Re: Progressive 812s...$164
DunnSpeed #393182 07/22/2010 11:55 AM
Well mine have arrived; but does anyone have any tricks/tips to make doing the swap easier?
Martin62 #393183 07/22/2010 1:39 PM
use a jack to raise your bike to take the tension off while you replace your shocks. That's about it.
I just got mine about an hour ago. Hopefully I'll get time tonight to swap them out.
My only complaint (and it's super minor) is that there is no indicator or anything to tell you by looking at them what the pre-load is set at. The instructions do say they are set at the lightest when they come from the factory.
Soren #393184 07/23/2010 8:51 AM
Just ordered mine.
Now just need some saddle bags and I am all set for my end of summer trip.
Soren #393185 07/23/2010 9:33 AM
Sometimes the bushings from the old shocks will stick on the posts. My mechanic advises heating them to get them off. "Hot to the touch, not glowing red."
Mine are due today. Guess I know what I'm doing this weekend.
Joe_Merlino #393186 07/23/2010 11:38 AM
Got the shocks yesterday. Installed them last night. It was a piece of cake. I did remove the R2-D2 looking hardware covers though for a more stripped down look. Put on about 60 miles last night and they're feeling pretty sweet compared to the stockers.
Captain_Midnight #393187 07/23/2010 11:49 AM
They look Great! Where did you get the peg hangers?
Soren #393188 07/23/2010 12:47 PM
Those are super sweet looking.
Joe_Merlino #393189 07/23/2010 7:42 PM
I had to remove the top chrome covers so they would fit with the Corbin seat.
miniski #393190 07/23/2010 8:27 PM
The peg hangers are homemade. A member on here cut the design on a CNC. I bought them off him, welded the passenger pegs on and took it to my local powder coater. I think the color's called silver vein. I had him do the bolts to match. It was Seattle Powdercoat that did the painting. I went with them because they had no minimum size/cost requirement.
miniski #393191 07/23/2010 9:20 PM
Hmmm...anybody else with a Corbin put these on yet and had the same issue?
I guess I'll wait and see if I need to make any adjustments when mine come and I'll report as well.
Thanks for the heads up with the Corbin.
Captain_Midnight #393192 07/23/2010 9:58 PM
I was gonna say, I thought those looked like Rob's old peg hangers! They look good coated.
DunnSpeed #393193 07/23/2010 11:02 PM
Soren #393194 07/23/2010 11:20 PM
Very Cool, Soren. They look great!
DunnSpeed #393195 07/24/2010 11:08 AM
I'm slow and old I guess. I paid $219.
Ridin' and playin' 'til I can't.
Bluehot #393196 07/24/2010 8:20 PM
Thanks for the tip Soren.
Using a simple scissor jack, I was able to do the swap in about 30mins, working solo (I hasten to add I strapped the front down first)
Photos when (if) it stops raining!
Martin62 #393197 07/25/2010 3:13 PM
I put mine on today. I took the chrome covers off both the top and bottom, both to make them fit better with the Corbin, and because I didn't especially like the look of them anyway.
Had a little trouble getting a couple of the bushings from the stock shocks off. A little PB Blaster and the vice-grips did the trick. Whole operation tool 50 minutes.
Check your preload. The instructions say that they come set on the lowest setting, but mine didn't.
Man, what a difference! I still felt the bumps but there wasn't as much of a bouncy feeling going over them. They don't compress nearly as much under acceleration, so there's not as much of that squat-and-go feeling when you start from a stop. And when you give it some gas in a turn, it feels much more planted. None of that sickening "sliding out" feeling (is this what people mean by "wallowing"? I've heard that term a lot but never known what it meant.)
These shocks would be a decent investment even at the list price. For under $200, it's practically manditory.
Joe_Merlino #393198 07/25/2010 8:01 PM
Mine weren't either. Mine were set in the middle. I set them at the lowest setting.
I put a bit more than a 100 miles on them today. They definitely do the trick! Not to mention I love the way they look.
The hardest part about getting mine on were getting the hole plug cap things on without bending any of the tab things.
When I removed my old shocks, I jacked up the bike just enough to relieve all the pressure (tire still on the ground) and used a large screw driver to gently pry them off.
Soren #393199 07/27/2010 10:19 AM
I changed them last night, and then rode into work this morning. Much more comfortable. Definitely loving them, and definitely planning on putting progs up front now, too.
Joe_Merlino #393200 08/03/2010 6:47 PM
Mine showed up today . Pretty quick really.
I'll get them on tomorrow and get some pics up. I hope there's no trouble trying to get the old ones off.
DunnSpeed #393201 08/06/2010 9:09 PM
Lonzo Offline OP
Finally got mine on tonight. Getting the bike ready for a poker run tomorrow.
The bushing nearest the chainguard absolutely would not come off. Had to cut off the rubber part and carefully heat it with a torch. The paint was thicker in there or something. The new shocks are tighter against the seat. They were both set up for the right side, had to rotate the baloney cut section around on one. Instructions said to remove the caps first, but I didn't read them til I was done.
Anxious to check them out in the morning.
Lonzo #393202 08/08/2010 1:48 PM
Lonzo Offline OP
OK, did a 122 mile poker run yesterday and another 120 miles or so today. The new shocks weren't as magical as I had built up my expectations, but are much better than stock. My back doesn't hurt like it usually does after a couple hundred miles. In the twisty section on the way home was the most noticeable difference, don't have to slow down for the little bumps and ripples in the asphalt around the curves.
I greased the posts and bushings with white lithium as suggested above. I heard loud sqeaking as I was putting my bike in the garage. The baloney cut shroud on one of them was rubbing on the spring. Pulled it away with my hand, hope it stays.
