 What's your max speed?
Posts: 2,419 |
What's the maximum speed you've wound out to on your America/Speedy?
Specify MPH or KPH, engine size, sprocket gearing and other relevant performance mods.
I haven't pushed my '09 865 America over 150kmh yet - mainly because of lack of a safe, cop-free opportunity. Just curious what can be had.
 Re: What's your max speed?
Posts: 3,816 |
110 mph on the clock what in real who knows 18 front/41 rear 790cc
Posts: 2,531 |
 It looked to be about 118mph or 119mph , just shy of the 120 mark.....however the Texas Highway Patrol ( just East of Pecos, Tx) said I was only doing 111mph ! But that was stock except for AI removal , K&N filter and Scepter exhaust....now it has the 904 BB kit installed so could probably do the 115 - 120 mph
Posts: 1,668 |
Well past an indicated 120mph with 120/90 front tire, 904, ported and polished head,stage 1 cams, Sceptres, 16/42 or 19/42 sprockets. It'll do it either way.
Posts: 2,419 |
Thanks for the 904s. What about the 865s?
(sorry Daniel I didn't read your post carefully enough -I see now it was before the 904 kit. Was it a 790 then?)
Posts: 2,525 |
75 - 80, I think I did 90 once
Erwin 05 America
Posts: 10,735 Likes: 7
Posts: 10,735 Likes: 7 |
+1, I don't speed either
Posts: 8,639 Likes: 3
Posts: 8,639 Likes: 3 |
I've seen 115 MPH on my 790, into a headwind with a little throttle left.
Posts: 1,160 |
I had the speedo around 115 i think once I dont like looking and taking my eyes off the road at that speed.
Life need a little Triumph!
Posts: 5,590 |
I (we) hit 70-75 mph once in British Columbia last July. Coincidently a kindly officer with the Royal Canadian Mounted Police was simultaneously there to record the event. He had a very fast horse.
Posts: 2,626 |
About 125 indicated. 790, 16/42T, lotsa fun.
The Hayabusa Killa
Procom CDI
Posts: 23,243 Likes: 64
Posts: 23,243 Likes: 64 |
I've had my speedo buried with the 16/42 combination my engine is a 790 mostly stock.
Any report without outside verification is useless. Unless you have GPS or the aforementioned kindly RCMP with a radar gun confirming your speed (or perhaps a properly calibrated aftermarket digital speedo), it doesn't mean a thing. Triumph speedos are crap.
Posts: 3,753 |
120 mph by my buddy following on his sprint with a gps
Posts: 3,995 Likes: 10
Posts: 3,995 Likes: 10 |
160kph,but that was by speedo which we know is "a little" inaccurate. On the dyno run I just had done it reached an accurate 180kph.  "07 America 865cc.Aftermarket pipes,AI blocked,re-jet,K&N filter,snokel removed ,carb needles shimmed
Posts: 973 |
The posted speed limit
Posts: 738 |
I always stick to the limits like you Graham. We are always well behaved!
Anyway approx 120 on the clock was 109 on the sat nav!
Btw speedo ok upto 30 mph past that understated by about 5-10%.
Posts: 1,668 |
I would try that except that my buddy can't keep up on his "Hawg".
Posts: 2,531 |
Yes....that was 790
Posts: 200 |
2003 Speedmaster 790 16/42 gears. Slight downhill grade the very optomistic Triumph speedo was well past 190 kph (118 mph). The bike was wound right out because I came up against the rev limiter. Bike has shown an indicated 190 numerous times in it's hard life but that was the first time it actually came up against the rev limiter in a flat out run. That's all there was and there weren't no more.
Posts: 2,362 |
A couple of times I've pulled the bike back at an indicated 175kph - the bike had more in it but I didn't. 790cc, 18/43, slightly bigger than standard jets (can't remember what size, not much over standard though), modified air inlet, thunderbike pipes. Oh, and a big roadster screen to slow it down too, so would probably do more without it. Before the pipes it would max out at just over an indicated 160kph.
I pulled just under a ton once... the speedo was reading 160 kph. But then again my speedo read high in those days (pretty much bang on now with the bigger front tire) so I was actually going a wee bit slower than that.
Posts: 116 |
109 with a GPS calibrated extra speedometer installed, 17/42, D&D pipes and a jet kit. UNI filter and AI removed. No other changes from stock.
Posts: 2,419 |
I'm thinking a GPS would only be accurate on a reasonably level road ... I don't imagine hills are factored into their speed? 2% gradient would introduce a 2% error.
Posts: 706 Likes: 1
Posts: 706 Likes: 1 |
hey Richard 2% error that a lot closer then our factory speedo down the 1/4 mile mine was reading 160kph when in fact the pass was at 145kph out at willowbank
Posts: 2,419 |
True. 10% variation is a lot (145 vs 160). My speedo reads 4% less than actual (based on 5km road markers). Just pointing out that GPS aren't as accurate as some might assume. If you're going down a moderate hill they could be out by 5% or even 10% on a steep hill.
Posts: 1,680 |
Mine has always been less than my bike's, so I have only an inkling of what she can really do.
Thom
Posts: 877 Likes: 2
Posts: 877 Likes: 2 |
My 02 would do about 115mph,but I bet is was less than that..
Posts: 1,586 Likes: 1
Posts: 1,586 Likes: 1 |
Same as LKR,190kph on prety much stock 03 790 18/42 and like he said that was all it had.Havent tried it on my 904,my eyeballs are just starting to settel.
my zumo says 98.0 mph. Captured this past August when rolling with the Englishyankee.
Cinnamon Girl prefire 790 17/42 D&D's
Posts: 144 |
Was climbing through 96mph yesterday, in 4th, when I had to throttle back...pesky cagers!
Stock '07 America, 865. Well, almost: AI gone, last baffle removed, snorkel removed, but not rejetted, yet. (So I'm sure I was pretty lean at those higher RPMs.)
"It doesn't matter what you ride, as long as you're out there."
- Hells Angels President (Philadelphia Chapter)
Posts: 6,681 Likes: 1
Posts: 6,681 Likes: 1 |
101 trying to catch Donny.  No AI, 2 baffles out of the pipes, other then that stock.
Posts: 326 |
186km/hr 115mph, Installed GPS, fully legal  on the A2 near Berlin on the way to the Euro rally in Poland. I have the 904 with FCR39 flat slide carbs, i was flat out but still slowly increasing. I think around 190KM/hr is possible. Nick
Posts: 95 |
I have made the ton a time or two. I would guess this bike (stock) will do 110.
Posts: 1,174 Likes: 15
Posts: 1,174 Likes: 15 |
just after break in on a mostly stock 865 speedy, I ran it up to a indicated 120 mph (it took a while to get there). given the known inaccuracy of tthe speedo, probably really 110 mph. Haven't tried it recently, but with (now) taller gears more hp and a slightly higher redline, pegging the speedo should be easier.
Posts: 807 |
Not the fastest bike on the block about 170 on the clock but it's very quick getting there.AI removed,no snorkle,raase pipes, can't remember the jetting now but the vacuum slides are bored out to 3mm, hohoho father christmas is back
Posts: 1 |
2009 model. indicated 105 mph with more to go.
Posts: 2,726 |
I hit an indicated 115 mph (actual probably almost 10 less) and I felt it could definitely keep going up, only problem - I couldn't.
Bob
Posts: 404 |
How fast is buried? "I've had my speedo buried"
Americas are not fast. They are a mid-range cruiser. Just enjoy the ride man.
If you want to go really fast buy another bike.
Posts: 2,419 |
Yeah I agree. Mine is plenty fast enough for me and ditto for acceleration. I was just curious about what they could do cos I haven't wound mine out yet. And I thought it would be interesting to compare results across the different size engines.
