Page 3 of 3 1 2 3
Re: NEW Jetting calculator
REBEL #383084 10/12/2015 11:15 AM
The cover screws can be sourced at a decent hardware store. Not doing anything to the intake and just removing one baffle will not cause your bike to cease running. You may need to re-jet, but you might have other issues, is what I'm trying to convey.
Ryk #383085 10/12/2015 11:40 AM
I agree. We really need more info to have a good suggestion on what route to take.
The_Dog33 #383086 10/12/2015 12:17 PM
Hi Guys, My problem started just last Saturday, I rode for about 1/2 an hour refill gas and then I notice loose of power and I just came back home. should I check hidden filter?
thanks again
REBEL #383087 10/12/2015 12:21 PM
Lose the hidden filter and replace with a inline one and that possible problem fades away. Did you buy some bad gas? It's been known to happen. After changing out the gas, add some Seafoam and see it that helps.
Ryk #383088 10/12/2015 1:09 PM
I would drain the bowls into a container and see if there is any water or dirt in it too.
Ryk #383089 10/12/2015 1:41 PM
It's supposed to be one of the best brands, I will remove hidden filter and replace it with inline fuel filter, change gas and follow with Seafoam.
Thank you so much guys
REBEL #383090 10/13/2015 11:50 AM
any body has a part number for my 124 main jets?
Thank you guys
REBEL #383091 10/13/2015 12:46 PM
Thank you guys
Fast Eddy Sports or BellaCourse is a the only mail order source you need for jets. Either will send you what you need the first time. Or just go to a local Japanese bike shop.
Ryk #383092 10/13/2015 3:15 PM
Thank you Ryk, I did send a message to Fast Eddy. I am waiting for an answer.
REBEL #383093 10/13/2015 5:36 PM
Eddy has a full time job as a Helo para-medic, along with his other endeavors. He'll be in touch.
Ryk #383094 10/13/2015 7:09 PM
Thank you guys
Think I pretty much said that a few posts back.
The_Dog33 #383095 10/13/2015 8:03 PM
The learning curve or the circle. We learn by redundancy.
Ryk #383096 10/15/2015 10:03 AM
Hi guys, Eddy contacted me already and He is checking on my jets. Thank you for your help from a completely Newb.
The_Insane_Viking #383097 11/06/2015 4:02 PM
is THERE ANY MEMBERS IN LOS ANGELES CA AREA ?
The_Insane_Viking #383098 02/20/2017 11:03 PM
I Used Dinqua's calculator. Awesome. That being said I have a few questions.
I have a 2007 Speedmaster with British Customs Bomber Exhaust mufflers and stock jet needles. I'm planning on removing the airbox and putting Dual K&N (Freak)on.
Do my mufflers fall under the "Misc Open Pipes"?
The Calculator says 120 for Main Jets with Stock Pilot Jets and Needles. Do I need to or would it help to change the stock Pilots and Needles?
Thanks for any help on this.
Edwin #383099 02/21/2017 1:07 AM
I would think the Bomber exhausts would be close to Epcos, increase your pilots up 2 or 4 points too. I'm guessing 146 Mains for a start. Just console yourself, you're going up in jet size with the config change you described. Try some T-Bird Sport needles, they work well for me with no shims. Once you feel your close to optimum, it's Dyno run time to get it perfect.
Ryk #383100 02/23/2017 8:29 PM
Thanks Ryk. Off to do some wrenching now.
Edwin #383101 03/31/2017 11:39 PM
Hi guys. Can anyone suggest jetting for an 03 BA with BC cocktail shaker, k&n pods setup? The calculator doesn't show shakers but I'm guessing a good starting point would be 152 or so mains with 45 pilots and stock needles without shims. BC told me they recommend 135 to 140 and 42's which doesn't sound right. 2000ft elevation. I'll probably have to experiment a little but if anyone has this setup I'll start with what works. Thanks.
dbontheb #383102 04/01/2017 6:17 AM
I have gutted stock with pods at about 1800' and runn 155 and 48. I dyno with a good mixture.
The_Dog33 #383103 04/01/2017 8:25 PM
Thanks Dog. That's much appreciated.
Dinqua #601721 07/02/2021 1:43 PM
What's the difference between "Dual K&N (FREAK)" and "K&N PODS"??? I have two individual K&N Pod filters on my '06 Speedmaster (on it when I got it).
John W. '06 Speedmaster 865, Sceptre pipes, Uni Pods, 45p/148m (Keihin), 2.5 out, NBZT needles w/1 shim, SAI & EVAP X'd, TTP S1 CDI, Nology Coils, Avon Cobra Chrome Tires, Morimoto 2Stroke 3.0 H4 LED Bulb, Eastern Beaver Relays and 3CS
Dinqua #601723 07/02/2021 7:02 PM
Same thing from my perspective.
B02S4 #601734 07/06/2021 2:05 PM
Dinqua Offline OP
Wow, this has been out there awhile.
Page 3 of 3 1 2 3
