up for my 08 Rocket.Thanks "Z"..They may treat you right if they know potential business may come their way!
Posts: 5,616 |
Sorry Bob... Right down the hill from me is I90. I did my baseline there and they are known by TPUSA so they get to do my tuning and dyno runs. I'm really hoping they have a good carb guy there. I will drop by this afternoon and verify.
Posts: 641 |
Not a problem..TofT is not the same with Bob,Paul,etc gone.I didnt know that I90 did dyno work.I can check myself about PC and dyno on my Rocket.They put tires on my friend "G"'s Rocket(06) for a LOT Less than Tof T charged me last month..I like Lonnie but not enough to over pay!!!Thanks "Z"..we need to get together now that weathers' good..love to hear that america running!!!Just got of phone from Tom@service..Installation,dyno,etc about$900 complete with the new PC5..less travel,etc.Let me know your experience later..and Thanks again "Z"
Posts: 5,616 |
Well work on this soon...  I hear Copper Creek pie calling my name
Posts: 5,616 |
I went by today to make sure they knew the bike was modified and there would be no surprises for either of us. I also wanted to make sure they would have someone that has worked on FCRs there as well, otherwise id reschedule. Now they are looking forward to it as well. "we like fun bikes like that, can't wait for next Tues!"
Posts: 1,382 |
The suspense is killing me!
Posts: 5,616 |
How the F do you think I feel?
Posts: 1,883 |
Z take the laptop with you and give us real time results.
~Brent
Posts: 5,616 |
Ill have the iPad
Posts: 1,883 |
You are the best.
~Brent
Posts: 5,616 |
Maaaaan.... Tomorrow morning can not get here fast e-freaking-nough!
Watdoya think if feels like to be me?@#! (Looking forward to your results!)
 Prelim Dyno
Posts: 5,616 |
The bike is still at the shop and will be there for a couple days. They need to get the proper jets, assemble and tune. I did get a peek at the prelim dyno run form this morning... Baseline Dyno from Feb was 50.74 Hp, 49.27 Tq Baseline Dyno today was 78 Hp, 54 Tq An increase of 27+ Hp and 4 + Tq Once the final results are in Ill post again.
 Re: Prelim Dyno
 Re: Prelim Dyno
Posts: 10,736 Likes: 7
Posts: 10,736 Likes: 7 |
That's real nice, man! I'd like to see a couple more ponies and a few more ftlbs after it's dialed in, those numbers there are just about what I'm running now. You're getting me motivated to get another dyno run on mine and see if the Procom unit is a power adder or not.
 Re: Prelim Dyno
Posts: 5,616 |
Well... I just got off the phone with Carlos who is talking to the shop doing my dyno tune. Sounds like their sniffer isn't picking up my a/f correctly. He has visibility to the dyno runs and is talking to the operator. Based on the results (even skewed) he knows what he needs to send them but Im not sure how its going to translate to final numbers. The numbers posted are under rich conditions. Im certainly going to get those bungs welded into my spare headers ASAP now. I really want to make sure I do not run lean. Ive said it before and Ill say it again... Im glad I have Carlos on my side.
 Re: Prelim Dyno *DELETED*
Posts: 48 |
1087cc's- 115RWHP-81.5RWTQ.Nuff Said
 Re: Prelim Dyno
Posts: 5,616 |
54 TQ? where did you get that from? I don't even know yet, but it's more than that. Let's wait for number until is done, can we?
That was from one of the runs they did. When I dropped off the loaner bike I asked to see the numbers and that was on the screen. That was before you and I talked today but after you spoke to them.
Posts: 48 |
 Re: Prelim Dyno
Posts: 5,616 |
Oh... that means that you knew everything that I told you over the phone and more... what a waist of energy...
LOL... No. Ill email you directly and well wait for the results after he get the jets.
 Re: Prelim Dyno
Posts: 20,096 Likes: 2
Posts: 20,096 Likes: 2 |
78hp + 54 ftlb, and the baby isn't even completely dialed in yet?! And, we're talkin' at the rear wheel here, right?! I would KILL for numbers like that as they presently stand! Now IF I can just stop spendin' money on houses!!!  (...btw Carlos, hello there ol' buddy...how's everyone at the shop?)
 Re: Prelim Dyno
Posts: 3,816 |
Lets wait for good set up coz my america with 68 hp has 57 ftlb
 Re: Prelim Dyno
Posts: 5,616 |
yes but you have a BB. Your mods are known to make Tq. Mine are more Hp than Tq (based on my own research). But I also agree... lets wait and see if the shop can sort the a/f issues they are having.
 Re: Prelim Dyno
Posts: 5,616 |
Dang it! Bike is done but I'm in Los Angeles for the weekend  No I don't know what the final numbers are, I just got the message and they are closed.
 Re: Zmilins build *finally started*
Posts: 8 |
Gratz! good luck with it!
Bird.
Posts: 5,616 |
Called the shop today... Got the HP number but the guy was in the other building and he couldn't recall the tourqe. I'll pick up the bike on Tuesday and share the numbers and charts then... I am typing this with a big smile though
