Do Bonneville Americas come with a tool kit?
#417434 12/26/2010 3:46 PM
Hi I'm new to this forum. I picked up a (new to me) 2006 (790) America just before Christmas. It's in pretty good shape with only 6,000kms on the clock. One thing I can't seem to find on the bike is the tool kit most bikes come with. Do modern day Hinkley Triumphs come with breakdown tool kits and if so, where should I be looking on the bike to find it?
Thanks
John Quinnell
Sydney Australia
Re: Do Bonneville Americas come with a tool kit?
Johnquinnell #417435 12/26/2010 3:50 PM
No they do not
miniski #417436 12/26/2010 4:05 PM
That's because they Don't brake down.
HabuBA #417437 12/26/2010 4:08 PM
Yes they do
Behind the small cover on the left side , it`s all there (or should be )
What goes round comes round
boof #417438 12/26/2010 4:37 PM
Yes they do
Dang straight! Forgot about that one.
erle #417439 12/26/2010 5:12 PM
Hey John welcome to the site. I bought a 06 speedmaster new ( which I still have )and it only came with an alan key which is clipped to the back of the little cover on the left side.
erle #417440 12/26/2010 5:17 PM
Welcome John to the forums. As you've already gathered, they don't come with much. They really are dependable.
boof #417441 12/26/2010 5:33 PM
Yes they do Behind the small cover on the left side , it`s all there (or should be )
Nope, no tool kit. Tom (brokenfixed) came up with a couple of places to store tools once you get them. He has pics where you can see them in this thread.
Oh, and welcome to this site!
Keith #417442 12/26/2010 5:40 PM
Keith, behind the plastic cover around the key switch is an allen wrench. Typically only on Speedmasters to remove the seat.
roadworthy #417443 12/26/2010 6:29 PM
Thanks for the welcome guys.
I pulled off r/h side cover, ignition switch cover, fuse box cover - no tool kit but then again not much room in that area of a TBA for a tool roll anyway
mountainman's link has some great ideas for tool storage that I think I'll investigate though.
Cheers and hope you all had a great Christmas?
John Quinnell
Johnquinnell #417444 12/26/2010 6:30 PM
The tool kit under the cover is just an allen key clipped there.
The_Dog33 #417445 12/26/2010 7:53 PM
The one piece tool kit only came w/the SMs, I think.
My '03 BA didn't come with one.
unclecharlie #417446 12/26/2010 8:27 PM
I have to go look to see if Wendy's 04 BA has one or not, I know my 04 SM does.
The_Dog33 #417447 12/26/2010 8:41 PM
None with my 03 BA
Gregger #417448 12/26/2010 9:39 PM
I suppose the responses so far might easily lead onto my next question then and that is; "In the time of owning your Speedmaster or America, what tools have you needed while out on the road?"
Thanks for all your help so far,
John Quinnell
Johnquinnell #417449 12/26/2010 9:55 PM
I pulled Wendy's caliper off but it turned out to be the tire was rubbing on the fender not the brakes.Never needed anything else yet. Chain breaker and master link is always good to carry. Unlike a belt a chain can be fixed along the road good as new so you can continue to ride.
Johnquinnell #417450 12/26/2010 11:05 PM
John Quinnell
Ummm, well the 'basics' really. Pliers, crescent wrench, a set of Allen keys, a multi-screwdriver. I like to carry a socket set with a 3/8th drive and 10 and 12 mm wrenches. If you were running tubeless tires I'd say carry a puncture repair kit and 12 volt pump but I believe your bike has laced wheels with tubes? Otherwise I like to carry a chunk of wire, some electrical tape, and spare fuses. I mean you will never carry enough for any and all scenarios... and no doubt many riders carry much, much more. As long as I can adjust my chain, tighten a loose nut or bolt and replace a fuse I feel more or less prepared.
roadworthy #417451 12/26/2010 11:07 PM
Well that's true, Dave but it doesn't really constitute a 'toolkit.' And as suggested, I don't think the Americas had that.
Keith #417452 12/26/2010 11:46 PM
Both of my 07 TBA's have had the allen wrench mounted in the cover by the keyswitch.
But I do carry some extra tools/fuses/oil filter (and duct tape)just in case. What exactly I carry is still evolving, based on the suggestions of other more experienced members here.
Conwy #417453 12/26/2010 11:55 PM
My '02 did not have it. Regardless, the stock bikes do not come with any tool other than the allen wrench, so tool rolls and kits are all personal preference. If you like to tinker with your bike, tools are good to have, but you don't really need many for roadside work. There have been many threads on what tools to carry.
Conwy #417454 12/26/2010 11:56 PM
I think that Allan Key will remove the Battery as well
Mine had the clip but no Key (America 05 )
boof #417455 12/27/2010 2:57 AM
The larger question is what tools would you use on the road? If you broke down would you call roadside assistance or break out the wrenches? That should inform your decision. I generally carry everything (except the jack) to do everything I've ever done to my bike (well, except maybe the specialty tool to do a valve adjustment). Beyond that I'm calling a tow truck (or a friend with a truck). The larger issue again is spare parts, not tires. I had my tool roll when my throttle cable broke, but no spare throttle cable. When my front tire went flat last year, I called the dealership in Missoula (where I happened to be when it went flat). When my drive belt broke in 2005 I was in Missoula again. I had all the tools I needed to replace it except a jack (which the dealer loaned me) and the spare belt (which I got from the Harley dealership). Now that I have a chain again, will I take my chain tool? Probably not.
Now that I have a SPOT GPS Messenger, I'll probably carry even less tools since I can call for help just about anywhere. Things rarely go wrong, but when they do, they're huge (the previously mentioned problems, and the ignitor problems I had this Summer). Every time I've broken down, a truck or trailer was involved, regardless of the tools I carry.
Next year my tool kit might look like this:
Allen wrenches (cuz they're useful for lots of small things)
Screwdriver with some bits
A wrench for the pillion seat bolt
A wrench for the driver seat bolt (these two seat bolts should be allen heads too--I could drop two tools)
A fuse assortment
Leatherman
Cell Phone
GEICO card
GPS beacon
Trailmix and a fizzy drink to tide me over while I wait for rescue
That's about it. I need to buy a slim set of motorcycle-style jumper cables.
FriarJohn #417456 12/27/2010 9:10 AM
I carry an adjustable wrench, screwdrivers, 1/4 drive socket set, allen/torx wrenchs, small needlenose etc in my saddlebags for long trips. Raingear too.
I also carry a tubeless patch repair kit complete with plugs and CO2 cartridges. For tubed tires....a cell phone and luck which I never had that's why I switched out my laced rims for mags.
Parts - fuses, clutch cable, extra headlight bulbs, CO2 cartridges, bungee cords, tie wrap fasteners, jumper wire.
FriarJohn #417457 12/27/2010 9:30 AM
Ha Friar!
Rule of thumb. Carry whatever tools you last used. When going cross country take the tools needed to get to the battery. And to get to the top tube. Lastly, tools to drop the float bowls and remove the jets. Beyond that, we'll have to look for Freedom's promised land and enjoy not the fizzy drinks, but the distilled variety! Oh yeah, given the Far North West, clothes to survive in sub zero temps!
moe #417458 12/27/2010 6:09 PM
I carry a clamp on cable barrel for broken cables but not sure how much good it would do for a broken throttle cable. Could swap the close cable for the open cable to get you home. I rode my bike home once holding the cable in my hand tied to an old bolt to make a T handle so I could pull on it to operate the throttle.
The_Dog33 #417459 12/27/2010 9:44 PM
Hopefully we didn't scare away the new guy. He's gotta be thinking, "What the heck did I start?"
FriarJohn #417460 12/27/2010 10:42 PM
Nah, not scared off at all FriarJohn but there are some good ideas posted to help with my tools/spares set-up.
Thank you one & all for your useful suggestions. So much to learn when switching brands and styles of bike. My previous machine up to a week ago was a dual purpose Kawasaki KLE 500 but since getting
both knees replaced in September, the riding position of that bike was too cramped for my new knees hence the change of bike for a '06 model TBA.
Cheers
John Quinnell
Johnquinnell #417461 12/28/2010 6:54 AM
I carry a set of plugs too. I don't carry anything on my SM though since I have never had any problem with it at all.I have my cell to call a friend with a truck or tools if I ever need either. I do want to start taking my chain breaker though since any chain can fail.
The_Dog33 #417462 12/28/2010 12:32 PM
Ya know Ian, you keep mentioning the chain breaker, however I don't recall anybody's chain failing 'em around here on their BA/SM. Seems to me these new stout O and X-ring babies are just that..."stout".
I mean, yeah, I suppose it's anyways a good idea to be prepared and all, especially if we're talkin' about an older bike like your Triumph Chopper(or say any older bike with a kickstarter and breaker-points ), but like I said, I haven't heard of anybody around here having their chain fail on these newer babies....a whole lot o' chain GUARDS maybe, but no chains.
(...though maybe you have, eh?!)
roadworthy #417463 12/28/2010 5:33 PM
I have most of the above tools listed... I keep them in a leather tool roll under my headlight. Looks good and I carry extra plugs and the proper tools to change them (I) hope. (o; V.
boof #417464 12/30/2010 9:55 AM
Yes they do
bought mine new and there were no tools
Erwin
05 America
Erwin #417465 12/30/2010 11:05 PM
Yes they do
Sounds like only the Speedmaster came out with them
But then the America is the most reliable and doesn't need tools
boof #417466 12/30/2010 11:44 PM
Dwight #417467 12/31/2010 10:33 AM
Your thinking is narrow on this one, surprised at that. If I have a chain breaker with me at all times then even if the guy with me loses a chain I have the tools to fix it instead of a ruined ride. My own chain did fail once but as you stated it was on my chopper. Having that breaker with me saved the day. It may not happen often but when it does happen that one time it is great to be prepared.
The_Dog33 #417468 12/31/2010 11:09 AM
I suppose I should also say I don't mean to carry stuff for anyones bike that wouldn't also work on your own bike, but a chain breaker, small amount of duct tape wrapped around a pencil, some zip ties, small coil of electrical wire, some crimp connectors in a film vial,a clamp on cable barrel,set of plugs, and a master link or 2 are standards to me then a small assortment of tools. I carry water pump pliers, linemans pliers,small socket set (on a clip) a 3/8 ratchet that is the size of a 1/4 drive one with a flex handle, #2 and #3 phillips bits for the ratchet as well as a flat head, feeler gauges and gapping tool, wire cutters,small adjustable wrench. I would have to look but that is the bulk of my tool kit. On my chopper I carried timing tools and a spare breaker plate with points already on it.
mjdenton
FriarJohn #417469 12/31/2010 1:38 PM
A fuse assortment
Leatherman
Cell Phone
GEICO card
GPS beacon
Hey FJ, didn't you forget a 5 gal gas can? (Or Dwight's phone number)
Morituri Nolumus Mori
The_Dog33 #417470 12/31/2010 2:19 PM
Why, you old Boy Scout, you!
(...good answer!)
Re: mjdenton
FCTush #417471 12/31/2010 2:19 PM
What's up with naming threads after yourself?
Re: mjdenton
Keith #417472 01/01/2011 8:03 AM
Man....what started off as an allen wrench suddenly became everything except the kitchen sink.
Let's talk about type of tools. How many are the die hard "Snap On" only guys or the "El Cheapo Deluxe" group? What's your preference?
Johnquinnell #417473 01/01/2011 3:48 PM
