Re: ....banging on one cylinder
roadworthy #448806 06/08/2011 10:41 PM
Yah, I should probably come up with something more fitting, or at least a little more witty.
Tomorrow is another day, but I don't think I'm going to be able to tool around with the bike. I'll keep everyone abreast though. Thanks for all the suggestions and comments. I really appreciate it.
Sometimes you get the bar, sometimes the bar gets you.
DuckOner #448807 06/08/2011 11:43 PM
Look closely at the needle valve above the float and the seat to see if it's sticking. If not, swap the slides. It's a quick way to eliminate the diaphragm as a culprit. Then you might just spray some carb cleaner into the 'T' junction and make certain that it's really feeding the right carb freely. You've done a lot of troubleshooting to get this far and there aren't that many options left.
oldroadie #448808 06/11/2011 10:42 AM
Success, at last. Although I'm a little miffed that I can't say what the problem was. I checked the float valve, the float height, and the float needle. I pulled all the jets and the idle screw, blew air threw everything and reassembled the carbs. The right side carb works now. I can only assume there was some kind of internal blockage that I blew out with the compressed air.
DuckOner #448809 06/11/2011 5:17 PM
This is a first and one to remember, a carb circuit blockage causing one cylinder not to fire and not the ignition system. Glad you're back on the road.
oldroadie #448810 06/12/2011 9:39 AM
Well, we're still waiting on that gasket. Haha.
DuckOner #448811 06/12/2011 9:57 AM
Glad ya got it sorted out.
Good learning experience though. I Bet now you could strip the bike down and back using a swiss army knife and a roll of duct tape.
DuckOner #448812 06/12/2011 11:15 AM
Way to go Ryan! Time to celebrate with a good and decent ride!
Keith #448813 06/13/2011 2:14 PM
Gaskets here, hopefully I'll be buttoning things up and laying down some rubber before the sun sets tonight.
DuckOner #448814 06/13/2011 2:24 PM
When you take the stator cover off, leave the bike on the side stand. Having the bike leaning away from you is advantageous in that you won't loose oil more than a thimble full.
Keith #448815 06/14/2011 10:01 AM
A very infomative thred,glad ya got it resolved.Now it's my turn Nanci's bike is doing the same thing altho after a while the right cylinder will fire to life and problem seems to go away.Tell me,do you shut the fuel off when your bike is gona sit fer a few days.I allways do and was thinking it took longer to reach the right side fer some strange reason.
marty #448816 06/14/2011 11:39 AM
I wonder if this is a subset of a problem I had a few years ago with a "bad" batch of fuel. Sitting overnight in a cool mountain parking lot something in the fuel jelled and I had to clean the entire fuel path to get the bike firing right again. News reports documented that the gas station chain had indeed obtained contaminated fuel and had fouled thousands of EFI cars (much to their collective dismay).
And, isn't the fuel tube longer going to the right side after the "T" and the 'hidden filter'? More room to clog...
oldroadie #448817 06/15/2011 10:29 AM
Right on! another project.
