 Re: Springer front end on an America
Posts: 3,210 |
Posts: 23,244 Likes: 64
Posts: 23,244 Likes: 64 |
The upper and lower suspension links are parallel to each other and move parallel to each other. The fork part and the bearing part are not really parallel so ,if I remember geometry correctly, not really a parallelogram since top and bottom are parallel but front and back are not, but that is what he meant Keith.
Posts: 7,702 Likes: 22
Posts: 7,702 Likes: 22 |
Trapazoidalellogramic is clearly the geometric shape of that front end.
Posts: 20,096 Likes: 2
Posts: 20,096 Likes: 2 |
das uber komplicated!
Boy, Tom, you're on a roll here lately, aren't ya?!
(...but as I recall, Keith wanted a translation from the original German to Canadian "Hoserese"...and so at least Ian seemed to supply that, though I must admit Ian's translation DID sound a little more American English than it did Canadian Hoserese, huh?!)
Posts: 1,204 |
Guys, what are we talking about here. This is the Custom Corner. If you like the springer front end use it. If you like the girder or leaf spring front end then use that. So lets get chopping and bobing.....Angelis
Posts: 1,074 |
I do like the Springer with a damper shock. I'm not a big time twisty runner so that would not be an issue with me.
What I would like more, given the technology available today?
Some sort of anti-dive control hooked into the common front end. Say a controlled valve that works much like an anti-lock brake system does.
Sounds like your seeking a set of fork valves such as these http://store.ricorshocks.com/triumph_s/44.htm
Posts: 1,382 |
Wow, not to change the subject of this thread but Ricor has a set of rear shocks on sale for $250 pair in Ryk's link.
Tony G
'03 America
