First valve shim check
#405941 10/12/2010 6:01 AM
Bruce Offline OP
Seems I always have a question. I'm getting ready to do my first valve shim check on my 06 America, it's 3,000 miles late but I finally have time to do it. I do have a couple of questions though. I used the rear tire to align the lines and dots on the camshaft gears and the "Top" is at the top on the camshaft drive gear. My first question is how critical is it to remove the alternator cover to align the mark on the rotor with the crankcase mating surfaces? My second question is are the crankshaft holder bolts (torx) extremely tight? I do have a hand held impact to use but am worried about cracking something if I use it. As always I look to the experience and knowledge of you guys and gals for the right answers. Thanks for any help.
Re: First valve shim check
Bruce #405942 10/12/2010 6:41 AM
First get a really good Torx set , impact if you can. Be4st to get a couple of the size you need as they are tough to get out. I put the bit in the bolt head with a 6" extension and gave each one a couple taps with a hammer before I took them out and all mine came out OK. I did break one bit in the process though.
As for the rotor cover on the right side of the engine. I haven't removed one yet. I did just as you described. Set the timing marks on the cams with the marks on the drive gear and the "Top" at the top. Don't move the engine while the cams are out just to be sure. Put back together with the new shims with the marks lined up again and you will be fine.
Don't forget to use the pins to hold the back lash gears. If the pins come out you need to re-tension them.
Bruce #405943 10/13/2010 5:37 AM
Bruce Offline OP
In the Haynes repair manual it says to lubricate the new shims and follower with molybdenum disulphide oil, what ever that is. Is it ok to just use the same motor oil thats in the bike?
Bruce #405944 10/13/2010 5:38 AM
chy Offline
Yep... that's what I do.
chy #405945 10/13/2010 7:00 AM
I wouldn't mind having a go at checking my valve shims . How many miles is the recomended time due ?
(kilometres in Australia)
Does this site have any pictures like in a workshop manual or will I just have to seek one out .
Peace in the country when the sun goes down , the corn is gettin' high
Silky #405946 10/13/2010 7:54 AM
12k miles.. i believe..
Bruce #405947 10/13/2010 4:09 PM
With all due respect, I think I'd do exactly what they suggest. They have probably researched it in their R&D labs.
I DO know that you would NEVER install new lifters/cam in a V8 and put motor oil only on the cam lobes! That HAS been PROVEN to be a cause of severe, early wear.
What are you going to save? $3.95-$9.95?
Maybe even $15!
(Remember what happened to valves (int/exh) that needed lead in the gas, when unleaded came out? I do.)
erle #405948 10/14/2010 5:07 AM
Wow, did I ever learn this one the hard way....Put my cams in wrong, engine would turn, but then "stop". My buddy hit the starter and bent all 4 exhaust valves (some of you may remember that)..On my wife's bike, a 2005 America, I removed the cam cover, and simply "loosened" the cam bosses, not taking the bolts all the way out, that way, I could pick the cam up just enough to get my magnet in to remove the shim that needed replacing, the cams never even had to come out. Install new shims after calculations, re-tork, and wah-lah...DONE. Did'nt even replace the gasket for the cam cover....Personally, I would'nt even bother with the thing if it was running good and not rattling more than usual...Just my 2 cents...
b717doc #405949 10/14/2010 9:44 AM
Personally I'd use some sort of assembly lube at the contact point(I like Lubri Plate assembly lube) using straight motor oil will cause premature cam wear. Not a serious issue given the 16,000 mile valve adjustment interval and the fact that most bikes wont have more than 4 or 5 adjustments over their useful life but an issue none the less.
As far as not worrying about it if it's not making excessive noise........ bad idea. Exhaust valves work into the seat and actually loose clearance over time while (no noise) intake valves will loosen up or gain clearance over time (these make the noise). Eventually the exhaust valves will recess into the seats to the point that they will not fully close, then you end up with burned exhaust valves and a hefty repair bill.
JMHO
cefox #405950 10/19/2010 1:43 AM
Mine are super overdue... part of what I'll address this winter!
Keith #405951 10/19/2010 4:07 PM
I'm due this winter at well, did it twice previously.
Label everything. I use separate zip-loc bags for each cam.
I made my own tensioner pins, cost me $3.
I just used motor oil to lube. I guess that I didn't read the shop manual carefully enough.
Engine is quiet at 38k, hopefully stays that way.
ssjones #405952 10/19/2010 6:34 PM
I use assembly lube but I always have that around from rebuilding other engines.
The_Dog33 #405953 10/19/2010 10:20 PM
I live in the sun downunder
Just a couple of points to remember when doing the job.
Don't mix up the bearing caps.
Make sure they go back the same way they came off.
FrankW #405954 10/20/2010 1:44 AM
Thanks Frank. Any tips are valuable to me 'cause I'm about to adjust the valves for the first time on my bike!
Keith #405955 10/20/2010 3:47 AM
Keith, When you loosen the bearing caps do it slowly and evenly or you can do damage to the cam.
When you replace the cams you do the same, tighten them up evenly.
If you look in thr Haynes manual they give you the right sequence, also I think with a diagram.
It's a very simple job to do if you take your time. If you do it over your winter you should have plenty of time. Six months at least.
FrankW #405956 10/20/2010 11:17 AM
Oooo, you bad, you really, really bad!!! But the tips you offer make up for it so I guess you are forgiven!!
Keith #405957 10/20/2010 1:01 PM
Is there a detailed writeup with pics on how to do the valve check/adjust out there somewhere?
SteelHorse #405958 10/20/2010 1:09 PM
All I know is that my shop charges 65 bucks to do it, and that makes it more than worth it to me!
roadworthy #405959 10/20/2010 1:36 PM
My shop is 113 miles away through the middle of a 6 million person city. I want to do my own valves.
SteelHorse #405960 10/20/2010 2:29 PM
Once I get out of St. Louis, only 30 miles of Illinois farmland for me to the shop
and they give me loaners
roadworthy #405961 10/20/2010 5:31 PM
I might even let them do it if it's only $65. I spend that in gas and shim cost when I do the job not to mention the time it takes.
The_Dog33 #405962 10/20/2010 6:02 PM
Hey, they gotta eat too! I try to support small business when I can.
roadworthy #405963 10/20/2010 8:49 PM
The last time I did mine it cost me $70 for the shims including shipping.
Even at $65 I'd still do my own though.
Frank.....don't start.... It snowed today and my bike is sitting in the driveway with the cover on. I'm hoping for 1 more weekend before it is parked.
You lucky.....#*^%(*@!
roadworthy #405964 10/20/2010 8:52 PM
65 bucks to do the valve check/adjust?
My dealer charged me 180 for the first oil change.
I checked and adjusted the valves after doing research
here.
unclecharlie #405965 10/20/2010 9:06 PM
Well, the labor was $65, the 4 bolt seals were 18 more dollars
Gregger #405966 10/21/2010 2:57 AM
Sorry Greg and Keith, I couldn't resist.
After seeing the pics that Keith has posted I envey you 2 some of the time, when it snows, No thanks.
roadworthy #405967 10/21/2010 2:59 AM
My local stealer who is also the Hardley dealer charges $80 an hour labour.
Thats why I do my own maintenance.
Bruce #405968 10/21/2010 5:29 AM
Bruce Offline OP
Confused. When I took off the oil feed pipe to remove the camshaft there was a crush washer right under the bolt head but none under the oil feed pipe that contacts the head. When looking at the diagram on BikeBandit they show a crush washer both on top and under the oil feed pipe. Was there suposed to be one under it when I took it off?
Bruce #405969 10/21/2010 7:04 AM
I found the same thing the first time I did mine. They are actually copper washers.
When you look in the Triumph parts manual it only shows 2 in the diagram. In the parts listing it says there are 4.
I went to my local brake centre and bought 4 copper washers and put them on both sides of the pipe where it connects to the cam bearing cap.
FrankW #405970 10/21/2010 4:48 PM
Man, you guys are lucky. The last Triumph dealer in Orlando charged $85 an hour for all makes EXCEPT:
$99 for Triumph/Ducati
Maybe THATS part of the reason they'er no longer here.
Can a dealer do it in only one hour? I'd have thought it would be like 2-3 hr. flat rate charge!
erle #405971 10/21/2010 4:57 PM
They told me the most it would be is for 2 hours, but usually just one.
roadworthy #405972 10/21/2010 6:56 PM
If you have the shims available and have done it before, you should be able to do it in 1 hour, but why rush.
I bet you Dinqua does it in 4 beers.
erle #405973 10/21/2010 7:35 PM
Lexington motor sports, my nearest dealer, has the same labor rates, the local dealer I worked at charged $75/hr flat rate.
Gregger #405974 10/23/2010 1:58 AM
Is this allowing for:
Jacking up the bike.
Removing the seat.
Taking off the fuel tank.
Moving thr coils because they are in the way.
IMHO. Gonna be a rough and ready job in 1 hour.
FrankW #405975 10/23/2010 2:30 AM
Knowing me it will be a two or three day job, but I will have learned something AND be able to do it in much less time in the future.
Keith #405976 10/23/2010 2:46 AM
Keith, Take it from me, it is a simple job.
Don't rush it and you will find it quite easy.
The last shims I got were from the local bike wrecker because none of the local bike dealers keep them in stock. (Even then I got them on a part exchange basis so I still have no spare shims) I was fortunate that he had them after sorting through a box of shims with a set of callipers.
Have you got the Haynes manual, the instructions in that are quite good?
FrankW #405977 10/23/2010 2:53 AM
I do Frank, and I believe I'll be fine. Heck... even if it takes 2 weeks, who cares? There's plenty of time before April!
Keith #405978 10/23/2010 6:41 AM
I haven't had to remove the coils.
The_Dog33 #405979 10/23/2010 7:23 AM
Ian, On my 2004 Speedy if I dont move the coils the cam cover won't come off.
FrankW #405980 10/23/2010 8:01 AM
Frank,
I just removed the coil wires. Like Ian, I had enough room to remove the cam cover without taking the coils out.
Keith,
If you can get the shims from a Honda or Yamaha dealer, they are a lot cheaper. I purchased mine a Triumph dealer and they were $10 each (ouch).
I've pasted the info from the tech vault, Parts Cross Reference Section to help.
Valve Adjustments [Re: bennybmn]
#98534 - 05/04/06 11:45 AM Edit Reply Quote Quick Reply
Valve Adjustments:
Yamaha Shims for the V-Max are direct replacements for Triumph shims.
SOB shims
25mm Used in Honda ('79--'83 4-cylinder CB750, 900, 1000, and 1100 series engines, and 1050 CBX 6-cylinder engines, and others), Yamaha (V-Max, and the FJ1100/1200 series), Triumph 3- and 4-cylinder liquid-cooled motorcycle engines, and older Toyota car engines.
