Re: 21 front and lowered
ROB900 #423930 03/19/2011 3:06 PM
Finally done still thinking i should have gone with a taller back wheel
chopperpaul #423931 03/19/2011 3:44 PM
Thanks paul
ROB900 #423932 03/19/2011 7:25 PM
Very sweet!
ROB900 #423933 03/19/2011 8:41 PM
Nope Rob, your bike looks PERFECT!!!!!!!!!
(...except of course as I mentioned earlier about those still chromed instead of blacked-out shock covers ...but other than that...PERFECT!!!!)
Dwight #423934 03/19/2011 11:08 PM
I agree. It looks fine as-is.
FriarJohn #423935 03/20/2011 9:03 AM
Perfect!
Strangler
chopperpaul #423936 03/20/2011 1:56 PM
Now, about that gas tank...
FriarJohn #423937 03/20/2011 4:52 PM
I know where i can get a thruxton tank. But then you have to get it painted im done time to put on some miles sale it and start something else.
ROB900 #423938 03/24/2011 12:34 PM
Did you buy the rim from Buchanan's, or just have them assemble it for you? I called them last week looking for a 16x5.5, and they told me that the only option for a 5.5" rim was an 18" diamater. I like the look of a little more tire!
ROB900 #423939 03/24/2011 2:07 PM
ROB900: I was reading on an other site about the front brake. It looks like you started with a Speedmaster. Correct?..did it have dual front brakes?...if so, how is the braking with one disk...I understand from the another site the master cylinder has to be matched with the brake caliber,IE, if you go from two disk to one disk you need to change to an America master cylinder, otherwise the front brake can be very touchy.
SDKimo #423940 03/24/2011 3:40 PM
Mgpaul i had buchanans do it all they do have the same wheel i got in the size 16 5.5 look under rims for excel chrome wheels. Sdkimo i do have a speedmaster its hard to see but i still have dual discs i found a thunderbird sport hub and had it laced to a 21 wheel. About the master cylinder i dont know if thats the case i woudnt think it would make much differance.
ROB900 #423941 03/24/2011 5:23 PM
What they were saying on the other site is the brake lever displaces "two calibers" worth of fluid vs one caliber worth of fluid. That difference makes the brakes feel all most "on/off" vs a gradual feed of the brake. Maybe it is more important for sportbikes... I know my sportbike had a gradual feed which I really miss on my bike...Where did you find the Thunderbird Sport Hub...been looking for one for a long time.
SDKimo #423942 03/24/2011 6:17 PM
I got the hub from pinnwall cycles. They are hard to find but if you keep searching the net you will find one sooner or later.
SDKimo #423943 03/24/2011 9:18 PM
I bought the smaller BA master cyl when I did my Speedmaster conversion to single caliper. However, I kept the larger (9/16") cyl and it actually eliminated the spongy feel that our bikes are known for and gave me an excellent front brake without the "on/off", or very hard and immediate feel that I expected, having been down this road before.
Strangler
erle #423944 03/28/2011 7:34 PM
grezgorz heres a side pic you wanted
ROB900 #423945 03/28/2011 8:30 PM
Sweet!
Strangler
Keith #423946 03/28/2011 9:12 PM
here's mine
seagull
Brin did you lay your battery down on that relocation?-not to get
Mr. Berry that blue and white with laced up rubber is bad a$$!!! Love the look and you did a bang up job on her.
Brett
ROB900 #423947 03/28/2011 11:59 PM
Thanks for pointing me to the right spot on Buchanan's Website. I must have been talking to someone with them who didn't know all of the available products. Now, I see that they also offer a 16x6 chrome plated steel rim. Is 6" to wide? I don't want to go with wider than a 200 tire, but the steel wheel is quite a bit cheaper ($194 vs $356) than the aluminum if it would work.
mgpauls #423948 03/29/2011 3:15 AM
Like that back wheel, I dont usualy go for lowering but with that wheel it works.
chopperpaul #423949 03/29/2011 9:06 AM
Sweet!
+1 and another and another!
Erwin
05 America
ROB900 #423950 03/29/2011 2:24 PM
grzegorz heres a side pic you wanted
thank you
Erwin #423951 03/29/2011 3:51 PM
brett,
yep just layed it down on the side. i had to extend the smaller cables off both terminals so they reached.
thedeuk #423952 05/01/2011 1:38 PM
any of you speedmaster owners that changed to a 21" front have the old rim they want to sell???
i also have an america hub for any one looking to change to a 21"
Grzegorz #423953 06/11/2011 3:31 AM
and with stock mudguard on..I think it fit nicely just need to make a brackets
