tbs needles ?
#428202 02/19/2011 11:56 AM
chuckyj Offline OP
Ok what's up with tbs needles what r they? why do I want them? what r they going to do for me? I running short little drag pipes like the jcwhiny ones and I'm planing on gheto freak this summer. I know I need to re jet again when I do that sooo I want know if I should be plaining to do them too.
Thanks
Chuck
Re: tbs needles ?
chuckyj #428203 02/19/2011 1:33 PM
TBS needles are the ones used by Triumph on the early Thunderbird if I remember correctly. They are used to adjust the midrange performance of your ride. Typically there are 3 ranges of needles most fellows use here. The stock ones with or without shims. TBS needles with or without shims which allow more fuel in the mid range settings. Finally the Thruxton needles which allow the most fuel in the mid range. You will have to choose which needles works the best for you either through seat of the pants riding, or dyno tunes.
I use the TBS which helps with the mid range flat spot our bikes have once you start to mod them.
Re: tbs needles ?
Gregger #428204 02/19/2011 6:05 PM
chuckyj Offline OP
last question were can I get them
Re: tbs needles ?
chuckyj #428205 02/19/2011 6:11 PM
You can get the Thruxton needles here:
http://www.motorcyclestore.us/triumph/accessories/general/oil/index.html
I have not found the TBS needles anywhere.
Re: tbs needles ?
chuckyj #428206 02/19/2011 6:27 PM
chuckyj Offline OP
http://www.bikebandit.com/1998-triumph-thunderbird-sport/o/m17585#sch564640
going to try to answer my own question is this what i want number 4 right
Re: tbs needles ?
chuckyj #428207 02/19/2011 6:54 PM
Re: tbs needles ?
StandingBull #428208 02/19/2011 6:58 PM
chuckyj Offline OP
http://www.ducatitech.com/2v/img/fcr_graphs.gif
this should explain it all.
ya did t tell me much
Re: tbs needles ?
chuckyj #428209 02/19/2011 7:02 PM
Yup, that's it.
Re: tbs needles ?
Madrid #428210 02/19/2011 7:03 PM
chuckyj Offline OP
cool thanks its going on the list I think I am going to have to have it dynoed when I am done this year
Re: tbs needles ?
chuckyj #428211 02/19/2011 7:22 PM
The graph is about how the carby works, and balance between the parts. Because its all about throttle position. In other word you can put jetts, and or needles in and end up with "dead spots". Lean and or rich areas through out the throttle range. The chart should help with understanding what needs to be done as you work on your carbs.
For example after you get done. When you go for a ride and you have say an area in the throttle range that dont have the pulling power or pulls harder in one area. You can look at the chart and it will tell you what to change.
Re: tbs needles ?
StandingBull #428212 02/19/2011 7:42 PM
chuckyj Offline OP
I have a tuff time noticing any changes lol
Re: tbs needles ?
chuckyj #428213 02/24/2011 7:31 AM
My experience with the TBS is very positive. Initially I tried the thruxton needles and mid range they were great but just too thirsty. Then I thought I'd go back to the tried and trusted oem's with a shim. Gee, after feeling what the mid range using those thirsty thruxtons was like, Ferdie felt like a tired old bull ready for dog meat. So I then tried the TBS's. Yep, just like the story of "The Three Bears".
Probably a tad thirsty than the oem's with one shim but there's a reason for that.
As far as where to buy them, I just rang up Pro-Cycles St.Peters in Sydney and got them to send them to me.
Re: tbs needles ?
Stacka #428214 02/24/2011 11:02 AM
I got Thruxton needles. I am only getting about 40mpg. maybe I am goin to TBS myself. Will they be leaner probably.
Re: tbs needles ?
StandingBull #428215 02/24/2011 12:28 PM
Chad - How did you like the Thruxtons performance wise?
Re: tbs needles ?
Madrid #428216 02/24/2011 12:32 PM
Performance wise they are great they drink up the fuel though. I can do a spinout for about 4 feet.
Re: tbs needles ?
StandingBull #428217 02/24/2011 1:18 PM
I run Thruxtons with a shim. I only get 39 mpg commuting(city/highway mix). The performance cant be beat thats why I deal with the loss of mpg. I wonder what I would get on a real highway run.
Re: tbs needles ?
billpvegas #428218 02/24/2011 1:23 PM
Re: tbs needles ?
StandingBull #428219 02/24/2011 2:45 PM
Did they get rid of your popping?
Re: tbs needles ?
Madrid #428220 02/24/2011 6:48 PM
I got straight exhaust (no Baffles so you gotta expect a little popping) They reduced it quite abit. I am probably going to get bigger pilots.
Re: tbs needles ?
Madrid #428221 02/25/2011 2:03 AM
Popping is a condition that is hard to isolate, yet once I pulled the plug on the TPS is was gone. Finito. Done! Thing of the past!! Not just my experience but shared by many!
Re: tbs needles ?
Keith #428222 02/25/2011 8:32 PM
I'll have to give that a try, Keith. I seem to remember a long thread on here about that a while ago...
Re: tbs needles ?
Madrid #428223 02/28/2011 7:09 AM
I've read the purpose of the tps but "blank capping" mine had no negatives and only positives. Glad I did it, and mucht tidier too. Btw, I can't see myself ever going back to oem regsrdless. My only consideration now is what size mains.
Re: tbs needles ?
Stacka #428224 02/28/2011 10:53 AM
the jet caculator pined to the performance area is really accurate.
Re: tbs needles ?
StandingBull #428225 02/28/2011 2:22 PM
Following this thread did you get the TBS needles from bike bandit that originally went in the T-bird?? Are those the version that we would get for our bikes?
Since I've been ripping my carbs apart every other day for the past two weeks now might be a good time to tweak those and the mains.
Re: tbs needles ?
08America #428226 02/28/2011 2:53 PM
What are you doing..............practicing
Re: tbs needles ?
StandingBull #428227 02/28/2011 3:49 PM
No, Chad...in another post I was soliciting help with getting my bike running right at upper throttle positions. I think I have it on the run now-pun intended, but the process was a lot of pulling, cleaning, checking, etc. with the carbs. I have to do it all at least one more time to put in my inline fuel filter and figured hey while I'm in there I think Chuck may be onto something here
Re: tbs needles ?
08America #428228 02/28/2011 7:38 PM
chuckyj Offline OP
I orderd them but I dont know when I am going to put them in waiting for a air box to gut first then I need to get filters and jets sooooo I got a good two months if not more before I even get that far
Re: tbs needles ?
chuckyj #428229 02/28/2011 7:58 PM
So to clarify you did indeed get the T-bird ones you linked earlier on bike bandit right? Keep me posted on how you like them and all the juicy details. Please that is.
Re: tbs needles ?
08America #428230 03/01/2011 6:22 AM
bad jojo to change things for performance gains while you still have an unsorted issue. just saying...
Re: tbs needles ?
moe #428231 03/01/2011 8:15 AM
Yeah your probably very right Moe. I'll wait until I make sure she's solid. Then screw it all up again. Haha
Re: tbs needles ?
08America #428232 03/01/2011 1:30 PM
As I once saind in an earlier post, the TBS and Thrux needles work well if you still have stock pilot jets because they flow a bit more fuel in the mid range and make up for higher flowing modified airboxes and pod filters. If you go up to 45 pilot you may find the TBS and thrux needles to be too rich and may end up back with a shimmed stock needle. Just my experience from playing aound with the carbs on my 07 BA.
Re: tbs needles ?
08America #428233 03/01/2011 2:45 PM
...I'll wait until I make sure she's solid. Then screw it all up again. Haha
Re: tbs needles ?
gilligan #428234 03/01/2011 6:41 PM
I got the thruxton needles with 130 mains, stock pilots, and the screw are 3 turns out. The air box has been drilled out with (5) 5/8 holes in a diamond patern kind of like dice. I have a unifilter with the snorkle removed, and 18 inch long 2 inch diameter pipes with a 90 degree turn down (no baffles) clamped onto the stock header pipes were the slip on silencers clamp on. I am really close to right or at least as close as one can get without a dyno.
(I am only getting about 40 mpg, but got lotsa power.)
Re: tbs needles ?
StandingBull #428235 03/02/2011 10:53 AM
Sounds like a good setup locopony. I jetted my bike by the seat of the pants too and have similar mods. My BA is kind of a pig when it comes to gas mileage also, but i got a small fairing in front and like to ride fast so, you gotta give up something. Right now the bike is in the shop getting TPUSA 813 cams and igniter, so hopefully when I get it back it will be stronger still.
Re: tbs needles ?
gilligan #428236 03/02/2011 11:03 AM
It will be I want to some cams but I found that Wiseco has a 1200cc big bore kit I really want to do that, but its $9000.00
Re: tbs needles ?
gilligan #428237 03/02/2011 4:56 PM
Hey Pat!
Who's doing the work?
Uncle Charlie
Re: tbs needles ?
unclecharlie #428238 03/03/2011 9:27 AM
Hey Charlie, I'm having Gengras Motorcycles in East Hartford do the install. Cams are a little above my skill level plus they came and picked up the bike at my house with a box truck and are coordinating the job with Triumph Performace USA, so that made the whole process a lot easier.
Putting in the 813 cams and retimed igniter which adds up to about $1,000 bucks in parts from TPUSA. Gengras is doing the install on those parts and also putting in a set of progressive front fork springs for $1,050 - yes expensive, but still cheaper than me screwing up the job and bending a valve or something. Looking forward to having a couple more ponies in the spring!!!
Re: tbs needles ?
gilligan #428239 03/13/2011 12:12 PM
Just pulled my needles in my '06 speedmaster to replace them with Truxton needles (NBZ)...guess what I all ready have NBZ needles...so are Truxton needles stock ??? I have had this bike since new and I haven't change them
Re: tbs needles ?
gilligan #428240 03/13/2011 12:34 PM
Re: tbs needles ?
Keith #428241 03/13/2011 2:35 PM
Good pay, if you can get it
