Lowering quick Q
#388075 05/08/2010 7:26 AM
dahla Offline OP
I've tried searching the forum but haven't found what I was looking for.
I want to lower my bike !", front and rear. Is it possible to lower the front 1" by cutting down the spacer 1"? The spacer is pretty long, and I reckon that cutting a little bit doesn't completely ruin the preload, or am I way off?
Hoping I don't need to buy the lowering kit, 'cause I don't want the wrench that much in case I don't want it lowered after a while.
Black '07 Speedmaster FTW!
Re: Lowering quick Q
dahla #388076 05/08/2010 7:59 AM
For a quick fix you could just slide the forks up in the clamp like the sport bike kids do. You can get maybe 3/4" or so before you get too close to the handlebars but that ought to let you know if the lowering idea is working for you. Gonna have to buy some shorter shocks, tho, since StreetBoogie quit making his lowering blocks.
oldroadie #388077 05/08/2010 8:11 AM
dahla Offline OP
Yeah, but lowering the front is another beast than lowering the rear. I've read posts here that says that progressive 11.5" lowers the rear close to 2", that's why I've been looking at the 12", only 0.5 lower than stock. So I feel that rear is easy enough, the front not so much.
dahla #388078 05/08/2010 8:26 AM
I can't see any reason that wouldn't work just fine. Easy to reverse it too.
dahla #388079 05/08/2010 8:27 AM
Is it possible to lower the front 1" by cutting down the spacer 1"....'cause I don't want the wrench that much in case I don't want it lowered after a while.
+1 on sliding the forks up until you know if you want it. Tightening 8 bolts is way easier than trying to find new oem spacers after cutting them. Just my 2 cents. NR
1982 Pontiac Trans Am...K.I.T.T. in progress. "It looks like Darth Vaders bathroom in here..."
Night_Rider #388080 05/08/2010 9:58 AM
I cut the spacers and it made the front end too soft and bottomed very easy. I actually made shorter spacers and then put the stock ones back in. I think sliding the fork tubes up in the trees is a good way to see if that is what you want. I think it looks cheesy though and if you wanted to keep it that way get the lowering kit.
The_Dog33 #388081 05/08/2010 10:00 AM
Yes, then once you're satisfied the new Progressive drop in kit would be the way to go without undue wrenching.
oldroadie #388082 05/08/2010 11:27 AM
dahla Offline OP
Thanks guys.
Oldroadie: I asked Fast Eddy about the drop in kit some days ago and progressive told him (Ed) that they didn't fit our bikes. Hope they do make them for Triumph soon...
dahla #388083 05/08/2010 11:35 AM
Both bikes use 41mm fork tubes so it's probably just a matter of winding the shorter main springs to suit our lighter machines. I'd be willing to bet that the lowering spring would work just fine on one of our stock springs that was cut 1" but obtaining that spring is another matter altogether.
oldroadie #388084 05/08/2010 4:22 PM
phoenix
phoenix
I'm with you roadie.i've lowered way to many cars, to not say this. Cut the spring 1" reinstall it. And it should all work very nicely, if it isn't your "cup of tea" Stock springs seem to be in abundance.Any altercation to stock, suspension will change the dynamics of the factorys plan for these bikes ,and their ride qualities. But like they always told me:just depends on how good you wanna look goin down the street!!
bob s
bsa_bob #388085 05/08/2010 9:59 PM
No Bob, you misunderstand, Ed meant to install the lowering spring at the bottom then cut the stock spring.If you just cut the spring you will make the front end too soft.
The_Dog33 #388086 05/09/2010 7:00 AM
Yep, I meant to say: install their compensator spring (but at the top where it goes in the regular "new" kit) on a cut regular spring. Because I'm guessing the shorter Progressive main spring is the issue with the kit and not the compensator. That said, I've been wrong before and the compensator spring might be the issue and not the shorter main spring. I think it's worth asking Progressive to get a real answer...
oldroadie #388087 05/09/2010 9:28 AM
phoenix
phoenix
Compensator spring.....that is the real short one in the bike bandit schematic....right????????
bob s
bsa_bob #388088 05/09/2010 9:45 AM
Not at all. In the new "drop in" lowering kit from Progressive there are two springs per fork; one for suspension and the other to lower the bike. The difference is that you don't have to disassemble the fork and place the second spring under the rebound damper to shorten the tube's effective length. It's a trick installation idea to put a softer spring under the preload tube to lower the bike without making the suspension too soft or mushy. Check it out: http://www.progressivesuspension.com/dropin/index.html
oldroadie #388089 05/09/2010 9:57 AM
For what it's worth, I will soon have a set of good condition Progressive 412's for sale. I'm on the road on business right now, so I can't check, but I believe they are 11.5 inches. I know the front is lowered, more so than some other bikes (2" maybe?) and I hate it. Even the dealer warned me that the bike is unsafe. So she will soon be returned to stock height with Hagon Nitros and Intiminator up front.
The Progressives will probably go on sale in late May.
Conwy #388090 05/09/2010 7:24 PM
When I posted I was under the impression that the 2nd spring still went under the dampener, I had no idea they changed the kit.
